查看: 1399|回复: 1
[讨论] SW2009怎么立刻出了这个Service Pack 1.0 Early Visibility
发表于 2008-10-30 19:42:19 | 显示全部楼层 |阅读模式 来自: 中国北京
这么快啊,就有sp1.0(EV)了。网页上看到的sp1.0说明
+ k, ?3 C) S& a- f7 W2 _" Z) M1 l  U1 u6 s( }, Q
Service Pack 1.0
& F5 h( s3 J4 _: a! k$ W) sExport to 3D XMLSave As 3D XML saves the file to the V4.2 specification of 3D XML.
+ b% t: z- ]! ]+ C; dRouting - Ribbon CablesYou can create folded ribbon cable routes. You can define ribbon cables from the cable/wire library, use the Auto Route PropertyManager to specify the path, and add ribbon cable connection points to connectors using the Connection Point PropertyManager.
+ x) ^# \8 {( yFeaturesThe "Solid Sweep Cuts" section of the What's New book mentions the ability to create a solid sweep cut along a non-tangent path. This feature is not supported in this release.3 c5 S8 l, P2 }# ^% X% C' I
9 |; ~( M+ P0 M% g0 P0 \/ OService Pack 1.0
# o" i$ M2 f, S3 r! n6 d9 T输出到 3D XML保存为 3D XML 会将文件保存到 3D XML 的 V4.2 规格。. z/ J# M! Z$ H/ W8 P3 D( m( u
Routing - 带状电缆您可以生成折叠的带状电缆线路。您可从电缆/电线库定义带状电缆,使用自动步路 PropertyManager 指派路径,然后使用连接点 PropertyManager 将带状电缆连接点添加到接头。
0 P* x$ y+ Z9 T* h8 Z. L2 M. z+ c+ Y! @" n- l
[ 本帖最后由 a1s1 于 2008-10-30 19:44 编辑 ]
发表于 2008-10-30 22:34:31 | 显示全部楼层 来自: 中国广西桂林
早点出SP1吧,SP0还是有不少问题
