HYDROGEN EMBRITTLEMENT RELIEF
, S3 u1 ]3 f0 @0 Z& \氢脆的预防方法
2 \- I$ I$ t( Z. X9 M9 @
& b( y0 B/ r. j+ o% @6 }, v# |
8 m/ a5 P" l, ]& `: b( d; t) rDAIMLERCHRYSLER CORPORATION, N& w( L# j7 q% e
标准号:PS-9500<S>
4 G6 l/ @8 T6 p" ^. T0 q. n戴姆勒·克莱斯勒有限公司
4 a2 ?) _7 H; d* I+ ?+ uProcess Standard3 X4 M& k9 `) Z) n9 x6 h8 k4 m5 K4 [
* A2 Y* |$ [& t作业标准
( D; {! w0 s1 B9 X/ @- S2 ~% R! q$ B, ]& U
! Y0 q& U# w! f
出版日期:2002.01.14 : T! T- b9 ^1 M* m
& z7 o" r4 J& c4 @/ W# O; H$ n
* R9 M6 T' o' q- h
: ~7 [! p$ a- V+ F7 L/ X: p+ R, w1 / P( z D6 @& s, V2 o7 m
GENERAL 综述 ) L7 c! l4 v: {8 p; n4 ~
+ D0 S% F/ I: E: g( J
1.1
3 q. ~( j% m8 m* O' y5 xPurpose of the Standard 适用范围 # S6 E5 D2 H4 I& j( u& k$ B/ t
This standard outlines the procedures and requirements for preventing hydrogen embrittlement in high-strength steel parts. High strength steel fasteners are covered by this standard but nuts are excluded. Hydrogen embrittlement can be caused by acid cleaning, phosphating or electroplating, because of hydrogen absorption, and lack of relief before tensile stresses are applied to the material. This standard is commensurate with SAE/USCAR-5 with the exception of the hardness value cut offs where a specific procedure such as a holding period or a heat treatment is required. Where these standards differ, the specific requirements in this standard take precedence over SAE/USCAR-5.
: r) f3 z. Z' R7 w9 B) P本标准规定了高强度钢制零件的氢脆预防的方法和要求。本标准适用于除螺母以外的高强度紧固件。经过酸洗、磷化或电镀等表面处理的钢制零件,在受到拉伸应力之前如未采取防治措施,将会因吸收氢原子而引起脆断。本标准与SAE/USCAR-5标准原则上基本相同,但决定是否采取放置释放或是否进行烘烤处理方法的硬度值有所不同。本标准与SAE/USCAR-5标准部分内容不一致时,本标准中的规定的要求高于SAE/USCAR-5
1 f# f3 Z( h" U0 w! ~9 A标准。 ; N) c% e8 `0 k6 F$ s! O1 t
, K; M( y( f0 q$ E9 n) x1.2
. m4 k) q! [! b; s9 k+ NPurpose of the Process 主题内容 4 W% U: L. x9 O
2 i9 L- R( r9 b. {This standard presents the process for preventing hydrogen embrittlement in high-strength steel.
. D6 N$ O. l7 j3 a' M0 e# H4 ` }本标准介绍了高强度钢制紧固件的氢脆防治的方法。
$ y5 F. F, T- _7 {* K4 V! x/ T) \: l' _& \3 Y9 E" G
2
/ F# t. |% b. P+ \. k: aPROCESS 处理方法 " F& X6 z- [' {: @
. O% X' T8 p% S. y/ t2.1 Applicable Hardness of Fasteners Requiring Hydrogen Relief 要求进行驱氢处理的紧固件的硬度 & a" r! M9 H; }+ B3 z3 _
& v( h# M7 s: @" [: k* H4 {The hardness levels referred to in this standard that will determine the type of hydrogen relief required is the “specified case hardness” for case hardened fasteners (MS-4515, MS-5479, and MS-5001). For through hardened and tip hardened fasteners (MS-3517, MS-5766, MS-7483, MS-4515B, MS-6149 and MS-8253), the hardness that shall apply in determining the type of hydrogen relief is the “specified core hardness.”
- j' x% {/ q+ z* W对于表面硬化型的紧固件(MS-4515、MS-5479及MS-5001),本标准明确提出,决定其去氢处理方式主要取决于其“表面硬度”。对整体调质或局部淬硬型紧固件(按标准MS-3517、MS-5766、MS-7483、MS-4515B、MS-6149及MS-8253),决定其去氢处理方式主要取决于其“芯部硬度”。
/ m: a+ I v2 ~) S) I' I- n7 L( B( ^) d+ v/ ]4 {& a- `, p9 d1 a$ G6 t3 j
2.2 Categories of Surface Treatment 表面处理的类型
( j# t( S4 ~1 C* u7 C* h4 M# C$ a' j
6 ^ I. }, C8 x 9 y a9 K6 R9 B
2.2.1 Acid Cleaning 酸洗 Acid cleaning must be minimized on high-strength/high-hardness steel parts because it can contribute to hydrogen embrittlement. Therefore, if fasteners or parts with a specified Rockwell hardness of HRC 32 or greater are to be acid pickled, it is required that a procedure be established for processing the parts that limits the time in the acid to a maximum of 10 minutes. Controls must be implemented and records kept on the type and concentration of the acid used, exposure time, acid bath temperature, and the type and amount of inhibitor. It is required that records be kept on when the parts entered and exited the various processing stations. For automatic plating equipment, a record of the cycle time will suffice until the cycle is changed or until the line is interrupted due to breakdown or otherwise. |
