查看: 4470|回复: 18
[求助] AMESim仿真出现异常,有没有用得熟一些的高手指点一下?
发表于 2008-1-16 16:53:02 | 显示全部楼层 |阅读模式 来自: 中国上海
运行仿真时出现以下提示,不能出结果。6 f0 _6 P% \" `) X; ~( b3 h& q/ \
不知道是模型建得有问题呢,还是软件本身有问题?
& W: O6 {) M! n7 |* t% I
: p7 Y2 C6 B9 E! qlc_checkout failed with -5 - retrying after a short sleep try no:0 6 t. y9 P! R0 ~$ B9 ]& C  m# x
lc_checkout failed with -5 - retrying after a short sleep try no:1 4 h% G: A$ `( y7 J- a
lc_checkout failed with -5 - retrying after a short sleep try no:2
6 ]1 R$ f4 C3 D+ o+ n) {lc_checkout failed with -5 - retrying after a short sleep try no:3
" c$ T0 l5 ?8 x  T7 h# \8 v/ dlc_checkout failed with -5 - retrying after a short sleep try no:4 ' h) V5 _  j$ |& ?& [6 h) x
lc_checkout failed with -5 - retrying after a short sleep try no:5
! i# E2 S1 \6 }1 t! l, c( l9 Y  klc_checkout failed with -5 - retrying after a short sleep try no:6
9 i. |& ^2 [, ]0 D/ Y9 M" S' `lc_checkout failed with -5 - retrying after a short sleep try no:7
& K' e' l, `! f6 l+ nlc_checkout failed with -5 - retrying after a short sleep try no:8
* a$ }; e* _7 X6 olc_checkout failed with -5 - retrying after a short sleep try no:9 % R2 x" X* i* L- [+ A  [5 J9 u+ j
lc_checkout failed with -5 - retrying after a short sleep try no:10 - l" Z. G' ?, `
Checkout failed: No such feature exists.
" {0 I0 g& v; ?' w$ ~  e8 ?Feature: hydraulic + o$ c" J+ Z/ C# N
License path: D:\AMESim\/licensing/license.dat
* s/ J/ F* J* ^FLEXnet Licensing error:-5,357
" d! G7 \3 e" x* [& o. b$ zFor further information, refer to the FLEXnet Licensing End User Guide, 1 U4 l) Z2 T6 `
available at "www.macrovision.com". 9 r& c4 h; J% h4 y+ H, V) R7 E
AMESim model E:/cylinder_ did an abnormal exit!
+ B; J, {) N( }) p- p
2 s2 N% `! ^9 r非常感谢!!!
发表于 2008-1-17 09:21:30 | 显示全部楼层 来自: 中国四川成都
可能是license的问题,你弄个帮助文件里面的模型运行看有没有问题
发表于 2008-1-17 15:26:40 | 显示全部楼层 来自: 中国天津
请问楼上这种软件有中文版的吗
发表于 2008-1-17 15:48:50 | 显示全部楼层 来自: 中国四川成都
没有,而且基本上没有中文教材,不过可以看英文帮助文档
发表于 2008-11-25 22:22:28 | 显示全部楼层 来自: 中国内蒙古呼和浩特
的却是lisence的问题,你没有Crack对,可以查查amesim的安装方法,论坛里面就有,crack也有。
发表于 2008-12-13 15:18:48 | 显示全部楼层 来自: 中国湖南长沙
哪个好心人能给我一个amesim 7.0的license
249359104@qq.com% b- |, b4 T& m) `: q6 i0 J
- b) d9 Z5 u1 t0 o
非常感谢!!!
发表于 2008-12-14 09:57:32 | 显示全部楼层 来自: 中国四川成都
你是amesim 哪个版本,我有8.0的crack
发表于 2008-12-14 14:19:04 | 显示全部楼层 来自: 中国陕西西安
应该是license的问题,我有7的crack,需要给我留言
发表于 2009-2-12 15:51:00 | 显示全部楼层 来自: 中国浙江宁波
chdiulong
0 }% A4 z8 M# ]3 P9 @/ K0 A6 F2 u5 ~ 请发我一个,谢谢!. g( Q% K" x- X) n5 K: P
295992877@qq.com
发表于 2009-3-4 09:26:34 | 显示全部楼层 来自: 中国吉林长春
我的也是只能建模不能仿真,上网查了一下是因为licesene缺少东西
* ]6 p" v8 \9 h" s3 F谁能帮忙解决一下,非常感激!
发表于 2009-4-9 12:41:14 | 显示全部楼层 来自: 中国四川成都
/ t3 G! \! E  z8 R非常感谢wff198037@163.com
发表于 2009-5-5 10:23:29 | 显示全部楼层 来自: 中国江苏镇江
回复 7# 龙门起重机 的帖子
我要8.0的,谢谢了
. F  q' O5 a! b8 M) v3 Gxunqunde1@163.com
发表于 2009-12-1 09:46:19 | 显示全部楼层 来自: 中国重庆
哪个好心人能给我一个amesim 8.0的license,非常感谢,
# `. n  e0 K; n% r! y5 C  m, }: D% hzzxjbs@163.com
发表于 2009-12-7 21:01:22 | 显示全部楼层 来自: 中国河北保定
发表于 2009-12-7 22:25:15 | 显示全部楼层 来自: 中国内蒙古呼和浩特
发表于 2009-12-8 11:01:38 | 显示全部楼层 来自: 中国辽宁鞍山
论坛里面有搜一下就行了
发表于 2010-1-8 21:29:36 | 显示全部楼层 来自: 中国河北保定
发表于 2010-3-26 09:09:40 | 显示全部楼层 来自: 中国陕西西安
我也出现了跟楼主同样的问题,请问楼主是怎么解决的?
发表于 2010-10-22 11:20:12 | 显示全部楼层 来自: 中国广东深圳
RE: AMESim仿真出现异常,仿真液压库中没有二位二通阀(常开)怎么办
18# joopl2007
