查看: 2767|回复: 7
[求助] 只知道3坐标,数值很大如何CAD中用空间显示出来
发表于 2009-2-20 15:36:12 | 显示全部楼层 |阅读模式 来自: 中国山东威海
 楼主| 发表于 2009-2-20 15:37:41 | 显示全部楼层 来自: 中国山东威海
发表于 2009-2-20 16:04:11 | 显示全部楼层 来自: 中国上海
在模型窗口里画,就可以了呀。
 楼主| 发表于 2009-2-20 16:25:45 | 显示全部楼层 来自: 中国山东威海
发表于 2009-2-20 17:45:11 | 显示全部楼层 来自: 中国上海
楼主讲的详细一点,是要更改什么比例?在模型里画,你的表示的东西多大,图形就画多大,标注出来也就是实际尺寸,单位当然是毫米,你要把单位改成米,可在标注样式里把测量比例值1改成0.001;字体太小,在标注样式里修改调整,比如你要把字体放大1000倍,就把全局比例修改为1000。
发表于 2009-2-20 19:32:35 | 显示全部楼层 来自: 中国河南郑州
将序号和等号去掉,如下:& Q7 z# C* `6 f9 p3 ]4 U
475277.724007,4413491.037460,49.085523! U+ B6 T( M: r4 m+ z1 I
475277.217631,4413490.484213,49.085523
4 g0 R+ B- ]. F" t$ H0 B475276.711255,4413489.930964,49.085523
5 f# t$ K  ?/ H+ j( ^' T475278.203488,4413490.598601,49.084223
  v, D+ z! }: Y475277.697112,4413490.045354,49.084223
( d+ V! p+ M- l" d0 I" W475277.190736,4413489.492105,49.084223
% I1 t# k6 ^/ F: M! G7 D' Y" y475278.682970,4413490.159743,49.082923
  k8 s9 [& w0 B5 L2 m475278.176594,4413489.606495,49.0829234 S3 s. g3 A* P) K9 A! V/ o; i
475277.670218,4413489.053245,49.082923
: z8 I4 w2 o+ M9 p( \( \" ~; j475279.162452,4413489.720882,49.081623
4 q: E/ \4 W; r& Z475278.656076,4413489.167635,49.081623  h, d: z! R% e/ C, X7 J' j
475278.149700,4413488.614386,49.081623
1 k: e9 M1 A1 S3 q; I$ M475279.641933,4413489.282024,49.080323( U4 r, o1 Y. n8 ]
475279.135557,4413488.728776,49.080323
3 w' _' [+ I, q5 U& t475278.629181,4413488.175528,49.080323. ?0 n, \  A2 v# a
475280.121415,4413488.843165,49.079023
& I- }( p* o$ O7 X3 }7 _2 T475279.615039,4413488.289916,49.079023
  o) r) j3 h" m$ o: ~1 d  N475279.108663,4413487.736669,49.0790239 C; K6 m0 d% Y
475280.600897,4413488.404305,49.077723
3 o# U( `5 u  \7 J- Z% V4 @475280.094521,4413487.851057,49.077723
4 x' S3 l! \& A. o% U# o475279.588145,4413487.297810,49.077723" b$ T$ k# J5 [4 h- d
475281.080378,4413487.965447,49.076423
2 U$ ]6 N# Q* O" w1 c- B& c) @475280.574002,4413487.412199,49.076423
% I* J7 }0 e+ n- o475280.067626,4413486.858950,49.076423
$ @. O- r8 l9 `% v9 R" B2 M6 b: i475281.559860,4413487.526588,49.075123/ K& X) i' X9 Z+ t( `' [: v
475281.053484,4413486.973340,49.075123
  s. I3 v5 O( _) Q475280.547108,4413486.420091,49.075123" s. S- X% R9 N) K
475282.039342,4413487.087728,49.0738234 X3 ]$ C$ f8 ^6 b) Z9 ?: G) n. K
475281.532966,4413486.534480,49.073823
) h) P) N6 s% m- U6 V( Z5 r- n; ]475281.026590,4413485.981232,49.073823  ~  A' o* F( L/ x
复制所有数据,执行直线命令(并适用其它个别命令),将复制的内容粘贴到命令行内,回车确认即可画出。
 楼主| 发表于 2009-2-21 08:24:11 | 显示全部楼层 来自: 中国山东威海
发表于 2009-2-21 09:51:50 | 显示全部楼层 来自: 中国陕西西安
也是个高手啊
