不知道为什么,,8 v3 w2 k! ]" A: R \& K% a
我用的是mastercam9.1sp2版,但是编出来的程序没有圆弧,我用的是2:1的过滤,,可是程序在机床上用时,,机器走的很慢,,这是我现在用的后处理。。7 `) h0 ?! M; ^) F
spaces : 1 #Number of spaces to add between fields
# G2 o# `/ J& y' m) e/ _$ C/ X! Pomitseq : no #Omit sequence numbers?
+ ]! d* E6 ]5 ~seqmax : 9999 #Max. sequence number
4 y0 `, H9 I. Xarcoutput : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 1805 X" b, n. `9 B
arctype : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc./ Y- _) s2 f) J* n( V: a( c
breakarcs : 2 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs6 _( ]+ b, t1 R! c- P; ?
do_full_arc : 1 #Allow full circle output? 0=no, 1=yes
, {7 U) J, f: q5 M4 R5 bhelix_arc : 1 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
" B, R0 N, D% A; v' j) Wcompwarn : 1 #Warn if cutter comp applied on arc, 0=no, 1=yes
" d6 N/ U8 Z3 Xmiscerror : 0 #Error out if Misc Values button is disabled, 0=no, 1=yes & A+ \% a& L {4 `, r: B
maxrad : 999 #Maximum arc radius7 F3 F+ m5 @9 _# }, R5 W0 N
hel_2100 : no #Acramatic 2100 style helical moves, 0=no, 1=yes 8 B4 W9 M' ]. {. q
usecanned : yes #Use canned drilling cycles? Set to no for long output.
. F; a! o4 C- Y: lforce_dpts : no #Force XY output on all drilling lines including cycle call?
1 T1 u/ ]1 q$ o, k5 s- Qhaas_drill : 0 #Haas style peck drill, 0=no, 1=yes
2 P) P. J( j8 h( swcstype : 2 #0 = G92 at start, 1 = G92 at toolchanges, 2 = G54, 3 = Off6 L0 y1 T$ U0 [4 r* v) S
force_wcs : yes #Force WCS output at every toolchange?
+ ^& f! L, c+ A% ustagetool : 0 #0 = Do not pre-stage tools, 1 = Stage tools7 E" L7 G* r- D) c8 E
tool_table : 1 #Tool table, 0=no, 1=yes, 2=Predator VCNC, 3=MetaCut View #
! K N' e! \6 T0 Soutput_z : yes #Output Z Min and Z Max values (yes or no)( t8 X6 s3 P; \' X: i
cool_zmove : yes #Coolant off with last move
% p; f& d9 C0 e1 Ruse_pitch : 0 #0 = Use feed for tapping, 1 = Use pitch for tapping* X. }# G7 I ^' x6 v2 y
tap_feed : 0 #0 = 2/1 (in/mm) decimal places, 1 = 4/3 (in/mm) decimal places; s3 g2 l K/ z' O- ]4 y- \
maxfeedpm : 500 #Limit for feed in inch/min
' [5 t$ A7 A' e8 Pmaxfeedpm_m : 10000 #Limit for feed in mm/min
% r( R& N$ ]0 x* U. nuse_gear : 0 #Output gear selection code, 0=no, 1=yes
! B; O* _* I' \) \max_speed : 10000 #Maximum spindle speed
. Q, \, T% h: l1 S( Amin_speed : 50 #Minimum spindle speed
: X$ m* L8 M. w. msextnc .NC #NC extension override
* l; [- |& E/ h5 c8 U9 wvmc : 1 #0 = Horizontal Machine, 1 = Vertical Mill
5 n4 X3 C, {: K8 A/ _, urot_on_x : 0 #Default Rotary Axis Orientation, See ques. 164.4 y! |$ K5 e0 Y7 Z% w
#0 = Off, 1 = About X, 2 = About Y, 3 = About Z " z& Y; F4 t* S' y# }
rot_ccw_pos : 1 #Axis signed dir, 0 = CW positive, 1 = CCW positive% p6 e& M! z+ f* O) h
ret_on_indx : 1 #Machine home retract on rotary index moves, (0 = no, 1 = yes)4 d" F \) K O6 @* t
index : 0 #Use index positioning, 0 = Full Rotary, 1 = Index only' ?# j7 J8 z0 R6 b% E d1 S
ctable : 5 #Degrees for each index step with indexing spindle
( i; s3 G3 R5 ]- i& A) Qone_rev : 0 #Limit rotary indexing between 0 and 360? (0 = No, 1 = Yes)0 K2 f9 E6 E! H; Q
lock_codes : 0 #Use rotary axis unlock/lock M-Codes? (0 = No, 1 = Yes)+ q! a$ ? H& a2 d' R
use_frinv : 0 #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)+ {; a$ _4 ]0 ~7 `
maxfrdeg : 2000 #Limit for feed in deg/min
$ `( E& {. }9 I9 o( v) Nmaxfrinv : 999.99#Limit for feed inverse time2 [9 o* Y6 V' T
frc_cinit : 1 #Force C axis reset at toolchange" r8 h' \6 Q9 y; ~5 |
ctol : 225 #Tolerance in deg. before rev flag changes) k Z+ E0 x# L
ixtol : .01 #Tolerance in deg. for index error
5 m* x! Z6 a5 Dfrdegstp : 10 #Step limit for rotary feed in deg/min |
