发表于 2008-11-12 21:40:34
来自: 中国上海
原帖由 freeshaw1 于 2008-11-12 11:57 发表 http://www.3dportal.cn/discuz/images/common/back.gif
6 H. @ \1 H9 R* X6 f9 Y( f0 O3 W7 D& ^8 _% s, t
. p8 [, Y7 R, m版主回答不对,UPVC的U是UNPLASTIZED的缩写,未增塑的意思,通常UPVC或者PVC-U都翻译成硬聚氯乙烯,与加大量增塑剂的软PVC相对应.
0 g7 n! P# U" y }" R* e: E, c6 u5 i/ e
另,交联的英文词是 cross-link, 不是USA中的UNITED.
1 |, K* F6 j" r2 B/ l# _( ^8 N' R* I1 N( J! s5 k
请参考下列标准:2 p0 h/ J% y& p6 U2 _# S
ASTM F2080-2006 Standard Specification for Cold-Expansion Fittings With Metal Compression-Sleeves for Cross-Linked Polyethylene (PEX) Pipe, A; V; A+ _7 Q% P6 g! g' Y- e
7 p$ G5 s$ ?' |$ OISO 4422-3-1996 Pipes and fittings made of unplasticized poly(vinyl chloride) (PVC-U) for water supply -- Specifications -- Part 3: Fittings and joints
4 W; E$ K* n1 u3 s6 }4 ]1 ?
8 k/ H; n7 D$ G4 {, b/ {; XBS 3505:1986 Specification for unplasticized polyvinyl chloride (PVC-U) pressure pipes for cold potable water
1 }) K/ U' d2 w/ v9 y( Z, J: p7 [! W. G: A* c# b
ISO 21138 :2007 Plastics piping systems for non-pressure underground drainage and sewerage -- Structured-wall piping systems of unplasticized poly(vinyl chloride) (PVC-U), polypropylene (PP) and polyethylene (PE) " Y# G3 t) e: K& }$ x) g! r, f
' d M* o( Y0 U+ _交联聚氯乙烯的缩写是XLPVC, 版主可以以此为关键词搜索的. |
