发表于 2009-5-5 14:23:30
来自: 中国陕西宝鸡
南化机煤化工设备制造业绩表
3 S4 _. r( s- u+ v# a d p1 FNCMW Main Equipment Fabrication Experience For Coal Chemical Industrial Area# K* G4 }" L! Y5 ~
序号No.设备名称 Description 规格 Dimension(mm) 设计压力 DesignPress.(MPa) 设计温度DesignTemp.(℃)换热面积或容积Heat Area or Vol.主材Main Material重量Wgt.(T)台数Qty用户End User交货时间Delivery Time5 \3 }1 h& `/ g* j. a# E
1高温变换炉φ3800×91×114054.52475/SA387Gr11Cl2891中原化肥厂1988H.T. Shift ConverterZhongyuan Chemical Fertilizer Plant
9 z7 U( A9 n% Q3 Q2甲烷化炉φ2600×56×96854.3450/SA387Gr11Cl2411中原化肥厂1988Methanized ConverterZhongyuan Chemical Fertilizer Plant- E6 z( m9 s$ [
3气化炉 (渣油)φ2400×(1100+6.5)×99399.57375 SA387-11-2+309L/347L(急冷室堆焊不锈钢 overlay SS in chilling room)102.061新疆乌鲁木齐石化总厂1998Gasifier (residual oil) Xinjiang Urumqi Petochemical Plant
2 x! |* [4 G% I% q7 |, d4CO2塔ф2200×16×515000.6-75~70 A203-D43.111南化公司大化肥1999
9 z9 Y- P9 p1 Y4 g0 Y. @CO2 Tower A350-LF3Nanjing Ammonia-Urea Plant4 b$ |( q. j C! {5 }9 p5 B
5H2S浓缩塔φ2400×14×541500.4-80~70 A203-D47.8651南化公司大化肥1999
' ^( _4 H; t/ c/ z! _H2S Concentrator A350-LF3Nanjing Ammonia-Urea Plant: g. ~ i6 s( ~2 L" \1 a W
6洗涤塔底部冷却器φ600×28×7537壳S: 8.7壳S: -80~60 SA203GrD SA334Gr313.9541南化公司大化肥1999- ~ v( L) u& S$ w- l* B
Washer Bottom Cooler管T: 9.1管T: -80~60 SA350-LF3Nanjing Ammonia-Urea Plant
/ a& Y1 }. ]3 F7第一甲醇冷却器φ800×14×5244壳S: 0.6壳S: -75~50 SA203GrD SA334Gr37.11南化公司大化肥1999
) I9 ~- B+ c1 U3 z/ D% v- s1st Methanol Cooler管T: 8.7管T: -75~50 SA350-LF3Nanjing Ammonia-Urea Plant
5 j* b8 K) w9 V9 c8合成气/甲醇冷却器φ700×35×6087壳S: 8.6壳S: -80~60 SA203GrD SA334Gr37.8361南化公司大化肥1999
: p y" w& ~- R5 K9 k# CSynthesis Gas/Methanol Cooler管T: 9.5管T: -80~60 SA350-LF3Nanjing Ammonia-Urea Plant: [! z( e4 t5 i) |! v
9废甲醇罐φ1800×6×55190.4-80~120 A203-D3.11南化公司大化肥1999
5 Z& [- ~' o, G. fWaste Methanol Tank A350-LF3Nanjing Ammonia-Urea Plant
% x# n, S: E+ v- a10甲醇洗涤塔φ2360×80/85/90×605508.6-75~70 SA203GrF326.71南化公司大化肥1999
5 ~* p( P: k% m+ h5 }Methanol Washing Tower SA516Gr70+S5Nanjing Ammonia-Urea Plant
/ J! f( C% q7 y! j* y' v11氨排放罐φ2000×8×52600.17-40~70 16MnDR2.9511南化公司大化肥1999" Z+ p) `$ p2 L# u8 E
Ammonia Vent Tank Nanjing Ammonia-Urea Plant
2 J. n- O# P: y" q9 P12气化炉(沥青)φ2600×(130+6)×143769.7430 SA387-11+309L/316L
7 E' A2 Z; K6 ?; ~' _$ M5 o' P: c" _(急冷室堆焊不锈钢 overlay SS in chilling room)1202南化公司大化肥1999
: A+ H' ]! H- ]1 F1 l$ YGasifier (asphalt) Nanjing Ammonia-Urea Plant
* d+ ~3 ^; V2 ^/ Z' ~' o9 }13气化炉φ2800×(50+5)×141463.53425 SA387-11+309L/316L! J5 v, ?& R+ B0 l7 p$ Q" v" d1 ~
(急冷室堆焊不锈钢 overlay SS in chilling room)62.81山东鲁南化肥厂2001
& K1 S& ?& L& r( QGasifier Shandong Lunan Chemical Fertilizer Plant0 w7 _& H1 M' d8 ?5 D1 p1 c1 o3 I
14第一低温变换炉φ3000×46×131203.92606015CrMoR
) s* V6 [4 J L) }* E- ]57.931浩良河化肥厂2003.03
0 A4 N* e. B- ]; B0 D1st L.T. Shift ConverterHaolianghe Chemical Fertilizer Plant& E0 M# N* m2 g' R! x( Z6 h
! [4 m9 G2 W2 S
15第二低温变换炉φ3000×46×131203.92606515CrMoR
. S$ y% `5 v4 t) q. O60.521浩良河化肥厂2003.03
/ N9 i$ O1 H& s" |5 W2nd L.T. Shift ConverterHaolianghe Chemical Fertilizer Plant
4 @) s' ?# r5 |% }3 j: e0 x4 T
, T$ r# r d h7 X( @. e16甲烷化炉φ2600×48×106983.944029.815CrMoR26.531浩良河化肥厂2003.03
4 e$ F: n! q$ \" g6 t* KMethanized ConverterHaolianghe Chemical Fertilizer Plant( q; ^2 ~% U$ L4 ~: |
2 h6 T$ J6 {- C. V
17ZnO脱硫槽φ1600×28×66783.93507.715CrMoR19.081浩良河化肥厂2003.04
- @7 f& o% M" ?% z+ T: JZnO De-sulphur TankHaolianghe Chemical Fertilizer Plant% y& y" s( @8 O! N" S
; v0 n" f2 h: x0 I
18含硫甲醇冷却器ф600×14×5635壳S: 0.4壳S: -70/50 SA203E3.261山东华鲁恒升化工股份有限公司2003
3 ]' V( {. Q% i o# OMethanol with Sulphur Cooler管T: 5.8管T: -70/50 Shandong Hualu Hengsheng Chemical Industrial Co.
F2 w4 `6 z K/ N19无硫甲醇冷却器ф500×16×6747: G+ X( Z0 K/ o. f7 H7 a$ }% b& N
壳S: 5.8壳S: -75/50 SA203E3.36×22山东华鲁恒升化工股份有限公司2003
' `! D, r% V# ?) g) PMethanol without Sulphur Cooler管T: 6.4管T: -70/50 Shandong Hualu Hengsheng Chemical Industrial Co.' o, `/ c( k# D: s
20脱硫甲醇冷却器ф850×12×6158, P- ?0 @1 I& t7 z
壳S: 0.3壳S: -75/50 SA203E6.05×22山东华鲁恒升化工股份有限公司2003
, p5 }3 S$ Q! u$ `De-sulphur Methanol Cooler管T: 6.5管T: -70/50 Shandong Hualu Hengsheng Chemical Industrial Co.7 U4 ^) u/ m7 W! W0 Z& I) ~
21第一变换炉φ3600×20×87123.43505915CrMoR491湖北双环科技股份有限公司2004.01
/ G0 i$ B( G; T% i/ u4 W5 S H1st Shift ConverterHubei Shuanghuan Science & Technology Co. Ltd.
( K4 t- r7 g! E3 q: E7 Y* l22第二变换炉φ3400×60×94753.445060.315CrMoR52.231湖北双环科技股份有限公司2004.01/ \0 k& d8 ^9 `2 a, }
2nd Shift ConverterHubei Shuanghuan Science & Technology Co. Ltd.
B5 O! Z$ A5 p5 T( W23第三变换炉φ3600×20×181203.4300(上)/ 260(下)15515CrMoR101.51湖北双环科技股份有限公司2004.01
3 T* O2 c* _( O+ A j3nd Shift ConverterHubei Shuanghuan Science & Technology Co. Ltd.( D9 q9 u% P! T9 E! }' i
% x' ^! A7 q% f5 ]5 B. e( b
24甲烷化炉φ3200×50×81852.94204315CrMoR31.521湖北双环科技股份有限公司2004.01
6 n, A/ Z* g1 E; y* t: T7 X0 _Methanized ConverterHubei Shuanghuan Science & Technology Co. Ltd." @2 |/ S$ t5 U2 G& N9 T0 V
25第二中温变换炉φ4200×(78+3)×164004.135010815CrMoR+0Cr18Ni10Ti
/ g1 {# f7 n- j, ~' [! u: L, m2 Y复合板 cladding plate1121中石化金陵分公司2004.11# P/ g- R4 B7 h1 Y6 i
2nd Middle Temp. Shift ConverterSINOPEC Jinling Company8 }( i. B( q6 H+ r# I6 S; r* I
26气化炉φ3800×(82+4)×172164.842525SA387Gr11CL2+316L E4 q# U/ d n/ G) P. l3 |
复合板 cladding plate1423中石化金陵分公司2004.11/ i, N; g4 D: ]+ }" U
GasifierSINOPEC Jinling Company1 T: b; X0 @9 _0 Q& n
27第一中温变换炉φ4190×(50+5)×174004.147012215CrMoR+0Cr18Ni10Ti
! S" K5 Z4 ~/ D2 h7 E: `9 B6 t% t复合板 cladding plate1331中石化金陵分公司2004.12
7 S4 h: f1 R h" n: p, Q8 X6 k, e1st Middle Temp. Shift ConverterSINOPEC Jinling Company
+ O4 d9 D' S( F3 K/ E$ N8 ^6 \28气化炉φ3800×(140+6)×183509.542725SA387Gr11CL2+316L
& ^5 f1 I, y& N7 \( `(堆焊overlay welding)2851南化大化肥2005.02
# B% k. Z! v' X+ v% _* i0 Q% eGasifierNanjing Ammonia-Urea Plant! F8 g! }0 I) G/ p5 W$ H/ b
29黑水过滤器φ800×(38+3)×290010.23000.66m316MnR+SS2507" P+ O# ~5 _! B0 |8 p; k
复合板 cladding plate, }. Q) q8 w& [4 g9 ]2 N1 N# r
6.61×22南化大化肥2005.051 S& B( N; e$ S5 i9 B1 A: b, e+ q
FilterNanjing Ammonia-Urea Plant
4 {- _9 A) U0 I; }/ e! ?30文丘里管φ526×(30+3)×80259.53051.85m316MnR+SS2507, o1 [$ ^& k# `; s% {
复合板 cladding plate
. N0 k& G' _; \8.651南化大化肥2005.06
6 F. c& U: `! q8 H7 y6 [Wen Qiuli PipeNanjing Ammonia-Urea Plant p) }, p, G+ u3 y2 ?1 n
31锁斗φ2600×(180+6)/(160+6)
& \4 D- p: [& N# }×83509.7/-0.129031.8m316MnR+316L& O7 m# J$ Y# Y( I% Q' a% a; U
(堆焊 overlay welding)931南化大化肥2005.11
+ J, g1 b2 l* }8 dLock DipperNanjing Ammonia-Urea Plant
9 M4 ?& x$ G! c6 [" v) H' ^32碳洗塔φ3500×(104+3)×213009.3300 13MnNiMoNbR+316L
# a. z$ ]- C9 h9 n0 w+ ^: i复合板 cladding plate' ?$ [& p. a: ~2 B8 K# ~6 I
169.61南化大化肥2005.11. n/ p* Q# d0 O3 p( v& l) w
Carbon Washing TowerNanjing Ammonia-Urea Plant
1 R/ P8 m5 k0 Y' X# a33气化炉φ3800×(140+6)×183509.542725SA387Gr11Cl2+316: [3 |3 d0 H) e" J! _. i6 v
(堆焊overlay welding)2851南化大化肥2005.11, j% K. a! Y) F2 l
GasifierNanjing Ammonia-Urea Plant7 x- Q$ Z/ y1 p7 A; H P; w$ ~
34锁斗φ2600×(180+6)/(160+6)3 v9 W% F5 i7 Y D. k/ g) b
×83509.7/-0.129031.8m316MnR+316L# Y6 f) |5 L% {9 l( R6 X
(堆焊 overlay welding)931南化大化肥2005.11$ r( H2 N9 s& t% { \% I: @
Lock DipperNanjing Ammonia-Urea Plant6 U8 @3 ~9 w5 R2 j) Z6 {: K7 L5 [
35碳洗塔φ3500×(104+3)×213009.3300 13MnNiMoNbR+316L
: t( [7 c2 b* X, i! ]+ h复合板 cladding plate; w9 X u; k: K& Z! J
169.61南化大化肥2005.11
- c& w2 M. U% H* f$ GCarbon Washing TowerNanjing Ammonia-Urea Plant
- ?7 }" d3 i1 n% ?" Q4 `36CO2分离器φ600×8×35891.0/FV-35/90 16MnDR0.551南化大化肥2005.11
/ Q) a2 t# Y& r/ |CO2 SeparatorNanjing Ammonia-Urea Plant3 }6 C' n, v* G1 C
|+ S3 e4 d5 Q/ R" \* X8 v' N37CO2冷量第二回收器φ500×10×5555壳S: 0.5/-0.1壳S: -45/120 壳S: 09MnNiDR2.211南化大化肥2005.11+ b) n( V$ }8 K$ W, V% B
CO2 Cold 2nd Recovery Heat Exchanger管T: 8.6管T: -45/120 管T: 09MnDNanjing Ammonia-Urea Plant
# K6 d$ U& j6 [+ y& l; p38预塔冷却器φ600×10×4442壳S: 0.9壳S: -70/50 壳S: 09MnNiDR3.341南化大化肥2005.118 T3 _7 Q% {. V* D: a
Pretower Cooler管T: 9.4管T: -70/50 管T: 0Cr18Ni9Nanjing Ammonia-Urea Plant2 L2 l. Q9 p% d* q R5 }5 K- i6 {/ C
39预洗塔塔底深冷器φ1600×16×9786壳S:2.45/-0.1壳S: -45/70 壳S: 09MnNiDR12.88×22南化大化肥2005.11
- m" s9 S T3 }" |% a1 V6 {4 S) bPrewashing Tower Bottom Cooler管T: 9.4管T: -45/70 管T: 09MnDNanjing Ammonia-Urea Plant
2 {: |# A/ C$ H' y" }- d40气化炉φ2794×86×181007.1542512.7m3SA387Gr11Cl2128.6×33上海惠生南京化工有限公司2006.05
# H% j B4 B0 ~: y6 I; QGasifierShanghai Huisheng Nanjing Chemical Industrial Co.
- G/ t( `9 i) z( H# k41锁斗φ2200×(110+5)×57087.429013.9m316MnR+00Cr17Ni14Mo2
2 i. K6 x% B) M1 _: j32.81上海惠生南京化工有限公司2006.05
: z5 e) \+ ^3 X/ h$ L% E" sLock DipperShanghai Huisheng Nanjing Chemical Industrial Co.
) n2 f5 Y/ [) |3 Y3 @: b U% ^42洗涤塔φ2800×(90+4)×183437.15/F.V280 16MnR+00Cr17Ni14Mo2
- S# M# K5 ^! T9 g2 ^: P1061上海惠生南京化工有限公司2006.05' w n2 F/ g/ s, I+ }8 L* n# i
+ R" ]4 c4 Z! v1 WWashing TowerShanghai Huisheng Nanjing Chemical Industrial Co.
% a, |3 D/ M+ t b4 I4 Q43气化炉φ3200×100×181007.1542525.5m30 O* t# v f: A7 [) |+ w- U! Q/ R
/~90m2SA387Gr11Cl2211.4×33兖矿国宏化工有限责任公司2006.05# R$ y- z* p8 T" e$ a
GasifierYankuang Guohong Chemical Industrial Co.
! d7 @ z/ t6 s% H" j" x44水洗塔φ3200×(72+4)×228526.9280128m313MnNiMoNbR+316L1 k, q% ?% j- Z
复合板 cladding plate, e y' @+ g$ x6 ~
1221山东华鲁恒升化工股份有限公司2006.07
7 S5 f( w U1 b- HWater Washing TowerShandong Hualu Hengsheng Chemical Industrial Co./ ]2 j6 w) c1 s) G. u9 S' ?
45第三变换炉φ3600×132×144506.748097.6m3SA387Gr11Cl21311山东华鲁恒升化工股份有限公司2006.09
W. B( R: H7 \, [, ]0 g, M8 ]3rd Shift ConverterShandong Hualu Hengsheng Chemical Industrial Co.
, }; ?. Q! B( e7 D' r" M46第四变换炉φ3300×80×111006.733053m3SA387Gr11Cl2531山东华鲁恒升化工股份有限公司2006.09/ v' a7 D9 L. e/ l) ~& ?
4th Shift ConverterShandong Hualu Hengsheng Chemical Industrial Co.& t; \: a; r- G" s
47T3001变化气甲醇洗涤塔φ2200×60×635006.6-45/60(bottom)
3 X/ e. D: a. V% @5 r9 L-80/60(top) 09MnNiDR2011上海惠生南京化工有限公司2006.081 E) N/ _. `3 o; }
Shifted Gas Methanol Wash ColumnShanghai Huisheng Nanjing Chemical Industrial Co.
9 i# K/ b8 q2 a% B# E6 b48T3002未变化气甲醇洗涤塔φ2400×68×577206.6-45/60(bottom). g" |; N4 [+ Z4 Y/ y a) x: [) |
-80/60(top) 09MnNiDR3001上海惠生南京化工有限公司2006.08
5 E7 R. S0 W" M# IUnshifted Gas Methanol Wash ColumnShanghai Huisheng Nanjing Chemical Industrial Co.
/ X9 K a2 T8 \: V: M49T3003H2S浓缩塔φ3400×14×577200.4-80/60 SA203 Gr E1401上海惠生南京化工有限公司2006.08
# g r9 l: y: f$ UH2S Enrichment ColumnShanghai Huisheng Nanjing Chemical Industrial Co.* [( H/ K5 _+ V7 w
50第三反应器φ2200×(50+3)×13611 m315CrMoR+0Cr18Ni10Ti
2 G5 |4 r( B8 }, h) g6 w! O27.31上海惠生南京化工有限公司2006.11) x5 z# l1 B) k. t) {" ]8 O
3rd ReactorShanghai Huisheng Nanjing Chemical Industrial Co.
! B4 }. T7 m* {/ G3 K51第一变换炉φ2400×(58+4)×85324.0848521m3SA387Gr11Cl2+347331河南中原大化集团有限公司2006.11
]: d7 g5 q0 C$ c1st Shift ConverterHenan Zhongyuan Dahua Group Co., Ltd.. o, X& S/ k' ~" N
52第二变换炉φ3600×(62+4)×110004.0842061m314Cr1MoR+304L511河南中原大化集团有限公司2006.113 }9 g) O @4 Y. Z3 |0 t! Z3 h
2nd Shift ConverterHenan Zhongyuan Dahua Group Co., Ltd.
+ H4 I* C4 [& G% h4 |8 s3 C53第三变换炉φ3800×(62+4)×120004.0837079.5m314Cr1MoR+304L581河南中原大化集团有限公司2006.11
$ C) L* Q$ h% G. \3rd Shift ConverterHenan Zhongyuan Dahua Group Co., Ltd.5 Z" h% Z& Y+ D: k
54硫保护器φ3000×(120+4)×948510.126039.5m3SA387Gr11Cl2+304L701河南中原大化集团有限公司2006.11& c% |" u* T% ~, s
Sulphur Protection ReactorHenan Zhongyuan Dahua Group Co., Ltd.3 Z% k e- S* q z
55煤粉锁斗φ3200×(65+4)×13468壳S: 5.72壳S: 15075m316MnR+00Cr17Ni14Mo2( {: \! ?' Q* p5 G
62.2×22河南中原大化集团有限公司2006.11
" r4 t$ `( d ^( }& gCoal Powder Lock Dipper盘管Coil: 0.7管T: 195Henan Zhongyuan Dahua Group Co., Ltd.7 V# I, G6 |/ D; _2 t& L
56排渣罐φ3000×(60+3)×104755.72/F.V15042.5m316MnR+00Cr17Ni14Mo2; n+ {7 Z" ?8 y/ M% y
36.71河南中原大化集团有限公司2006.11 c, M4 o: h3 z# ^6 x7 ~5 y; Y
TankHenan Zhongyuan Dahua Group Co., Ltd.1 ^, h: E3 _- n( r6 K* l4 c
57渣收集器φ3600×(70+3)×124305.4/F.V15068.6m316MnR+00Cr17Ni14Mo2
& k* ~8 T0 \ Q- K55.91河南中原大化集团有限公司2006.11/ h' C; [" I) F, G- S3 e4 B5 W
Residue Collection TankHenan Zhongyuan Dahua Group Co., Ltd.
+ O& `) n0 o; t; W" B7 t) \7 B58合成塔出口气体水冷却器φ1250×62×20000壳S: 16.275壳S: 95/-71783.4m2壳S: 13MnNiMoNbR
! m- K X* T; R, [# I3 Z' v) t, Q901河南中原大化集团有限公司2006.11
# a, ?1 w/ B5 J6 t. kConverter Outlet Water Cooler Preheater管T: 0.7/F.V管T: 70/-7管T: SA179Henan Zhongyuan Dahua Group Co., Ltd.
& {4 _* |& D) B& L* v" M1 x# P- [0 G2 w59甲醇分离器φ2600×(80+4)×107158.512045.3m316MnR+00Cr19Ni1055.92上海焦化厂2007.04: \( d% s2 L& V5 C1 j& a
H.P.SeparatorShanghai Coking & Chemical Complex
; [* S9 C! Q5 m3 [1 w60碳洗塔φ2800×(72+4)×195364.8/-0.134370m316MnR+00Cr17Ni14Mo284.54上海焦化厂2007.042 i, j5 {6 q( I* Y% ]
Carbon Washing TowerShanghai Coking & Chemical Complex
. P. O( G ?+ @* K! `& c61超高压氮气/CO2缓冲罐φ3700×120×240009150 SA516Gr702401河南中原大化集团有限公司2007.048 g2 o, K* u" J1 }7 {
Super High Pressure Nitrogen/CO2 Buffering TankHenan Zhongyuan Dahua Group Co., Ltd.4 G/ M( h6 v$ j
62气化炉φ3200×72/φ3792×(82+4)×174104.8425 SA387-11-2+316L7 J- C: r$ t; q/ h8 S3 g
(急冷室堆焊不锈钢 overlay SS in chilling room)136.23内蒙古伊泰煤制油有限责任公司2007.05. y, |2 y( M' @0 Z7 p
GasifierNeimenggu Yitai Co., Ltd.6 l6 n% C6 X/ A/ R( i/ B5 |# H5 _7 e/ I
63甲醇塔φ3600×(130+5)×4550/φ3600×130×78509.5340153m3SA387-11-2+316L堆焊/SA387-11-22221内蒙古新能能源有限公司2008.01
/ E7 t: N3 s/ o3 F# g, n4 mMethanol ConverterNeimenggu Xinneng Energy
0 `& O5 X$ i/ ?' F0 |9 K/ v" rCo., Ltd.! t S3 B( i$ r$ D
64气化炉φ3800×(112+6)/φ3200×100×199737.1542525m3SA387-11-2+316L
8 N! R' `5 _; J7 H/ Y$ |(急冷室堆焊不锈钢 overlay SS in chilling room)2353内蒙古新能能源有限公司2008.01
- `/ W% U6 A, ~/ @1 \4 W7 V k2 U+ lGasifierNeimenggu Xinneng Energy
# ^3 {2 ^3 l+ x# J' @( FCo., Ltd.
5 k9 Y9 W* a) h$ r- P4 }65变换炉φ3600×(140+5)×136607.1480100.7m3SA387-11-2+316L堆焊1581内蒙古新能能源有限公司2008.01
3 b; K* B" Z5 \3 B! [Shift ConverterNeimenggu Xinneng Energy
, Z" A+ m( V$ A' g& ~7 tCo., Ltd.! k+ K/ x0 w, [ f! U7 p
66气化炉φ3880×86×12060/φ3800×(86+6)×112017.15425 SA387-11-2+316L/309L
s. h2 b" R2 q* y" L' @ h- ^. s(急冷室堆焊不锈钢 overlay SS in chilling room)2452江苏灵谷化工有限公司2008.04; Y) j1 x* y- W# |
GasifierJiangsu Linggu Chemical Industrial Co., Ltd., z: z2 J9 Y, y8 E3 ]( X0 E
67气化炉φ2794×86×/2794×(86+4)×171527.15/F.V425 SA387-11-2+316L/309L& C, M) P2 J2 Z( {+ ?
(急冷室堆焊不锈钢 overlay SS in chilling room)126.943上海惠生南京化工有限公司2008.05
: l; P- [0 f/ T) P' ^+ aGasifierShanghai Huisheng Nanjing Chemical Industrial Co., G1 W/ e% b( q- ]: \+ X) S* }
68锁斗φ2200×(110+5) ×57087.429013.9m316MnR+00Cr17Ni14Mo2
5 s$ U9 x$ l [, m# N$ z(堆焊 overlay welding)32.83上海惠生南京化工有限公司2008.05
6 y; I' f& w" WLock DipperShanghai Huisheng Nanjing Chemical Industrial Co.4 ~1 z) a- k1 q+ A" q$ [# C
69变换炉φ2400×(66+5)×109986.846527m3SA387-11-2+堆焊overlay402上海惠生南京化工有限公司2008.06
g% i5 |7 g' n% D, HShift ConverterShanghai Huisheng Nanjing Chemical Industrial Co.
7 z6 s* T- i0 [ r) ^70气化炉φ3200×100×5877/3800×(112+6)×84747.15425 SA387-11-2+316L/309L
3 s! V* R" C& F8 S(急冷室堆焊不锈钢 overlay SS in chilling room)2304神华包头煤化工有限公司2008.08/ C& T& H4 {; R; }" j, s7 T, ]
GasifierShenhua Baotou Coal Chemical Co., Ltd." A, s) S1 y$ [. M7 ^- N
71变换炉Φ3200×(82+6)×107246.6450 SA387Gr11Cl2+welding overlay堆焊 347H67.061江苏索普(集团)有限公司2008.08
1 I, y1 I% z8 ]3 z; uConverterJiangsu Sopu (Group) Co. Ltd." a/ L- n# A8 o# s% I7 u
72气化炉φ3200×100/φ3788×(120+6)×198807.1542525.4/~90m3SA387-11-2+316L堆焊245.53陕西咸阳化学有限公司2008.12* n1 F7 j2 J& _" v! o
GasifierShanxi Xianyang Chemical Co., Ltd.4 H3 N! f. k8 r0 ]) z! j
7 Y: V m7 K1 q% S% }' V
73变换炉φ3800×150×175506.9480137.4m3SA387-11-2205.261陕西咸阳化学有限公司2008.12- x' M8 b4 s. s8 G
Shift ConverterShanxi Xianyang Chemical Co., Ltd.
4 U4 L9 G' P% H$ E3 m74气化炉φ3200×95/φ3188×(95+6)×204837.15425 SA516-70+堆焊overlay2003华陆工程科技有限责任公司2009.068 \# q4 J- y; I8 B& F- x/ x% z
Gasifier
3 R* X2 @7 B3 o, W; {) H8 R75锁斗φ2200×(115+6)×74907.3280 SA516-70+堆焊overlay483东华工程科技股份有限公司2009.1/ N" ~/ s% v% T! [7 `1 f+ O
Lock Dipper 8 g: o" \' S2 T. r R: T1 P
76洗涤塔φ2600×(76+4)×213806.9280 SA516-70+316L1013东华工程科技股份有限公司2009.1
) x7 m, Z! F" ^8 p+ B
4 I$ f. x; y' _% t- KWashing Tower 9 t/ f1 a0 b0 y" A
77高压锅炉给水加热器0 J* V1 M7 F; n& X# [
φ1200×78×8610壳S: 18壳S: 180590m2壳S:16MnR40.371上海焦化厂2008.12
4 u2 n1 { q2 P! {4 T
+ N. J8 Y* B6 N& v/ NH.P. Boiler Water Feed Heater管T: 4.6管T: 210管T:20gShanghai Coking & Chemical Complex
& m* E9 X0 b1 ]2 @( O" B
7 u9 e8 ]; w( T* Y& [2 v4 D[ 本帖最后由 wch5557250 于 2009-5-5 14:25 编辑 ] |
