查看: 3136|回复: 14
[求助] Solid_User: CIMCO HSM crack not working anymore
发表于 2008-12-17 00:37:08 | 显示全部楼层 |阅读模式 来自: 伊朗
Hi,: n& n7 C  x: ?6 Q8 `
8 d0 d  w3 O* q) M2 }* b
I just downloaded HSM v3.0.51.14634 applied your cr@ck, it modified the hsm.dll but the; |- U: w8 b2 ~! r5 r0 z' U
HSM module shows error about floating operation and the menu doesn't come up.
8 p& V2 q- m8 d3 f+ Z, V' [0 Q9 m
1 C% C) T- e! |, i/ W7 n6 cIs there a newer cr@ck? I used hsm_for_mc_v3.x.x.x_crk
发表于 2008-12-17 04:52:48 | 显示全部楼层 来自: 中国广东深圳
我的可以Crack啊。。 hsm_for_mc_v3.x.x.x_crk.rar (14.71 KB, 下载次数: 84)
发表于 2008-12-17 04:59:16 | 显示全部楼层 来自: 中国广东深圳
啊啊的.jpg 你哪里有问题啊,,贴图片好吗?
发表于 2008-12-17 08:59:59 | 显示全部楼层 来自: 中国江苏盐城
1楼的,我也是用的这个版本的,X3MU1上都是可以用的啊,老大的那个CRACK是可以在5.1上用的
0 G8 n& J6 E. A我就安装了,你能够来个你的图形文件给大家测试侃侃看?
 楼主| 发表于 2008-12-17 10:15:42 | 显示全部楼层 来自: 伊朗
The crack doesn't work for me under X3MU1.
 楼主| 发表于 2008-12-17 11:00:09 | 显示全部楼层 来自: 伊朗
The system shows me this message
 楼主| 发表于 2008-12-22 16:22:23 | 显示全部楼层 来自: 伊朗
Any solution please?
发表于 2008-12-23 02:07:04 | 显示全部楼层 来自: 中国台湾
到底可不可以在X3MU1上使用?
发表于 2008-12-23 21:06:16 | 显示全部楼层 来自: LAN
原帖由 ccuappz 于 2008-12-17 11:00 发表 http://www.3dportal.cn/discuz/images/common/back.gif
+ g) m: m( W; \The system shows me this message
6 i$ `! f5 l5 V2 @% F# X
I did not find any problems.. Crack works,  HSM v3.0.51.14634  works too...Suppose it's you own problem (may be not correct initial parameters) ! |: Y  L* L/ w: l) K% Q5 E2 g" ~+ y
/ `8 r- h4 F" K( w3 F/ f, ~[ 本帖最后由 solid_user 于 2008-12-23 21:36 编辑 ]
 楼主| 发表于 2008-12-31 07:46:34 | 显示全部楼层 来自: 伊朗
Thanks solid_user,
* z8 k3 f0 O2 B5 I" U; {. F* |I installed this application on several newer machines (Intel dual cores/xpsp3/MCX3-MU1) with success   , but one old machine (AMD 2400/xpsp3/MCX3-MU1) refuses to run the application with the above error message for all fininshing and roughing operations." j( |" K- o$ w3 b5 d
I tried installing/uninstalling Mastercam x3/mu1 as well as Cimco-HSM with no success.
, x$ f2 T5 V7 E5 z' {& d- P5 aThanks again9 [/ b6 ?% ]2 E1 W( c- N
, @9 W' X( h) x- N  C) kPS. should I run the c-hook everytime I need to use HSM? Is it normal?+ |  E3 w1 ?1 x( J% H( e" F/ k# |
Shouldn't it add new HSM menu items in the list of Mastercam's own machining operations when I right-click on Operation Manager panel??
 楼主| 发表于 2009-1-26 09:56:09 | 显示全部楼层 来自: 伊朗
I had no success running HSM on this system.$ G+ f& I: s+ D0 Z: Z  Z' c& @6 |
I just installed v3.0.53.15030 and here's the result.
* p8 P- t1 Y: \4 P: E, d2 S3 h- H( U2 b- \- z; d+ B. Q6 D: x4 M
I tried exporting geometry as STL and used it as "Geometry Source" in a parallel finish Operation.; `4 y; V: C5 I+ I& l
. }4 {6 T- D0 H, nHere's the system message.3 |8 K) e# M7 y, v+ F
' n3 |8 ^- `% M5 JInformation: Initializing parallel finishing strategy3 U& b5 @. ]8 H3 M
Information: Ignoring associated geometry due to explicitly selected stereolithography source.4 T- J! l! [$ a% W( Y- G3 n, A1 x
Information: Using external stereolithography file:///D:/U/GEOM.STL (4.9Mb).
2 D) l5 b' T8 \8 Y
Error: Floating-point operation on denormalized operand at address 0x0b9c886d.) Z3 r+ z- B: m2 [
. z3 X, M7 `; o: m
8 L0 W. F" M, r& [Maybe the cr@ck only works for dual core systems??5 J/ ^8 N6 I, |) e3 j+ X( h
6 V; Y4 ?8 V0 r; |! x( P, JOn other dual core systems it works fine. : t- C. }2 T" P( g
Any help will be much appreciated.
7 W+ T) J( w. C$ i1 W% S7 y; q* W  m% ]
[ 本帖最后由 ccuappz 于 2009-1-26 09:59 编辑 ]
 楼主| 发表于 2009-1-26 10:06:47 | 显示全部楼层 来自: 伊朗
Besides when I select VERIFY from CIMCO HSM Performance Pack menu.% ~7 b# W% E/ b  N* R! o4 v
It shows me this message." t8 L: _6 E; S* N8 f2 Q  H' V
The error occurs with both operations. The first one is a builtin Mastercam operation (Blend).
! y$ M7 H1 P3 \& e1 YThe second is the failed HSM parallel fininsh.6 d, L" D: D* z
% L/ P$ v% E7 Q, ]# C3 L" d
[ 本帖最后由 ccuappz 于 2009-1-26 10:08 编辑 ]
发表于 2009-1-29 21:09:37 | 显示全部楼层 来自: 中国江苏盐城
)19*( 告诉你另外一个原因就是HSM必须和网络北京时间对应,否则无法工作
发表于 2009-4-20 14:52:07 | 显示全部楼层 来自: 中国广东东莞
找了好久,看看是否能用
发表于 2009-6-2 15:09:40 | 显示全部楼层 来自: 中国重庆
我的老是报错
