2021-06-25
查看: 5241|回复: 8
[讨论] proe3.0提示由于格式错误而未能加载受限制参数的外部文件,如何解决?
发表于 2008-12-17 23:04:51 | 显示全部楼层 |阅读模式 来自: 中国广东深圳
我写了一个名为Restricted_parameter.lst的文件,但是运行proe3.0的时候却提示格式错误,不能载入,请教高手如何解决!内容如下:
9 e/ i- D4 N1 q2 tND_ParamDefArr_K01 = {
% G. s) `) F+ u" j$ Q' z4 f" o{ Name=MATERIAL) D9 u- `( Z' ~( m
   Type=string9 c) V8 c3 O/ f. w7 z
   Default='S45C'
$ M9 C! S5 @1 k  j6 `" |1 h& F$ l8 V+ wEnum={'S45C','P20','SKD11','SKD61','A3','SUJ2','YK30','65Mn','60SiMn2','AL6061','AL5052','ASP23','SLD','Cr12MoV','SUS304','优力胶','铁氟龙','电木','塑钢','其它','-'}
- I' S/ g2 L. \$ C" S2 V, A},6 I7 ~5 d0 \% Y- p% t
{ Name=FINISHED- F- `3 s1 F) ~# t! U$ G% t
   Type=string
  @9 u. V* M7 C  p   Default='NONE'
- Z) K1 P; h% ?- }   Enum={'NONE','HRC45','HRC45~50','HRC50~55','HRC55~60','HRC60~65','调质','其它','-'}$ V9 M8 n9 S5 L8 Z9 Z* c4 P7 K! Q
},% Q, s: o3 v0 B1 P1 |9 V3 |& i# e
{ Name=PART_TYPE  ~2 p( T  V6 R; ~8 J
   Type=string
9 o2 g# o/ M9 t! v   Default='加工件'6 A6 M5 S  _6 F( {( \
   Enum={'加工件','外购标准件','其它','-'}
: u+ n4 l! H! }1 }4 q7 U},
0 h" k7 q6 m8 X{ Name=螺丝大小
8 z3 Q; ]6 L, F  [+ \3 r0 d: d   Type=string0 e0 |# L! B" [: t
   Default='M6'- `5 U0 N2 k# G  [3 {! P
   Enum={'M2','M2.5','M3','M4','M5','M6','M8','M10','M12','M14','M16','M20'}
4 {/ Q' d: j) {$ d5 H. N5 {. R; v# r}: q' i5 L3 G& M6 \9 A
发表于 2008-12-18 21:46:34 | 显示全部楼层 来自: 中国江苏南京
逗号错了,帮你该了,再试试
, e( k. q8 d) S2 M  Y, MND_ParamDefArr_K01 = {
' L$ @) A* H3 q( Y% e0 E{ Name=MATERIAL
5 v; b' {& w' r   Type=string
" ]6 e: i3 y+ L$ o: T   Default='S45C'
8 e7 O5 H' F) D' ~- vEnum= {'S45C','P20','SKD11','SKD61','A3','SUJ2','YK30','65Mn','60SiMn2','AL6061','AL5052','ASP23','SLD','Cr12MoV','SUS304',' 优力胶','铁氟龙','电木','塑钢','其它','-'}
  p8 q0 A7 D/ P( e3 ^' X/ V},
6 P# e% N" V) W  |3 u5 s) `# N" t9 P{ Name=FINISHED
9 e6 s2 Z, p% x' U   Type=string5 \6 R' y5 P  a: X5 d3 Y/ q
   Default='NONE'
- _  P: f' B$ N2 B2 W% ~3 \) y0 }   Enum={'NONE','HRC45','HRC45~50','HRC50~55','HRC55~60','HRC60~65','调质','其它','-'}1 q% b6 Q: W) t1 o  j
},* `  i! i( Y0 H' k
{ Name=PART_TYPE
- }' v5 ~/ V5 e' v& `8 G   Type=string" A  }3 o9 K4 }+ ?% O
   Default='加工件'( Z5 J( s- @. x9 @2 Z2 O  }& w) i
+ C4 U( c. D! t},8 Z$ e& H2 @& Z- i5 l2 x
{ Name=螺丝大小
7 N  L6 b7 C4 h2 c# `   Type=string) s3 R: l. `2 M$ b
   Default='M6'! Z1 V  h! ^4 S" ?# X
5 x( M, U& t* C- {  j, s+ f* Z}/ Q; {7 w# O& I3 k. b+ G' D
 楼主| 发表于 2008-12-19 23:30:37 | 显示全部楼层 来自: 中国广东深圳
问题已解决,谢谢版主! 另外还请教一个问题:在proe的这些文件中标点符号应该用那种,半角还是全角,在英文状态下输入,还是在中文状态下输入?
发表于 2008-12-19 23:51:54 | 显示全部楼层 来自: 中国江苏南京
我印象中,全角的标点符号除了句号都不可以,要换成半角,在英文状态下输入
" m  G1 s. i! X1 b5 s4 |还有,在中文状态下也可以输入半角符号的
发表于 2010-9-30 14:39:35 | 显示全部楼层 来自: 美国
2# jasoworld
& G( T" u6 G- A7 f8 p: {4 R, q% q5 i* u2 a! w/ F1 a& L* h
我是4.0的,为何在配置文件中也指定了该文件,但在参数表中不能使用。能给个详细描述吗?谢谢!
发表于 2010-9-30 17:14:49 | 显示全部楼层 来自: 中国河北石家庄
这个比较深奥  还没有学到这一步
发表于 2010-10-14 22:07:13 | 显示全部楼层 来自: 中国江苏徐州
删掉老的,新的才会出现
发表于 2011-6-24 08:17:51 | 显示全部楼层 来自: 中国福建泉州
请问楼主,parameter.lst中的汉字只能保存为非ANSI格式,那么在打开PROE时就读取不了文件,请问你是怎么解决这个问题的?
发表于 2013-5-7 09:03:32 | 显示全部楼层 来自: 中国广东深圳
我曾用过这种文件,但后来发现还不如自由填写来得好一些。但不知如何消除受限参数了。怎么办?如何操作?
