下面是程序代码,红色的部分就出错了,报错:实时错误'91',对象变量或with块变量未设置。。。我都不晓得错在啥地方了,希望高手可以帮我解答下。。。红色部分有两个函数,我分别用了,错误都是一样的。。。谢谢了。。。。。。。。。
2 z* A8 h' x6 \; F) ]
9 X, |. `( t% G* s
+ p. S- c& B( ]Private Sub Command2_Click()
. \* G/ R, d! [) ^) @' HDim swApp As Object
7 H$ l% A$ l* i2 g" e' t; }Dim Part As Object! m/ W% H+ }( w% Y# O- G7 K/ e$ R
Dim SelMgr As Object
1 s- U- A! e7 d% ?% @Dim boolstatus As Boolean3 p& h4 i5 B5 s E
Dim longstatus As Long, longwarnings As Long
6 y t, r) a# q5 D& w& U4 LDim Feature As Object$ k; Q9 W/ E1 s$ i# {; z; W
Dim matefeature As SldWorks.Feature
% H! `, ]! V7 Y: _7 yDim mateError As Long
2 _7 ?" J" p; i( E, f8 a- J+ FDim AssemblyDoc As AssemblyDoc
2 o& a+ B' M! s6 n* _Dim modeldoc As AssemblyDoc! }5 f" D3 r) i* h$ ^8 `& E) g
Dim swassy As SldWorks.AssemblyDoc
7 E1 |0 q- j/ F7 ^9 ~8 jDim swmatefeat As Object
1 G- Y5 v6 K% NDim nErrors As Long
: ?. K0 w! {2 Q+ b8 J( hSet swApp = CreateObject("SldWorks.application")
4 l4 a7 T+ s8 t( R/ d3 OSet Part = swApp.OpenDoc6("C:\Documents and Settings\Administrator\×ÀÃæ\Assem1.SLDASM", 2, 0, "", longstatus, longwarnings)
. L9 T9 e {$ W( MSet Part = swApp.ActivateDoc2("Assem1.SLDASM", False, longstatus)
5 Z+ b: {: I& l0 N& ?: PSet Part = swApp.ActiveDoc
5 V' [8 M4 S' {/ T/ o. vSet SelMgr = Part.SelectionManager7 R6 q+ A2 i; b% V( ?8 z
Part.ClearSelection2 True
' e. O# |3 r4 S, u2 _Part.AddComponent "C:\Documents and Settings\Administrator\×ÀÃæ\Part1.SLDPRT", -0.02323122071431, 0.03645583370445, 0.08245399542471
/ `8 B* U2 }' p ]boolstatus = Part.Extension.SelectByID2("", "FACE", 0.01501535777649, 0.04541356535486, 0.06745399542474, True, 1, Nothing, 0)
6 I$ o/ t; h/ b: o& @boolstatus = Part.Extension.SelectByID2("", "FACE", 0.01242594790686, 0.003812740405351, 0.04944596164239, True, 1, Nothing, 0)
' F3 J5 U0 }* z9 `Set swmatefeat = swassy.AddMate2(0, 0, False, 0, 0, 0, 0, 0, 0, 0, 0, nErrors)
5 G1 x k2 \% s- j! { R: [2 @1 Z6 \ |4 J2 l: `
'Set matefeature = AssemblyDoc.AddMate3(swMateCOINCIDENT, swMateAlignALIGNED, False, 0, 0, 0, 0, 0, 0, 0, 0, False, mateError)( w+ F& `8 C [2 t: ]
Part.ClearSelection2 True/ [6 }% r0 {) c, S' a- g
End Sub |
