发表于 2008-1-3 10:45:14
来自: 中国安徽芜湖
接近:GB/T 4171-2000 高耐候结构钢: Q. V7 _( W- K% q* F8 `8 A3 i
GB/T 4171-2008 耐大气腐蚀结构钢(预审稿)8 d8 {/ `( y/ Z1 w
JIS G7101-2000 Structural steels with improved atmospheric corrosion resistance1 E9 w5 v& y1 P
ISO 4952 Structural steels with improved atmospheric corrosion resistance 8 a( e% Y6 u; i
1 z" ?- V: o. `6 ^( h }
- j/ w. \# S6 B7 {http://www.key-to-steel.com/cn/img/nav/spacer.gif5 p& {4 |( t7 o0 k8 r4 W% @
化学成分 (%)' n+ } ~7 J8 a, D
4 _" o+ B& R$ ?' U| 元素 | 最小 | 最大 | 近似的 | | C | 9 V' u8 U+ A7 F6 F
| 0.1200 |
. O& E$ x- p, q. V4 { | | Si | 0.2500 | 0.7500 | 9 l- q9 B& w8 ]. M3 O% Z( m
| | Mn | 0.2000 | 0.5000 | ( Y8 P% @* b1 c/ k- t. m
| | P | 0.0700 | 0.1500 | 9 ^# |# d' n W. K
| | S |
5 v! [6 f) p2 f0 |0 ^ | 0.0400 | ' V. q2 N7 r6 s& r7 d
| | Cr | 0.3000 | 1.2500 |
* [ o5 U0 d j. o( \/ Y2 s" o% [- D | | Ni |
7 p1 S6 x: W' w& `( a1 e" _7 c, O | 0.6500 |
6 @# c" d* x8 v' f3 ~! c | | Cu | 0.2500 | 0.5500 |
4 |. R$ G6 ?+ G: M5 @
6 i K' J7 X( ~9 e/ ohttp://www.key-to-steel.com/cn/img/nav/spacer.gif# A6 Z6 a4 r( ~. N. M3 x+ J, c) l
化学成分 (%). ~, B% Z" m2 w n
| http://www.key-to-steel.com/cn/img/nav/spacer.gif8 ?- ?, A+ ]; Z* E! s
| 元素 | 最小 | 最大 | 近似的 | | C | " y9 B8 \9 r* y! w
| 0.1200 |
. ?* |$ S9 M! w | | Si | 0.2500 | 0.7500 |
+ [6 {- d, M9 a/ C* t | | Mn | 0.2000 | 0.5000 | 8 ?* z' }/ y' L2 C+ `5 Y
4 g" M+ c. h( P5 k6 E- {0 @ | | S | 6 t, X/ A' w3 D
| 0.0400 |
, l" k0 K" D: u# j/ Q | | Cr | 0.3000 | 1.2500 |
) h; Y h, D9 k6 d: {. T. T | | Ni |
) g1 h1 j4 V0 j2 \% {' |7 e | 0.6500 | / y; N* o B$ N5 |7 ?
| 6 N' O. K+ w) F2 ^ l
| ( h* P% N4 e7 i7 y) [2 j/ n! ]- _$ W
2 ?- n# j: y) Q, I4 S$ i- h7 @+ x; w6 H6 k5 W4 l
http://www.key-to-steel.com/cn/img/nav/spacer.gif* n, v3 u) A0 W' j3 C5 N
化学成分 (%)
9 e" D7 E# \7 e; F: t3 b | http://www.key-to-steel.com/cn/img/nav/spacer.gif
w. n) `$ O5 E D' A- `0 X| 元素 | 最小 | 最大 | 近似的 | | C |
0 F& o, \' R+ J- C! r& T | 0.1200 |
# V+ N" S% ]9 \2 ?1 Y | | Si | 0.2500 | 0.7500 |
P/ d; w6 \# v9 B' n5 P | | Mn | 0.2000 | 0.5000 | ( h; P4 L3 ~0 M T8 e; J
% }6 D% z4 i6 B2 [0 J2 c. k | | S |
( }: W6 j( T; { | 0.0400 | / m- u; n5 P* w% m. a) [, |: _
| | Cr | 0.3000 | 1.2500 | ! i5 j! R" v7 X% X6 `. f! o5 U
| | Ni |
U' `! @. Z# j, I' P4 I0 m: O5 z | 0.6500 | 7 n# n! j% v+ a' Q/ D( d3 W2 s
| ( V, ?( R, f; a- F: e/ H, Q; Y1 A
' ] Q; _. H0 |0 M
0 E. D3 N" x) k4 ^/ d" `# M2 o
$ b$ |4 Z% Y. V7 y7 Hhttp://www.key-to-steel.com/cn/img/nav/spacer.gif: [/ Y. `5 [2 d. R
化学成分 (%)& c u7 r3 U; o
| http://www.key-to-steel.com/cn/img/nav/spacer.gif4 B2 ^% L* e* }% {1 C
| 元素 | 最小 | 最大 | 近似的 | | C | 1 m5 r7 q8 u% m8 d
| 0.1200 |
: N# m& E5 F) ~& ~. F | | Si | 0.2000 | 0.7500 |
! R- v3 b, e, [5 A3 ] | | Mn | ' |' \' Z4 l6 F, d: o$ d8 R% f3 b
| 1.0000 | ; y0 M' _$ v; N2 `: @
| | P | 0.0600 | 0.1500 |
8 ?8 @' T: Y$ o, F. A | | S | $ ?. Y5 j& q2 S5 ?5 ~, s2 \
| 0.0500 |
]; ]* @( j% r( ~3 z) J | | Cr | 0.3000 | 1.2500 | 2 v7 L" y# w$ M' o P( s9 K
| | Ni | : s/ E% x2 f/ ] M6 j( U: o% \2 K. s
| 0.6500 |
e- O! ~: H- h) S* r | | Cu | 0.2500 | 0.5500 |
| 9 v& i; }/ V/ M% W [& {
: t" ]" { q8 X) ], l6 Z5 D9 z$ J+ x# ]" K! t
http://www.key-to-steel.com/cn/img/nav/spacer.gif" t2 ]" ~' `/ T8 S! z
化学成分 (%)
6 T9 z" P# l7 q$ V9 ]8 \ | http://www.key-to-steel.com/cn/img/nav/spacer.gif
1 f+ t3 L& Y' C| 元素 | 最小 | 最大 | 近似的 | | C |
2 o- n c( i$ I' s | 0.1200 | 8 f* e+ K1 K! x6 b
+ o L( v3 Z: l& L; a2 |- N | | Mn | 0.2000 | 0.5000 | 8 u! A+ `7 y0 d' D6 m' C% q
| | P | 0.0700 | 0.1200 |
0 y* O# e C4 _1 g Z$ Q | | S | ; ]" o$ r+ N; @5 M# ~# i
| 0.0300 |
$ a1 H3 K' }0 k( ^ | | Cr | 0.3000 | 1.2500 | & O& x' X( D$ A
| | Ni |
3 ?4 B' ~: E: s) ~* F | 0.6500 |
& ?$ P7 K3 y2 f5 w/ x/ P | | Cu | 0.2500 | 0.5000 |
| 3 l% D4 w- e8 D- }
8 [0 H j9 v9 P. v* h P B化学成分 (%)1 K( V1 s3 U9 S, ~- a" ?0 [
| http://www.key-to-steel.com/cn/img/nav/spacer.gif! `+ F; z d; q' a7 \. N
# y5 s1 `) F$ v0 S* c% R5 m* D0 p | 0.1200 | & A9 _$ }( o a J7 V6 z! s
| | Si | 0.2500 | 0.7500 | 0 ^( v8 S. P1 G; h$ E( P0 p
/ ]2 o4 f: v3 \& j5 E+ g9 ] | | P | 0.0700 | 0.1200 | 6 b3 g! u& Q: }
| | S | + ?" W& R8 a# v: b" F
| 0.0300 |
0 u1 a; b0 m' o9 E0 X. s | | Cr | 0.3000 | 1.2500 |
' ]% r w7 M3 g8 P" S9 ]# `2 m | | Ni |
; t0 Z- L7 U0 u8 ]8 G1 ~; \0 c | 0.6500 | - I c' Q1 r# q* e$ i2 x+ A2 I8 Y
& M( N$ Y+ d5 D, e |
| http://www.key-to-steel.com/cn/img/nav/spacer.gif4 [' y5 B5 x/ q4 I& G, a
化学成分 (%)& D6 Y) m; ]' d
! c1 X: C$ y! |1 J) r8 d| 元素 | 最小 | 最大 | 近似的 | | C | 1 Z( ^! |: U' x# Z2 o; z3 I1 E t
| 0.1600 |
3 z* w. W4 b% A+ Q$ Y3 x | | Si | 2 L$ j! Z+ r# ~. W4 |9 p7 T
| 0.5000 |
; m4 {2 |2 ]0 ~% e' W( L | | Mn | 0.9000 | 1.5000 |
# M$ i& R( ?. [4 m' O | | P | . n7 K" j4 x2 C9 O {
| 0.0350 | * F9 F6 @* |: i7 j8 M
| | Cr | 0.4000 | 0.8000 |
! ]( v+ y3 Z: W! U3 {. W | | Ni | , V4 {! q- n8 e4 g' v# e' z& D
| 0.0350 |
1 ]0 @6 L, l: C+ A0 ? | | V | 0.0200 | 0.1000 | ? | | Cu | 0.2000 | 0.5000 |
| 2 T& C Q% v: {: y* a9 O: n; _
| + j( ]* y1 _! [6 f/ N2 P# N
. n: G- n8 {* a; d& |+ M[ 本帖最后由 hourpp 于 2008-1-3 11:12 编辑 ] |
