发表于 2008-11-22 12:47:48
|阅读模式
来自: 中国黑龙江哈尔滨
30CrMnSiNi2A 钢壳体毛坯的温挤压成形工艺研究
) X/ i; n& s" G* ?伍太宾 , 周强
+ a- y9 Y, \; {* I8 @(重庆工商大学 机械与包装工程学院 ,重庆 400067)+ g" Y2 y' u$ Q. u2 {
[摘要] 针对 30CrMnSiNi2A超高强度钢制壳体毛坯的结构特点和材料工艺特性 ,对该壳体毛坯的温挤压成形工艺进行了大量的试验研究;并采用“正交试验方法”对温挤压工艺参数进行了优化设计。经过理化检测和使用结果表明 ,采用温挤压工艺生产的 30CrMnSiNi2A钢制壳体毛坯锻件完全满足壳体的使用要求 ,各项性能指标合格。
, ?8 n8 o9 k+ {! L. [1 }[关键词] 30CrMnSiNi2A; 温挤压; 壳体; 毛坯
7 |0 n# j0 B! G" f中图分类号:TG376.2 文献标识码:B 文章编号:1000 - 8446(2004)01 - 0011 - 03
/ s& H4 D, s7 d% E, E* u* CStudy on the Warm Extrusion of Shell Body Blank Made by 30CrMnSiNi2A
. @# J# h" V$ U |7 P& h4 LWU Tai2bin , ZHOU Qiang( f0 K" q# d. ~6 o9 ^, x( m5 X; ^
(Chongqing Technology and Business University,Chongqing 400067 ,China)
5 L+ l7 x, v+ y' U( }/ w: k5 h5 tAbstract: In view of the construction feature of shell body blank made by 30CrMnSiNi2A and the) a6 A* F4 M k$ T, u
specificproperty of material ,the experiments are performed to investigate the warm extrusion of shell) h' e! P! X8 A/ T* J0 \
body blank;and theoptimized designof major processparameters arefinished by meansof ”experimental2$ B3 a# z, i! o% x" D
orthogonal method”。The experimented results show that the forging of shell body manufactured by
1 r' b% o- ~# j0 g7 zwarm extrusion fulfil quality requirements,and each of property target is up to standard。1 ^7 l( L# [+ C) T
Key words: 30CrMnSiNi2A;warm extrusion;shell body ;blank |
