发表于 2009-4-5 06:35:04
来自: 中国山东烟台
这个事我的楼主看看 有什么不一样吗?* y8 S6 m2 l& f" k) W
怎么个打不开啊?# J! ~- S* Y0 ?, B
#FEATURE CORE_ELECTRODE cima-d 8 31-dec-2012 uncounted
, h6 u) f" L; \# HOSTID=0019DBB5F86C ISSUER="Team oDDiTy" SIGN=6DBC437817BE
) r1 s2 x1 }, Q* p' K4 N, Y; T/ l
5 q! p) M& u% S, I, V4 ^6 p6 cFEATURE CORE_STANDARD cima-d 8 31-dec-2012 uncounted \
: _9 {# {5 w0 V" @8 ?% Q! } HOSTID=0019dbb5f86c ISSUER="Team oDDiTy" SIGN=D240DCC213F29 p( E2 c% N2 m9 x" s7 l2 b+ h: ^
PACKAGE ODT_SHOOT_PACKAGE cima-d 8 COMPONENTS="$oDDiTy 2D-TO-3D \
$ [* K3 U- L( s |; ^9 ] 2X_MILL_LITE 2X-MILL 2X-WIRE 3X_MILL_LITE 3X_SIMULATOR 3X-MILL \
. \0 V' D' e' B 4X-CONT 4X-WIRE 5X_AEROSPACE 5X_SIMULATOR 5X_TRIM 5X-CONT \7 N/ o. p, _$ l) T" ~- E0 C: v
ABIANT ADVANCED_ASSEMBLY AUTODRAW AUTOMATED_DRILL BEND \) P: K3 N& \0 x$ |- B( R" n
CAD_MODE CADENAS CATALOGTOOL CATIA CATIAR2D CATIAR3D CATIAW2D \+ b I4 w0 ~) t- m s, [ G4 a! M
CATIAW3D CHINESE_TRANSLATION CIMACABLE CIMADEK CIMADEK-NC \) D7 W- R% }" c& a& v/ P# d
CIMADEK-RUN CIMARENDER CIMIT-D CIMIT-M CIMIT-MD CIMIT-MDN \
# ^+ m# a/ N9 s% T; @( i CIMIT-MN CIMIT-N CONCURRENT_DESIGN CORE CORE-M CORE-X CPDM \
+ T, ^3 v6 k* N5 Q& j' _ DIE_BLANK DIE_FLANGE DIE_FORM DIE_LABEL DIE_PLOT \0 y* x+ I& [6 f: B
DIE_PLOT_SAFETY DIE_PLOT_THICK DIE_SET DIE_STRIP DIE_TOOLS DMS \3 Y2 H. h' y( g. l, c
DRAFT DWG DXF E_STAMP EDM_SETUP_WIZARD EDM_WIZ_AGIE \. Z! d' q1 x& f" w0 Y. S
EDM_WIZ_DPC EDM_WIZ_INGERSOL EDM_WIZ_MITSUBISHI EDMS-LINK \/ u& v& p$ `- f7 D. _0 z' d/ f9 O
ELECOTRE FAST_BLANK FEM FIKUS_IGUS FUSION_FULL GPF GPP \
3 y* J4 R7 m* ~& ~# g GPP_DEV_EX2 GPP2_3X GPP2_5X GPP2_DEV_3X GPP2_DEV_DF2 \0 ]' y3 H, m# b
GPP2_DEV_EX2 GUN_DRILL IGES KINEMATICS LATHE LATHE_2X LATHE_3X \
2 t6 s3 n# q7 p# U6 V3 L1 U LATHE_PP_COMPILER MACHINE_SIM MACHINE_SIM_CONFIG MACRO \
* v4 M$ l% f" _* G1 \ MICRO_3X MICRO_5X MICROSCRIBE_IF MOLDBASE3D MOLDDESIGN \
+ O( z( m" v9 G1 E9 e MOLD-EXPERT MULTI-USER-1 MULTI-USER-2 MX_MOTION_BUILDER \0 a% N. P2 R& u, w- z- H, Q7 }
MX_MOTION_EDITOR NC_UNDERCUT NC-LINK NESTING NETWORK_ENABLED \
- G/ {6 C1 y6 F" v( D( K2 M2 [ PARASOLID_READ PARASOLID_SAT PAR-SHAPE POST_CONFIG \0 T! }" d$ a- H+ u2 b
POST_DEVELOPMENT POST_PRO POST_RUN PUNCH Q5X_CONT QCOMPARE \
{* z- i- t- k6 K% a* z8 d QCON_C QCON_Q QCON_S QELECTROD QSPLIT QUICK_NC QUICKCONCEPT \ V5 i8 K0 L) C% t& i) m
QUICKDRILL R_CATIA_2D R_CATIA_SAT R_CATIA5 R_IGES R_IGES_SAT \
. b# O7 [6 \2 r V6 z( L3 S R_INVENTOR R_PARASOLID R_PROE R_SOLIDWORKS R_STEP R_STEP_SAT \
5 u6 {6 ^6 C# N7 X6 o R_UG R_VDA R_VDA_SAT R_VRML RD-PTC RE-ENGE SHEET_METAL SAT \
0 K1 v* }$ I. h. S/ u7 \ SHOP-NC SIMULATOR SLA SOLFAST_FULL SOLID SOLID-ASSEMBLY \
8 ?; S n6 f/ Q% ?( h4 S STEP_READ STEP_WRITE STL SURFM TACFAST_FULL TEMP_KEY_CODE \, }$ P/ Y0 W1 l; i U' e8 y
UGR3D V_CONTROLLER VDA VERIFIER W_CATIA_SAT W_CATIA5 W_IGES \+ [* U6 v/ |+ i# i
W_IGES_SAT W_PARASOLID W_STEP W_STEP_SAT W_UG W_VDA W_VDA_SAT \
1 ~4 S9 b$ i- T0 _0 Q W_VRML WF2SRF WIRE_2X WIRE_4X WIRE_STANDALONE X-CIMADEK \. y" }' y, f# [+ C
X-CIMADEK-RUN" SIGN=A7ECA376CC4E0 @! ^3 ^/ C$ k. F/ f
FEATURE ODT_SHOOT_PACKAGE cima-d 8 31-dec-2012 uncounted \ r+ I% }9 i: Q5 a
HOSTID=0019dbb5f86c ISSUER="Team oDDiTy" SIGN=C3F7BB1CA1B6
, L. N$ x/ d' \3 l F7 ^PACKAGE ODT_CATALOGS cima-d 8 COMPONENTS="CATALOG_DANLY_INCH \. x" p& @5 O$ t) V* v' }
CATALOG_DANYL_MM CATALOG_DAYTON_INCH CATALOG_DAYTON_MM \
+ P: S0 K: i* ^8 Z CATALOG_DME_INCH CATALOG_DME_MM CATALOG_DMS CATALOG_FIBRO \
8 h* S8 ?: ]. {1 r. c. c CATALOG_FUTABA CATALOG_HASCO_INCH CATALOG_HASCO_MM \7 g4 v8 j* ]; } @9 j
CATALOG_HOPPT CATALOG_HYSON_INCH CATALOG_HYSON_MM \3 I8 l' i4 } p! G/ i: U) {" T
CATALOG_KISHIN CATALOG_LKM CATALOG_MEUSBURGER CATALOG_MISUMI \
% I8 s# u- V5 h1 W3 q9 y$ p CATALOG_NATIONAL CATALOG_OKSET CATALOG_OTHER1 CATALOG_OTHER2 \
5 f1 E9 @( }$ g7 {- E, E0 [ CATALOG_OTHER3 CATALOG_OTHER4 CATALOG_PCS CATALOG_PEDEROTTI \
: F2 q1 B$ f6 y$ u CATALOG_POLIMOLD CATALOG_PROGRESSIVE CATALOG_RABOURDIN \
0 u; B# E: Z, e CATALOG_SIDECO CATALOG_SISCAT CATALOG_SKF CATALOG_STAMPI \9 F2 B5 N# Z1 q( \
CATALOG_STRACK CATALOG_SYSTEM3R CATALOG_TEKIS CATALOG_TVMP \% {: z8 g8 L; C4 y8 Z
CATALOG_UNI CATALOG_VAP " SIGN=32AC419C92FC- z- [" ]; f% I4 ?9 ?
FEATURE ODT_CATALOGS cima-d 8 31-dec-2012 uncounted \" F% q: e2 L2 c
HOSTID=0019dbb5f86c ISSUER="Team oDDiTy" SIGN=60294F4A5A66+ i1 s0 Q& B+ h
FEATURE CHINESE_TRANSLATION cima-d 8 31-dec-2012 uncounted \
1 ?- V0 M3 ~6 D3 N1 G8 X& N, E1 Q% ` HOSTID=0019dbb5f86c ISSUER="Team oDDiTy" SIGN=21D902F0E482 |
