查看: 1227|回复: 0
[分享] Disamatic Molding Explained
发表于 2008-7-9 20:05:51 | 显示全部楼层 |阅读模式 来自: 中国辽宁大连
, t; x: l8 S; K7 v1 z1 Z/ Z8 y
Currently, all Metal Technologies foundries utilize Disamatic Molding Machines to produce molds for our castings. Disamatics offer a highly efficient means of rapidly and automatically creating a string of flaskless molds. These molds are built for vertical casting and are created in a vertical molding environment. For an explanation of the process, read through the text below and click on the thumbnail images to see illustrations.
1 C# d0 j) o$ \4 A- C: D& b% j
Step 1. Sand is blown into the Molding Chamber from above.
! s! g$ Z. V$ M* c
Step 2. The Ram advances, pushing the Ram Pattern. This compresses the sand in the Molding Chamber to form mold impressions." I5 A9 d. }0 D7 f6 R$ P' _7 |9 _
: V1 m0 q' q/ i, P% f
Step 2. (cont) The compression creates opposite halves of consecutive molds to placed in the mold string.
6 G, ?/ [( s* [
Step 2. (cont) Castings cannot be formed using a single mold, but when a new mold is placed in the mold string, its leading edge meets the trailing edge of the previous mold to create a completed mold cavity. ' l! f. H( x/ U- ~& g# A# V
/ c7 w8 E% p2 t' S1 r% s: U  Q/ k
Step 3. The Swing Pattern moves back and up to allow the mold to exit the Molding Chamber.7 X* `5 o* \* V% F+ j( S9 ~
- F& G  A3 ?' l* R+ S! u- l" C5 y
Step 4. The Ram extends, pushing the new mold into the existing mold string.
/ k5 h7 Z/ k' b8 f! ^
! z- j  c# U: F$ n! y
Step 5. The Ram and Swing patterns return to their original position to begin the process again.
5 H* S- b6 R7 W7 v; Y
Step 6. Sand is blown into the Molding Chamber for the next mold. A little further down the mold string, iron is poured into the top of a formed mold via the pouring sprue left by the pattern impressions.
