请求解释翻译这段文字的意思' ?$ [/ e$ w; ?& o
Pressure openings. Allows you to specify Static Pressure, Total Pressure or Environment Pressure on the selected faces. The Environment pressure condition is interpreted by COSMOSFloWorks as a total pressure for incoming flows and as a static pressure for outgoing flows. If, during calculation, a vortex crosses an opening with the Environment pressure condition specified at it, this pressure considered as the total pressure at the part of opening through which the flow enters the model and as the static pressure at the part of opening through which the flow leaves the model. Additionally, you can specify fluid temperature (and concentration for multiple fluids), turbulence, and boundary layer parameters. These settings are used to define a fluid entering the model at the opening. |
