查看: 2703|回复: 5
[已解决] 有关在Aux 3D Viewport里使用Drawlist
发表于 2009-2-9 20:12:17 | 显示全部楼层 |阅读模式 来自: 中国上海
发表于 2009-2-10 09:17:13 | 显示全部楼层 来自: 中国香港
Copy                                  Edit                             Ctrl+C                      Copy the selection and put it on the Clipboard
# A* N0 e1 d4 ?3 {* y9 @6 z% A4 CNew                                   Filing                           Ctrl+N                      Deletes the current drawing
2 V5 N3 q8 b, Q! F( I" v! I9 A8 hLoad ...                              Filing                           Ctrl+O                      Loads a file into OneSpace Designer Annotation.
- F, ~! R1 [* C3 a/ nToggle Open Menus                     Miscellaneous                    Ctrl+Q                      Toggle Open Menus* l' X( K9 r0 k1 c8 Z/ M; t
Save ...                              Filing                           Ctrl+S                      Saves the data to a file.& B' e+ U9 I1 |  G, d
Undelete                              Delete                           Ctrl+U                      Undelete elements.! p: a- c5 b5 }* o8 o* \: R. p
Paste                                 Edit                             Ctrl+V                      Insert Clipboard contents
9 k. p' `7 G) w  `+ kOn Context                            Help                             F1                          Help on current context" n; D" q2 ?$ N& c- g3 u- b
Global Axes On/Off                    View                             F10                         Toggles the global coordinate axes on/off in a given or selected viewport1 U3 [# g' s8 J8 x
Full Screen                           View                             F11                         Toggle Full Screen Mode on and off" S3 |! ^0 {/ m5 V# m2 |
Browser Bar                           View                             F12                         Show or hide the browser dialog bar8 W% O+ [/ G$ s/ k+ I* h# e
Select                                Select                           F2                          Select objects: l; y: y% D' N# g* s- u( C
Search Next                           Miscellaneous                    F3                          If Search command is active: Search next matching item. Else: Toggle the global coordinate axes on/off in a given or selected viewport.' \0 n* a5 F. r
Hidden On/Off                         Viewport                         F4                          Toggles the hidden lines in Annotation views on / off.5 F* C5 u1 F, b6 l+ @5 O2 p; \
Geo On/Off                            Viewport                         F5                          Toggles the lines in Annotation viewport on / off.; b' `8 W$ q" ~7 U% z
Task Bar                              View                             F9                          Show or hide task bar( V" a2 w+ \  m8 \: z
Update Colors On/Off                  Viewport                         Shift+F10                   Toggles update colors in Annotation views on / off.
! n* T' Q* d- t. t6 `7 R. J: W) ]Drawing Browser                       User Interface                   Shift+F12                   Show drawing browser.- g' ~8 R! v3 B
Tangent On/Off                        Viewport                         Shift+F4                    Toggles the tangent lines in Annotation viewport on / off.& J  R( n, x  d( @. h' a
2D Geo On/Off                         Viewport                         Shift+F5                    Toggles the manual created lines in Annotation viewport on / off.  }( V5 @* y4 O
Vertex On/Off                         Viewport                         Shift+F7                    Toggles the vertex in Annotation viewport on / off.
 楼主| 发表于 2009-2-10 11:03:01 | 显示全部楼层 来自: 中国上海
发表于 2009-2-10 11:06:54 | 显示全部楼层 来自: 中国香港
我查过了在2005里应该是没有的.在自定义命令的那个对话框可以查看该命令对应的快捷方式...keyboard
发表于 2009-2-10 14:55:24 | 显示全部楼层 来自: 中国广东佛山
原帖由 a_zong 于 2009-2-10 11:03 发表 http://www.3dportal.cn/discuz/images/common/back.gif
/ U1 E. |0 m" R7 f谢谢斑竹贴了那么多快捷键出来,但在我印象当中是一个“keyboard+mouse”的组合。
% x0 k4 }5 w( }* O( K& t& I# N
+ @$ h5 n  \7 P6 J& S" z" k也用图示贴上来,看看有没有你想要的
sytgos + 3 应助
 楼主| 发表于 2009-2-10 20:34:59 | 显示全部楼层 来自: 中国上海
