1.刀口型直尺:knife straigjht edge! d2 r' ^; h6 `
2.刀口尺: knife straigjht edge* B: [! b4 U3 B9 [# K6 S
3.三棱尺three edges straigjht edge4 q7 ~2 M% f/ D9 o9 e
4.四棱尺four edges straigjht edge# V! x# g5 l i# Y+ y
5.条式和框式水平仪 bar form and square levels# F9 z% d5 i$ j0 T [$ A* ~
6.合像水平仪 imaging level meter/ T1 |: b! v7 { l( T, l0 p# f7 n
7铸铁平板 cast iron surface plate& |/ W f5 |+ t/ U. v
8.岩石平板 granite surface plate
2 [7 h/ ?& X+ `- K: N6 x# C) r' Y9.铸铁平尺cast iron straigjht edge
3 k. `9 o7 e0 s& F& n+ d5 m10.钢平尺和岩石平尺 steel and granite straigjht edge
3 z& ~2 \1 x1 [, z* E9 V11.圆度仪 roundness measuring instrument
# W0 t0 k s: F+ {12.电子水平仪electronic level meter
5 \8 z# P6 G" `# W13.表面粗糙度比较样块铸造表面 roughness comparison specimens cast surface
0 S: X9 g/ T2 r: S; F0 [" n& Z14.表面粗糙度比较样块磨、车、铣、插及刨加工表面
6 C8 N& s5 K8 [) i1 k/ R7 q/ P$ f& {roughness comparison specimens-ground,turned,bored,milled,shape and planed5 p/ o4 R! I! y6 G) j
15.表面粗糙度比较样块电火花加工表面" [' S! [) F- |' `
roughness comparison specimens spark-erostion machining surfaces
2 a" m2 {! R. o16.表面粗糙度比较样块抛光加工表面
# Y1 ~1 Y8 _6 n7 [- C, T4 }roughness comparison specimens pollshed surfaces
+ a: G5 B' q7 G2 W17.接触式仪器的标称特性" g6 ?9 J) G) t+ d! Z
18.轮廓profiles
& V% g9 l1 a" }0 X19.轨迹轮廓 traced profile- u& c. T7 ~& J
20.基准轮廓 reference profile
' ]6 _4 H1 O; T2 J, L5 Z% g3 D' h3 y21.总轮廓 total profile- P% p+ L6 X ~6 ^. {7 u7 T) z- X
22.原始轮廓 primary profile
- s) O5 g* P, _23.残余轮廓residual profile
* A3 k7 G( b! ?6 s3 A3 A$ d! q8 F24.触针式仪器stylus instrument7 @6 ~% a7 D1 p; k
25.感应位移数字存储触针式量仪displacement sensitive,digitally storing stylus instrument1 x' \" X# h1 Q, x
26.触针式仪器的部件stylus instrument components( U. [1 U2 h0 J# t( [& x
27.测量环measurement loop; c4 L8 Z: t" E. |4 K1 g
28.导向基准renfence guide/ i0 a, w' o6 l- u
29.驱动器drive unit! ]/ z' X" X2 l6 }8 j7 q2 `& ~+ M( l9 V9 d
30.测头(传感器)probe(pick-up)
3 }7 {; j4 `; E3 R31.拾取单元tracing element$ `: x7 V U' M7 `4 R% V# w: @, e
32.针尖stylus tip( c, S3 l( U- k5 t* M) i8 d f7 m
33.转换器transducer& c k' h8 I' Z. s- w5 e3 h% u
34.放大器amplifier# O+ t0 F4 J2 i
35.模/数转换器analog-to-digital converter
2 @' L X+ w: L. G36.数据输入data input
; ~% Y) {# l0 b37.数据输出data output
. @& b0 T8 s! l7 I4 ]5 v/ _ a38.轮廓滤波和评定profile filtering and evaluation
# a9 j/ ~( A+ ~7 Y3 \% O) {8 A39.轮廓记录器profile recorder
* {( U/ ?8 p( R6 A* d4 ^" V' I40.仪器的计量特性metrological characteristics of the instrument
( N M* l0 g2 o2 o% y* |; M41.静测力的变化change of static measuring force: v& [$ d1 U% K3 M
42.静态测力 static measuring force* |" d( t/ V- {) M
43.动态测量力 dynamic measuring force
6 i% H, ]( D+ e- q0 \8 N44.滞后hysteresis
7 N; |9 I9 j; J45.测头的测量范围 transmission function for the sine waves9 q* z7 g. g) X5 X. `1 P4 w( Y
46.仪器的测量范围measuring range of the instrument
1 y5 _/ `* U2 R1 u- m0 {5 {6 ^# R47.模数转换器的量化步距quantization step of the ADC
- B+ w, V6 r' n2 F48.仪器分辨力 instrument resolution+ e- _! Z/ X' z9 T6 Q; u0 F0 k8 {
49.量程分辨力比range-to-resolution ratio9 X& ?- e( W- ?5 Q
50.测头线性偏差probe linearity deviation2 K5 H# n* f7 v! Q
51.短波传输界限short-wave transmission limitation0 b4 _ S! Q* A+ ?
52.轮廓垂直成分传输 vertical profile component transmission1; Q; B" C2 {# g& q1 A( z0 G
53表面粗糙度比较样块抛丸、喷砂加工表面
2 Z% `) q! A' S* i7 e, J3 \roughness comparison specimens shot blasted and blasted surfaces3 d( Q: u' c1 U! n: _
54产品结构几何量计术规范(GPS)geometrical product specifications(GPS)
% E: ~6 f' F |3 ~7 O X55表面结构 surface texture" w! e1 r& {3 Y: c3 r% t
56接触式仪器的标称特性 nominal characteristics of contact instruments
$ t7 }* i0 z" B57公法线千分尺micrometer for mearsuring root tangent lenghths of gear teeth& U6 q' I% I G' }1 E
58最大允许误差 maximum permissible error
% K/ ]) o0 d( t- H* Z) D59圆柱直齿渐开线花键量规 gauges for straight cylindrical involute splines" w& N- A; ^, E
60齿厚游标卡尺 Gear tooth vernier
% `2 g9 w2 I# f: J6 gcalipers
% H9 E: c3 H9 ?) h- W2 `61齿轮渐开线样板the involute master of gear
. V# j% H9 {# r( s' f9 Y& E+ ^7 o62齿轮螺旋线样板 the helix master of gear
. s( X* M3 K' w9 `" e2 M63矩形花键量规 gauges for straight –sided splines. g9 ~+ K$ i0 a: _" R9 g p& z
64测量蜗杆 master worm3 o/ n( U' m% i' h* F, w+ a+ C
65万能测齿仪 universal gear measuring instrument: |, S0 e9 B! n
66万能渐开线检查仪universal involute measuring instrument
) r& N% B; z2 v1 H67齿轮齿距测量仪gear circular pictch measuring instrument) Q- h3 F; `1 Z6 M. q8 l$ s) W9 Q
68万能齿轮测量机 Universal gear measuring machine
, I, w! s- S* I7 T' L& ~69齿轮螺旋线测量仪gear helix measuring instrument
7 Z# I5 i+ S3 I0 L% p( A. \70便携式齿轮齿距测量仪 manual gear circular pitch measuring instrument3 x3 H- B4 E3 }) p- M& u, M; b S
71便携式齿轮基节测量仪manual gear base pitch measuring instrument: G; s$ `$ d7 n/ Z$ a
72立式滚刀测量仪vertical hob measuring instrument0 ^1 b" \% k+ C) b' b# `
73齿轮双面啮合综合测量仪Gear dual-flank measuring instrument. @! d+ V2 n0 Y3 y, M" y
74齿轮单面啮合整体误差测量仪Gear single-flank meshing integrated error measuring instrument
& d4 d+ ~7 _0 \3 `75梯形螺纹量规 gauges for metric trapezoidal screw threads $ S7 y5 F6 O& {1 }2 X/ `0 l
76工作螺纹量规work gauges for metric trapezoidal screw threads : P( X" m2 ]3 V; g
77校对螺纹量规check gauges for metric trapezoidal screw threads% {" m' q0 x* `3 e1 ~7 G) y
# O. r" [2 q: ~
78.梯形螺纹量规型式与尺寸 Types and dimensions of metric trapezoidal screw threads5 W; q5 P! S1 Z- `
79.普通螺纹量规型式与尺寸 Types and dimensions of gauges purpose screw threads
% B: s6 ~" R! j% O6 J, N80.非螺纹密封的管螺纹量规 Gauges for pipe threads prcessure-tight joints are not made on the threads
6 |" Z: F' F" N% \81.螺纹千分尺% |. A( _. R$ c# p! n
Screw thread micrometer/ Z4 W9 f9 A. Y% }
82.最大允许误差 maximum permissible error
! u: t/ y: [' e0 P$ H) S: Q4 `4 B83.间隙螺纹量规 Clearance screw gauge% L- J, x: [$ p
84.量针2 Y( R, i& O5 U' P f% `2 v* |" d
Bar gauge
- Z3 \' u5 n7 _4 K85.螺纹样板 Screw thread template
6 h! s( Z$ ^) O0 y# A+ `86.用螺纹密封的管螺纹量规
! C) a+ M/ h) WGauges for pipe threads where pressure-tight joints are made on the threads+ m% d# e/ s' }, l0 L
87.刀具预调测量仪 精度
& N) x6 f0 _) f& g; d4 H2 nAccuracy of the presetting instrument2 d7 s/ G- f3 W: K! \9 n
88.薄膜式气动量仪 H: @! c1 \) F0 {7 S: r
Membrane type pneumatic measuring instrument a7 ~( \0 Y- \( ?
89.光栅线位移测量系统
3 ?) x3 e7 s3 M6 l/ p( }Grating linear displacement measuring system& d, `) |7 B. x8 g& E7 T: G5 D' h, e
90.光栅角位移测量系统9 q9 m6 I# L1 f4 X5 ^
Grating angular displacement measuring system7 `: i+ t6 s1 A1 n/ p [# T* x
91.磁栅线位移测量系统- \/ _5 _, S& P' S
Magnet-grid linear displacement measuring system& l* X4 X. y0 P( M6 A; ~
92.量块附件
+ T0 ^, ]$ ?7 L }Accessories for gauge blocks# y% q( y3 b5 Z1 N2 z1 h
93.V形架% _0 o* I2 z5 @: i
Vee blocks
- v$ X2 P* O' K9 C- {7 A* V7 h [94.比较仪座
8 e; t: Z. x- D$ n0 _. d8 s& aComparator stand
# {" _5 j O+ y6 q+ Q95.磁性表座
' Z/ Y9 ~5 ] N- F, S' KMagnetic stand4 p0 l3 T" R. W+ `& X' k+ x
96.万能表座- u5 C3 N3 G7 F- ?& }" [
Universal stand for dial indicator |
