- 积分
- 6
UID721267
主题
在线时间 小时
注册时间2008-7-3
下载了SW 2006 4CD版本,用的挺好,可是,最近老是出现cosmos licence问题,说 authorization fialed. + q1 _4 y' I6 [4 Q5 _4 M2 k
licence administrator tool 截屏在附录里面。licence的内容在下面。问题是都没有改过,原来可以用,现在不能用,而且删了重装也没有用。还有,在其他机器上可以用。考过来还是不可以,ps,我有四台机器,现在三台不能用,一台可以。很奇怪,有人知道原因吗。谢谢
) q9 b: {. G* l2 L8 I! U& r2 H/ v, g# V/ k, C# I
: o7 w" x* [$ f3 N* P/ u. h
FEATURE CUST_CODE SRAC 2.000 permanent uncounted E8C60AB208C6 \7 H6 I8 B+ ^1 _# k+ |4 X$ ]
VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212 \
) Z, E- _; l; a3 H7 g vendor_info=112233 dist_info=permanent user_info="THE FORCE \" s0 z. X" u# g* j4 [# Z% H
TEAM 2006" START=1-jun-2005# O) f5 U; p6 v. z8 b
FEATURE DS_PARTS SRAC 2.000 permanent uncounted 4B34D3F1AE94 \$ z4 F$ S! l8 y7 G4 S) u
! O: s; n) }; I% @FEATURE CW_EDUPARTS SRAC 2.000 permanent uncounted 56AB4D6F49C5 \
! v ?, B+ i9 Z; F0 Q& q VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212
3 R5 i* E; f; T5 fFEATURE CW_EDUASSEMBLIES SRAC 2.000 permanent uncounted EBA1C80CDFC0 \
% f, w0 w$ K/ G+ j VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212
- B8 D5 @' }7 n$ Q3 l3 q) VFEATURE COSMOS_EDUMOTION SRAC 2.000 permanent uncounted B09A17DE195E \2 M1 x7 J8 G& @# |8 ? p. ?
$ U, u& G, O$ jFEATURE DS_ASSEMBLIES SRAC 2.000 permanent uncounted 34FCFA072388 \9 v# h5 _& |, }' z% e4 s
& d; H! Y I& Y; dFEATURE CW_PARTS SRAC 2.000 permanent uncounted 0B1E5B38AF8E \/ E1 \: n+ b8 j* {
VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=12213412121 y& Q9 I T# U2 E
FEATURE CW_ASSEMBLIES SRAC 2.000 permanent uncounted F6CE4D945EAA \1 g# c% f3 ?( j: [1 z
+ c, U% A+ @2 s8 I4 G# LFEATURE GEOSTAR SRAC 2.000 permanent uncounted 2F0118CB1284 \+ F1 J, S o$ k3 f* t& j" R
* c5 B8 f$ Y* ~* W: r. x, DFEATURE LINEAR_STATIC SRAC 2.000 permanent uncounted A3D0099995AB \) {2 G* {$ Z4 }8 s) }2 p6 Q; I9 p J
VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=12213412123 A B5 Z% U4 `5 f
FEATURE LINEAR_FREQ_BUCK SRAC 2.000 permanent uncounted 25321ECCE20F \8 O" ^) R% g7 S, w' v1 W
VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=12213412120 V& i; M8 h1 s7 i! `
FEATURE THERMAL SRAC 2.000 permanent uncounted 4A36A29AE3AE \
, N, G5 p3 _2 |9 G/ @! B+ H VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212
& Z+ g y7 G% oFEATURE OPTIMIZATION SRAC 2.000 permanent uncounted 62CE08AAC4AE \
$ B* M4 c, `- V! \7 ?- _7 X VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212" h' M8 a5 { l" y6 I# H9 W- f
FEATURE DYNAMIC_RESPONSE SRAC 2.000 permanent uncounted A357D71D69F2 \# W( @2 O; F& h, Z6 a$ o
: q( o, y. r$ b( P, G% BFEATURE NONLINEAR SRAC 2.000 permanent uncounted E265D0109FF2 \3 X& J( d* l( L i% t# E1 @, z1 s# ]
VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=12213412127 n; U; R2 P4 M/ p; h8 ]
FEATURE FATIGUE SRAC 2.000 permanent uncounted 68C17E13051E \2 d0 |. A9 j8 E0 f, V/ r6 ~4 A
" L3 l% t% u% {3 m, bFEATURE EMS_LF_BASIC SRAC 2.000 permanent uncounted 0AD022D92757 \: \0 H1 H# d& \. l, y0 z/ J3 S! }
VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=12213412120 ^: L; Y$ y! B6 h. t
FEATURE EMS_LF_ADVANCED SRAC 2.000 permanent uncounted 7A828BE81540 \
! |7 y5 ~$ h* j9 S VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212- I) _; O( E( y' i0 b# q4 f
FEATURE EMS_HF_ANTENNAS SRAC 2.000 permanent uncounted 24FFF657D05A \
) i+ d+ L, W& ~5 b! I% L* A VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212, ]9 f- Z0 M, ~5 \# X' E) z: n
FEATURE DS_CATIA_TRANS SRAC 2.000 permanent uncounted 633DDB7D6889 \6 B: t$ z, f; D# O
6 b2 B' N' x2 QFEATURE DS_PROE_TRANS SRAC 2.000 permanent uncounted C303AB0DEDD4 \% f2 n+ m, M* U5 E- e; ~
# @7 L; V/ j! f2 H: e! m* A( A0 ]FEATURE ANSYS_TRANS SRAC 2.000 permanent uncounted C0F3155B1C49 \
2 Q, ]8 {6 r5 l VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212! d3 X; C! }1 {
FEATURE NASTRAN_TRANS SRAC 2.000 permanent uncounted D41F26B2322B \
' j0 \4 x; O+ U9 O VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212
9 S# o# K1 M4 ]& j0 B4 PFEATURE PATRAN_TRANS SRAC 2.000 permanent uncounted B733036F693A \: n$ {$ \& b* G8 u5 {/ k% v
VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212( N4 U* C- a$ J7 m6 k2 N
FEATURE IDEAS_TRANS SRAC 2.000 permanent uncounted CD7AE5176E6D \
" P1 {* `& {4 c+ v1 D VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212( z. |- U9 K+ }
FEATURE COSMOS_MOTION SRAC 2.000 permanent uncounted 4364FCDA5D87 \
( j& n/ `6 Q u VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212
. k1 M4 t) V+ Q1 k/ S' m% zFEATURE HFS_2D SRAC 2.000 permanent uncounted B3BBBFF31ADD \6 R2 H% F5 F. ~# t
VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=12213412125 D! y" f: V8 s! W( h; n
FEATURE HFS_3D SRAC 2.000 permanent uncounted 1D94B2EAC458 \5 o A. h/ _; a: l: q( F
VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=12213412127 m8 M3 e6 ?- x" @7 n. Q% D: |- Y
FEATURE HFS_CAVITY SRAC 2.000 permanent uncounted 45291E413EAA \& i7 T- Q" p% [ c
VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=12213412122 N# W4 D: W& I. s# w% z1 [
FEATURE COSMOS_FLOWORKS_STD SRAC 2.000 permanent uncounted \
; Y' M6 U1 B1 b; E( r 34635CAE47C0 VENDOR_STRING="THE FORCE TEAM 2006" \
; m; b1 }4 a# t* \' m1 o HOSTID=ID=1221341212; ]3 c/ E+ N4 K3 C* U2 ]6 |
FEATURE COSMOS_FLOWORKS_PE SRAC 2.000 permanent uncounted \& T3 |& V9 d0 H$ u- F1 R
C4AC1AEF8B69 VENDOR_STRING="THE FORCE TEAM 2006" \% d0 I9 N5 f E2 `& z7 p0 g" z
HOSTID=ID=12213412121 q4 a) }' |; S# r- N
FEATURE COSMOS_EDUFLOWORKS_STD SRAC 2.000 permanent uncounted \
; [- O6 a* t r: I( U' E 004B8ABECE17 VENDOR_STRING="THE FORCE TEAM 2006" \3 ~) v( x$ d! K* a9 E$ y
' q+ H1 C" T) J- @. n0 AFEATURE COSMOS_EDUFLOWORKS_PE SRAC 2.000 permanent uncounted \
2 j& d' n6 z" F" ~6 e/ F0 @ DC2887913E51 VENDOR_STRING="THE FORCE TEAM 2006" \) G/ F4 a4 Z' B0 G5 W4 _) H
3 _4 c. Z4 D: T" N7 _+ z( q9 FFEATURE DROP_TEST SRAC 2.000 permanent uncounted 43F4F8CA164E \
* l$ n% ~% `+ |8 g/ X VENDOR_STRING="THE FORCE TEAM 2006" HOSTID=ID=1221341212 |
