发表于 2008-10-28 21:00:42
来自: 中国河北唐山
常见的涉及DIN标准的铸造标准如下:
. C; ~& S5 h& A) j) _DIN EN 12892-2000 铸造.用于失型铸造工艺的失型生产设备 Founding - Equipment for the production of lost patterns for the lost foam casting process; German version EN 12892:2000 I* J) N0 O( g4 Y- {8 ?/ T7 G
DIN EN 12890-2000 铸造.砂模和砂芯生产用模型、砂芯盒和模型设备 Founding - Patterns, pattern equipment and coreboxes for the production of sand moulds and sand cores; German version EN 12890:2000 9 N) x! W( d- o/ _8 D/ I4 p$ l0 x
DIN ISO 5832-4-2000 外科植入物.金属材料.第4部分:钴铬钼铸造合金 Implants for surgery - Metallic materials - Part 4: Cobalt-chromium-molybdenum casting alloy (ISO 5832-4:1996)
. x) o/ G8 F0 H1 T7 bDIN EN 1559-2-2000 铸造.交货技术条件.第2部分:钢铸件附加要求 Founding - Technical conditions of delivery - Part 2: Additional requirements for steel castings; German version EN 1559-2:2000 ; Q+ \+ R1 U1 z4 {* n
DIN 47600-3-1974 最高可达 10 kV 电力电缆用金属铸造连接盒.第3部分:用纸质绝缘电缆对连接盒的连接.裸露的绞合铜线焊接的连 Cast Metal Joint Boxes for Power Cables up to 10 kV; Correlation of Joint Boxes with Paper-insulated Cables; Correlation of Bare Stranded Copper Bonding Wire
, L& ~ b6 @. g+ I3 Y$ t+ IDIN 47600-1-1974 最高可达 10 kV 电力电缆用金属铸造连接盒.第1部分:保护连接盒 Cast Metal Joint Boxes for Power Cables up to 10 kV; Protective Joint Boxes * N' @# O8 Z3 O+ A* x. k: G) B
DIN 47635-1973 铸造金属电缆接头用垫片槽和褶皱 Gasket grooves and folds for cast-metal cable fittings % Z3 R; s; n& H% }; L
DIN 47600-2-1974 最高可达 10 kV 电力电缆用金属铸造连接盒.第2部分:内连接盒 Cast Metal Joint Boxes for Power Cables up to 10 kV; Internal Joint Boxes
# D. u/ n5 y- lDIN 1688-3-1980 轻金属合金的铸件毛坯.金属模铸造.一般公差、加工余量 Light metal alloy raw castings; gravity die castings; general tolerances, machining allowances
/ B: @7 i) U A9 ^DIN 47600-4-1974 最高可达 10 kV 电力电缆用金属铸造连接盒.第4部分:纸质绝缘电缆的内部设计 Cast Metal Joint Boxes for Power Cables up to 10 kV; Internal Design for Paper-insulated Cables
5 v0 u1 P4 a) l/ rDIN 47600-5-1974 最高可达 10 kV 电力电缆用金属铸造连接盒.第5部分:纸质绝缘电缆的安装说明 Cast Metal Joint Boxes for Power Cables up to 10 kV; Installation Instructions for Paper-insulated Cables
3 |) _- L$ A2 p' K; YDIN 47600-6-1974 最高可达 10 kV 电力电缆用金属铸造连接盒.第6部分:用0.6/1kV 塑料绝缘电缆对连接盒的连接 Cast Metal Joint Boxes for Power Cables up to 10 kV; Correlation of Joint Boxes with Plastic Insulated Cables 0.6/1 kV 1 k$ r# P9 q+ j( ], [( ?
DIN 47600-7-1974 最高可达 10 kV 电力电缆用金属铸造连接盒.第7部分:1.6/1kV 塑料绝缘电缆的内部设计 Cast Metal Joint Boxes for Power Cables up to 10 kV; Internal Design for Plastic Insulated Cables 0.6/1 kV
9 i. H& g8 W9 O/ {5 |2 t* S$ {DIN 11525-1992 园艺用玻璃.园艺用玻璃板和铸造玻璃 Horticultural glass; horticultural sheet glass and horticultural cast glass 6 e$ `9 B7 Y# {: K
DIN 8141-1-1993 ISO米制螺纹.铝铸造合金的过盈配合用粗牙和细牙螺纹.标称直径5mm至16mm.标称尺寸、尺寸公差和极限偏差 ISO-metric screw threads; coarse pitch threads and fine pitch threads for interference fits in aluminium cast alloys; nominal diameter from 5 mm to 16 mm; nominal sizes, tolerances and limits of sizes - u8 D$ d: L% e6 [4 w5 t2 ^
DIN EN 50089-1994 金属外壳充气高压开关设备和控制装置用铸造树脂隔板; 德文版本 EN 50089:1992 Cast resin partitions for metal enclosed gas-filled high voltage switchgear and controlgear; German version EN 50089:1992 4 n1 e. ?* v" s
DIN 8141-2-1993 ISO米制螺纹.铝铸造合金的过盈配合用粗牙和细牙螺纹.标称直径5mm至16mm.内螺纹和外螺纹量规 ISO-metric screw threads; coarse pitch threads and fine pitch threads for interference fits in aluminium cast alloys; nominal diameter from 5 mm to 16 mm; gauges for internal and external threads
% _( r+ O% D) RDIN EN 1369-1997 铸造.磁粉检验 Founding - Magnetic particle inspection; German version EN 1369:1996
3 v9 r9 E. u1 C. J8 j: p9 p- ODIN EN 1370-1997 铸造.用目视比对试样检验表面粗糙度 Founding - Surface roughness inspection by visualtactile comparators; German version EN 1370:1996 ! x, C8 Q- u: ^; G
DIN 1687-1-1998 重金属合金的毛坯铸件.砂模铸造.一般公差及机加工余量.不适用于新设计 Rough castings of heavy metal alloys - Sand mouldings - General tolerances, machining allowances; inactive for new design
( O" }; X# ]* B, Z' s& NDIN 1688-1-1998 轻金属合金的毛坯铸件.砂模铸造.一般公差及机加工余量.不适用于新设计 Rough castings of light metal alloys - Sand mouldings - General tolerances, machining allowances; inactive for new design
& B; @* A" h3 U4 q- G) EDIN EN 1559-1-1997 铸造.交货技术条件.第1部分:总则 Founding - Technical conditions of delivery - Part 1: General; German version EN 1559-1:1997
" v% f' F0 d3 a/ L/ PDIN EN 1560-1997 铸造.铸铁命名制度.材料符号和牌号 Founding - Designation system for cast iron - Material symbols and material numbers; German version EN 1560:1997 3 ]' `" i- D3 e# U) w% B
DIN EN 1371-1-1997 铸造.渗液探伤检验.第1部分:砂型铸件.重力金属铸件.低压金属铸件 Founding - Liquid penetrant inspection - Part 1: Sand, gravity die and low pressure die castings; German version EN 1371-1:1997
9 k3 [) S k& A" }4 u$ dDIN EN 1559-3-1997 铸造.交货技术条件.第3部分:铁铸件附加要求 Founding - Technical conditions of delivery - Part 3: Additional requirements for iron castings; German version EN 1559-3:1997
9 Z" _% h" J) b/ w) w2 ^* O8 HDIN EN 1559-5-1998 铸造.交货技术条件.第5部分:镁合金铸件的附加要求 Founding - Technical conditions of delivery - Part 5: Additional requirements for magnesium alloy castings; German version EN 1559-5:1997
" E0 W$ f$ _) s) lDIN EN 1774-1997 锌和锌合金.铸造用合金.铸块和液体 Zinc and zinc alloys - Alloys for foundry purposes - Ingot and liquid; German version EN 1774:1997 0 h! @' |: U9 z
DIN EN 1371-2-1998 铸造.液体渗透检验.第2部分:精密铸件 Founding - Liquid penetrant inspection - Part 2: Investment castings; German version EN 1371-2:1998 9 k/ _: J: K& ]. u
DIN EN 12454-1998 铸造.表面缺陷的目视检验.钢砂型铸件 Founding - Visual examination of surface discontinuities - Steel sand castings; German version EN 12454:1998
3 j' m! b% n) F' @1 n( @DIN EN 1559-6-1999 铸造.交货技术条件.第6部分:锌合金铸件的附加要求 Founding - Technical conditions of delivery - Part 6: Additional requirements for zinc alloy castings; German version EN 1559-6:1998
. Y4 p" n4 a, xDIN EN 1559-4-1999 铸造.交货技术条件.第4部分:铝合金铸件的附加要求 Founding - Technical conditions of delivery - Part 4: Additional requirements for aluminium alloy castings; German version EN 1559-4:1999 % i' O) V* d. ~ G7 k3 F- B% X% ?
DIN EN 12883-2001 铸造.失蜡铸造工艺用生产失型的设备 Founding - Equipment for the production of lost patterns for the lost wax casting process; German version EN 12883:2000 ( y- K6 k- u9 c
DIN EN 1265-2000 铸造机器和设备用噪声测试法 Noise test code for foundry machines and equipment; German version EN 1265:1999 : ~' p$ ^1 h: M
DIN ISO 4381-2001 滑动轴承.多层滑动轴承用铅锡铸造合金 Plain bearings - Lead and tin casting alloys for multilayer plain bearings (ISO 4381:2000)
6 I T% R. a$ l9 i( A2 JDIN 86021-2002 铜合金铸造法兰.公称压力为10、16、25的法兰设计原则 Cast flanges of copper alloys - Principles of design for nominal pressure 10, 16, 25
! Z1 x, C: R, k4 f: G2 mDIN EN 13195-1-2002 铝和铝合金.船舶应用(海运和近海造船)精制产品和铸造产品.第1部分:规范; 德文版本 EN 13195-1:2002 Aluminium and aluminium alloys - Wrought and cast products for marine applications (shipbuilding, marine and offshore) - Part 1: Specifications; German version EN 13195-1:2002 9 L/ }* U8 Q& S9 L# n% ]& q6 A
DIN EN 1247-2004 铸造机械.戽斗、浇注设备、离心铸造机、连续和半连续铸造机的安全要求 Foundry machinery - Safety requirements for ladles, pouring equipment, centrifugal casting machines, continuous and semi continuous casting machines; German version EN 1247:2004 6 p, k; B* W4 ]$ s% K+ r+ O
DIN EN ISO 580-2005 塑料管和管道系统.喷射铸造热塑性配件.热效应直观评估法 Plastics piping and ducting systems - Injection-moulded thermoplastics fittings - Methods for visually assessing the effects of heating (ISO 580:2005); German version EN ISO 580:2005 , H! C+ ]: @3 t0 w/ L' z
DIN EN ISO 293-2005 塑料.热塑性材料试样的压模铸造 Plastics - Compression moulding of test specimens of thermoplastic materials (ISO 293:2004); German version EN ISO 293:2005 2 e H: D( i/ r: u4 v6 P3 ^" L5 b
DIN EN 1563-2005 铸造.球墨铸铁 Founding - Spheroidal graphite cast irons; German version EN 1563:1997 + A1:2002 + A2:2005 4 F. K9 J; b. I, Y
DIN EN 2732-2005 航空航天系列.镁合金MG-C46001-T6.冷型铸造 Aerospace series - Magnesium alloy MG-C46001-T6 - Chill casting; German and English version EN 2732:2005
# W4 @# B: J# \DIN EN 1564-2006 铸造.奥氏体铸铁 Founding - Austempered ductile cast irons; German version EN 1564:1997 + A1:2006 9 a( \, V3 ?) Q2 x
DIN EN 1562-2006 铸造.可锻铸铁 Founding - Malleable cast irons English version of DIN EN 1562:2006-08 W- Y: m, v: w: V3 w9 |- ] U8 C
DIN EN 13835-2006 铸造.奥氏体铸铁 Founding - Austenitic cast irons; German version EN 13835:2002 + A1:2006
) C. } B6 w* M6 ?; O2 I" x& j, S& CDIN EN 2731-2006 航空航天系列.镁合金钢 MG-C46001-T6.砂型铸造 Aerospace series - Magnesium alloy MG-C46001-T6 - Sand casting; German and English version EN 2731:2005
2 l+ a2 S2 ]. P- SDIN EN 1561-1997 铸造.灰口铸铁 Founding - Grey cast irons; German version EN 1561:1997 6 E4 D, f4 \( Y9 N
DIN EN 12513-2001 铸造.耐磨铸铁 Founding - Abrasion resistant cast irons; German version EN 12513:2000 " d4 i4 c" G; I; G3 X2 _
DIN EN 1248-2002 铸造机械.喷砂设备的安全要求; 德文版本 EN 1248:2001 Foundry machinery - Safety requirements for abrasive blasting equipment; German version EN 1248:2001 : l. j, M' `( d
DIN EN 869-2007 机械安全.金属压力铸造设备安全要求 Safety of machinery - Safety requirements for pressure metal diecasting units; English version of DIN EN 869:2007-02 / n* n T# V( w
DIN EN 4616-2007 航空航天系列.型MG-C18002镁合金.T4.冷型铸造 Aerospace series - Magnesium alloy MG-C18002 - T4 - Chill casting; German and English version EN 4616:2005 " u8 ~& \' {- U' ]# a
DIN EN 4615-2007 航空航天系列.MG-C18002型镁合金.T4.砂型铸造 Aerospace series - Magnesium alloy MG-C18002 - T4 - Sand casting; German and English version EN 4615:2005
( f: r* X. U3 Q+ z* K c$ x0 K/ sDIN EN 3973-2007 航空航天系列.FE-CM3801(X5CrNiCuNb16-4)型钢.均匀分布、溶解处理和沉淀淬火.熔模铸造.D<(指数)e>≤50mm.R< Aerospace series - Steel FE-CM3801 (X5CrNiCuNb16-4) - Homogenized, solution treated and precipitation hardened - Investment casting - D<(Index)e> 50 mm - R<(Index)m> 1030 MPa; German and English version EN 3973:2006 |
