查看: 3060|回复: 8
[分享] AUTOLisp也可以说话!
发表于 2009-3-2 16:35:49 | 显示全部楼层 |阅读模式 来自: 中国四川德阳
试试,很神奇吧!
8 Z8 ?# G1 n$ t# }+ Y) v0 |. \(defun c:test (/ ss i txt catch)9 b2 X8 u9 _0 I: `  p$ ]. b
  (defun speek (str)
! c5 D8 t3 r1 V" `. \$ r    (setq spi (vlax-create-object "Sapi.SpVoice")): |" J+ w4 @6 k* p
    (vlax-method-applicable-p spi "Speak")
! e" ^. `, G$ W" q0 m4 a. N) Z    (vlax-invoke-method spi "Speak" str 3)# u* I! P2 L  O' K  A
  )7 V- q+ o; f7 O0 U5 J3 V9 V% @' g
  (princ "\n请选择要朗读的文字 : ")) A, i4 X1 N) y, V
  (if (setq ss (ssget '((0 . "*TEXT"))))
8 s' T- L+ x4 n- T3 D7 w    (progn1 J( u: k( p! e; X% s* W  n
      (setq i -1)
, y- G8 \8 U: L& [( ]! M! c5 `      (repeat (sslength ss)
' E: ~6 G, |% D6 Q* v0 s. X        (setq txt (cdr (assoc 1 (entget (ssname ss (setq i (1+ i))))))2 N( j! h7 S1 ]( E- J  T- U
              cat (vl-catch-all-apply 'speek (list txt))
" G  C. V9 h0 P& ?. A6 P        )* ^( Z' E  V! G  u( J' s" k
        (if (vl-catch-all-error-p cat)
' a# l' }" D. n0 A' s8 c          (progn (princ "\n朗读文字时捕捉到错误 : ")  K: O; P6 W' {$ W9 C% M
                 (princ (vl-catch-all-error-message cat))4 R4 s0 w% Y% R1 E. A
          )8 H( f* b6 l5 K# n, a
# K1 O/ J, o7 I( \      )1 f" ]2 q+ J; A4 Y
    )6 q. T1 y7 s1 Q; P- G
  ): o8 H2 t, G( H' E* b+ n, h
  (princ)$ d- l, j& H5 p" F. p  q7 N
发表于 2009-3-3 16:04:08 | 显示全部楼层 来自: 中国辽宁鞍山
太神奇了,楼主用的是VBA 中的vl-catch-all-apply函数,学习了,还有什么神奇功能??
 楼主| 发表于 2009-3-3 16:35:18 | 显示全部楼层 来自: 中国四川德阳
还可以这样
;;winxp测试通过比如(speek "how are you") 1 S, M& y% I$ B. W% D( Q2 a7 b& r
(defun speek (str)
1 D7 }& @6 z% A  \9 e$ B  ?  (setq spi (vlax-create-object "Sapi.SpVoice"))
2 B3 L5 D5 E, E  (vlax-method-applicable-p spi "Speak") & P- G5 w3 A- e9 l& G" `: m
  (vlax-invoke-method spi "Speak" str 3) 4 D4 _7 A+ k* _) y9 p
) " s) g- e1 O6 r4 O% S
;;只有装了中文语音包下面这段代码才能完好运行. + ]4 k' i# R! y7 H& ]
(defun c:speek (/ ss i). W" U3 |" e4 x
  (princ "\n输入要朗读的文字:")
& b; r9 F) V! B. {. h) ]! B# {  (setq ss (ssget '((0 . "*TEXT")))) 8 ^2 e+ s1 a, X, P% Z, W
  (setq i 0)  1 @1 C) r9 d" A+ f* d! \3 ]
  (repeat (sslength ss) " P8 u7 L( z) i! \* M  s
    (setq speekContent
; _: P& R) X( E9 U0 c5 [       "<VOICE REQUIRED='NAME=Microsoft Simplified Chinese'>"
' L" r7 E0 l2 B3 q    )
& V' n: |9 u; F$ b    (setq speekContent
2 T) f  T3 d0 W! y) n       (strcat speekContent 8 n. ~% {. d5 E( r4 s, Y
           (cdr (assoc 1 (entget (ssname ss i))))
1 \: F4 Y; _: b           "</VOICE>"
/ n% j0 c- ^1 q2 @8 z( K       ) ' y6 R: V# Q& z" v
' w: v" d9 _% T4 C0 V, p    (setq catchit (vl-catch-all-apply 'speek (list speekContent)))
# A9 V; G, l5 ?, S0 I1 f7 \$ o    (if    (vl-catch-all-error-p catchit) & F. F9 X0 }  A! m
      (progn (princ "\n朗读文字时捕捉到错误:")
8 O5 X$ P# g& k. E         (princ (vl-catch-all-error-message catchit)) - E6 H* e) }0 ]0 w' [
      ) / T3 Y& u' F2 N2 k0 ~; \* z
: |6 e" S. A5 [0 g5 ~    (setq i (+ i 1)) 9 N& X, j0 P2 u) s" V
  P+ a3 X/ u/ b- ]- X. g5 \  ?; i)
发表于 2009-3-9 23:57:44 | 显示全部楼层 来自: 中国江苏常州
厉害啊,,高手
发表于 2009-3-12 20:59:31 | 显示全部楼层 来自: 中国上海
咱也试试!
发表于 2009-3-15 00:20:35 | 显示全部楼层 来自: 中国内蒙古通辽
帅气,我看到那个就头晕,真了不起
发表于 2010-1-31 19:39:37 | 显示全部楼层 来自: 中国江苏南京
我是刘姥姥进了大观圆了。佩服佩服!
发表于 2011-1-14 16:27:48 | 显示全部楼层 来自: 中国广东深圳
我也来试试,
发表于 2011-1-19 13:02:45 | 显示全部楼层 来自: 中国山东日照
试一试,楼主了不起。
