发表于 2008-1-10 08:40:01
来自: 中国浙江宁波
4 P1 F+ u2 A# R( Z, K5 h$ i
: P! L; r9 ^9 D O
lisp代码:
& R5 W, u' o# D/ ?3 b(setq var (getvar "cmdecho"))
+ C+ D/ E4 I; F! f9 j# M. E (setvar "cmdecho" 0)
; e* ^+ P. l, E: Z/ P. U" } c0 H# }0 J (command "-style" "standard" "gbtxt.shx,hztxt.shx" "" "" "" "" "" "")
( N9 T c& w& y( F' | Z4 b! G (command "-style" "单位名称" "gbtxt.shx,hztxt.shx" "" "" "" "" "" "")+ Q. A0 L$ q% q7 N( j! R7 O
(command "-style" "工程字" "gbtxt.shx,hztxt.shx" "" "" "" "" "" ""); G2 n9 }% T$ A) H4 i
;;(command "-style" "standard" "txt.shx,bigfont.shx" "" "" "" "" "" "")
8 L% W1 U/ Q9 C3 Y" J ;;(command "-style" "单位名称" "txt.shx,bigfont.shx" "" "" "" "" "" "")9 M6 n9 n6 I, @; g& N5 a+ r M
;;(command "-style" "工程字" "txt.shx,bigfont.shx" "" "" "" "" "" "")
5 I8 z! I6 `- ^ (setvar "cmdecho" var)- ?7 f; L5 |8 f9 L& n, x
(command "_qsave")
9 K! C0 B+ O, W9 Z# n3 q( Q3 X (command "close"): Y6 \% p' r6 D: p2 v' B Q
2 c6 X. p* Q! M: V- G1 }- c9 Y2 m代码放在acad.lsp文件中,将此文件放在CAD的support文件夹中,在“选项”中设置每个文件都加载acad.lsp;使用时只需打开要修改的文件即可;自己电脑上2008版调试通过;建议楼主先备份一个要修改的文件然后做试验,修改后删除acad.lsp再次打开修改后的文件,如果成功无问题后在做批量修改;3 o* U; T$ ~0 _8 w- q
本程序只作方法指导用,建议楼主使用前仔细调试,因各人电脑及软件差异,制作者不承担由此带来的一切后果! |
