发表于 2008-11-18 13:35:06
来自: 中国上海
打开13安装文件,把Crack的ID,序号安装过程中填上去,/ ]: b1 I+ c. Q0 {$ @! P
最后安装CIM12/CRACK/iso-cit13i.exeCrack文件安装上就OK了. S' M' C. D! e% }9 b# o
& B* x* l1 X- A, u
Cimatron It v13.0
7 {( `: u [& W2 g* U ------------------ G2 \ i7 U2 }. q
7 `: O' V* e: W# [
- run cimatron it v13.0 installer, choose complete install. * F$ x9 g' p- }9 O9 k# c
- during installation enter providen plug id and key codes.
9 h# I0 R% A' X8 T2 G5 k3 [% ^* y - note: we've encountered some strange issues with installer, so if installer is crashing for, U) s n) R. r' w5 I
you, do not enter real key codes (just type smth else and press next), after you done with& |' W& A6 G8 c/ Z1 D
installation run 'bin\updatereg_it.exe' and now enter real key codes.
4 z* g7 } ]3 y, Q( G. ? - if you wanna install cimatron quickconcept v2.2.1, do it now. {* \$ ]- S# H9 `
- after it's done, run 'iso-cit13i.exe', choose components you want to be patched and
1 ]) y3 \" B/ h point to destination locations of every component.& ?* \) F# o/ h! H
- note: we didn't cracked magics stl and cimarender pro since they aren't integral part of
1 I: O9 s1 A- `0 o' `+ `0 { the cimatron it v13.0 (just third party addons).$ g% C! c' H% i1 h. A
- that's all!
% R9 |% H) k6 ?: M4 I
1 M% r6 a+ G! E% W9 A n7 F0 K = plug id: 5791 (注意就是这个ID)$ ~- |1 s* ?' \& d' Z* Y1 v+ {
= key code: 42290,53157,5827421,1372587,1372579,5002109,31341,31333,5781637,1315306,1315298,4983933 (接是这个序列号)/ B4 y) R, L0 H9 W7 f9 U7 n& [
= catia key code: 40bd 26ad af2b 8983 740c 4465 c39e b0df: t1 o7 C$ q, O8 n5 }5 O
= ug key code: 30af 9c69 45df 07a0 e218 3ae1 ea40 9eb9& S9 ?0 W5 f5 E# o* v
= re_enge key code: 5fde% z) n9 A2 |# h( s* K
- A) ~8 ~$ o4 S# G
e!l |
