查看: 2067|回复: 4
[讨论] UG5.0二次开发中创建一个二维工程视图(大虾请进)
发表于 2009-4-8 17:30:57 | 显示全部楼层 |阅读模式 来自: 中国广西桂林
使用的例子是:《图表详解UG NX二次开发》第11章的例子(11.4.1). t  ?1 d6 r+ g+ S: o# H
/ d6 }% J8 V2 M$ a$ \
代码如下:) e6 P4 e  S  ]5 }& _4 t
#include <stdlib.h>
/ _2 w6 p" f. Z. r; S, A$ ~#include <stdio.h>
  b5 w& p. g. Y4 ?; \; ~9 m6 d#include <uf.h>
4 K  n! H# ]$ A8 `$ Z& B#include <uf_defs.h>
/ F  N5 I: a( N5 r#include <uf_draw.h>
9 e: C/ K9 r1 h; C! c/ v( M#include <uf_draw_types.h>0 R7 Q2 _' `$ y$ |& a+ f
#include <uf_obj.h>
* b. k$ i! c; s. v- a0 D7 V#include <uf_part.h>" K- h" r& Z- y# M
void ufusr(char *param, int *retcod, int param_len)
9 W) \5 h5 {: I7 X{
5 ?  i2 m) J2 ]% Aint         ifail = 0;
4 i2 M/ v. _, ~. r: r- P5 Fdouble      reference_point[2] = {70.0, 160.0};) n2 X7 J% `: n' _! L
tag_t       drawing_tag = NULL_TAG;% @! b0 C  n4 Z2 x# M
tag_t       part_tag = NULL_TAG;
$ R: [' m- ^( E# _tag_t       view_tag = NULL_TAG;
6 P9 c# h. n1 ?tag_t       draw_view_tag = NULL_TAG;0 X1 k" Y3 S" }6 S/ b* Q( r! f
char        *view_name = "BOTTOM";7 y# d( E/ e' F
UF_DRAW_view_info_t view_info;: i3 e2 G0 Y# H
view_info.view_status = UF_DRAW_ACTIVE_VIEW;$ L8 C3 R) w5 u% w3 H* {- x
view_info.anchor_point = NULL_TAG;
; `* q( J( I8 Mview_info.view_scale = 1.0;3 O% A! W" J* d: \. }, R: M7 }
view_info.use_ref_pt = FALSE;+ w; s4 \3 U% @+ V, j/ q( h4 G
view_info.inherit_boundary = FALSE;2 L- L1 w+ F8 M
view_info.transfer_annotation = TRUE;
% A1 l6 @& v% `5 sUF_DRAW_view_prfs_t view_display_parms;
8 w) T0 q3 G+ P" i) h# V0 kifail = UF_initialize();& n* q7 K# U6 r% l; N8 p5 K
if( !ifail )# M3 E9 U3 W, u$ F3 y
  part_tag = UF_PART_ask_display_part();
6 k" W+ @" ~- A) p" Yif( !ifail & part_tag != NULL_TAG )
, r3 ~( X+ \" x: F9 M  ifail = UF_DRAW_ask_current_drawing( drawing_tag );
* x0 ^' I& R$ h1 ]. B. Mif( !ifail & part_tag != NULL_TAG && drawing_tag != NULL_TAG)
5 T# v7 L' d( x! k# h% ?{
2 R; L1 B- }, P5 f- e# M  ifail = UF_OBJ_cycle_by_name( view_name, view_tag );
9 t5 I; L, F! P2 j" u( O& o  if( !ifail & view_tag != NULL_TAG )
" m5 r$ B9 O# p  {7 g0 W% ?- W$ h/ i) P) _1 F
   ifail = UF_DRAW_import_view( drawing_tag, view_tag,reference_point, view_info,  &draw_view_tag );" n# {% ?" d7 o/ ?: I
   UF_DRAW_delete_view_label ( view_tag );6 V3 p1 f! e+ W! V2 i  K
   UF_DRAW_set_view_display(drawing_tag,view_display_parms);
/ n( b: g' K% b/ x6 V0 h   UF_DRAW_update_one_view(drawing_tag,draw_view_tag);* p& D# _2 C5 ]" |9 @3 M
  }! g/ z3 t  A7 W& [9 S
}4 s% `( M( ?, Q! ~! q
ifail = UF_terminate();/ o, E- i$ F+ G2 M" H; G# y& F
}7 W) e: Z- ], |$ D- w
(以上是全部代码)9 _3 w9 c; T% }4 h2 ?
1.在投影之前,UG中已经建立了一个三维模型,而且已经进入图纸空间(SH1) D% R4 L! Q: w$ x" `
2.执行ImportView.dll
* V1 C" a( W" b- A3.应该是俯视图(X-Y平面)出现在图纸上,但是我运行的时候什么都没有显示。
7 H; @- j9 {! q问题:. @$ `" ?5 l4 s% Z- w$ f2 X
1.如何进入图纸空间
  U" x& s4 G0 j( `是不是点击“开始”-》“制图”-》确定8 W9 ]( ?0 V9 I8 i4 S  v
2.请大虾们试试这个例子,在UG5.0下到底可不可以运行。
, _) B8 t' x& |2 P! ?我调试过这个程序,各条语句都运行了,但是图面就是没有反应。无奈啊!!& Y+ x5 W9 {) L3 S! j' E2 C. X! z
请大虾们帮帮忙,小弟不胜感激!! 9 n# G  Q( S2 _* o: J
求详细的操作步骤!
 楼主| 发表于 2009-4-9 11:05:59 | 显示全部楼层 来自: 中国广西桂林
哪位老哥指点一下啊!
 楼主| 发表于 2009-4-10 11:07:29 | 显示全部楼层 来自: 中国广西桂林
高人们,显显灵吧。。!@#¥@#!@4 e/ F4 v6 U/ `/ J
俺呼唤你们~~
 楼主| 发表于 2009-4-10 21:34:34 | 显示全部楼层 来自: 中国广西桂林
最后找到了可能出现问题的原因了。运行到9 ]1 F, P3 G; i. g  o
UF_DRAW_import_view( drawing_tag, view_tag,reference_point, view_info,  &draw_view_tag );& y) V5 q& X1 W* H( B) Q5 k- z
语句的时候调试显示可能出现了内存错误,没有强制跳出。, V. w" ~: I3 [& s6 P, H. \* \
另看到一个英文网站上说UG V15.0修复了一个引入视图错误。
" V# _& P; s$ N) @" S% X而我看到帮助文档上写的是V13.0.可能这个错误在13.0没有修复,所以出了问题。; O9 @+ K4 o3 F. k! Z( L+ w( j
对于这两个有点疑问。UG5.0到底是什么版本的,引入视图这个问题有没有被修复?怎么才能用上V15.0这个已经修复的版本?
 楼主| 发表于 2009-4-14 11:18:13 | 显示全部楼层 来自: 中国广西桂林
天灵灵地灵灵,论坛高手快出现!!
