查看: 1428|回复: 0
[讨论] 这样的NC在G17平面螺旋走圆弧吗?
发表于 2009-5-28 20:31:50 | 显示全部楼层 |阅读模式 来自: 中国上海
这样的NC在G17平面螺旋走圆弧吗?: v3 k/ c; ?' p7 M
7 j0 V2 J0 Y% F+ W5 N%
5 F9 c3 `2 M2 E2 t+ W/ `(PROGRAM NAME: lgj.NC, Thu May 28 19:59:08 2009)+ C1 A# B% z. O
(后处理创建人*刘公军*测试阶段请同仁多批评指正)
1 n0 h5 P% e9 p(请阁下在每次加工前检查刀号,刀补。既刀具大小正确)4 ?3 s; \( o% Q( x
% C! W; }7 L; {* a$ p; S(                                   T O O L   L I S T                                           )
( ~& L& q$ Q' ~* U, V3 q(===============================================================================================)" N  `; v. ^, }! O+ }6 |6 H% Y
(        ). B% h7 w0 m4 h1 I" w; E' e
(-----------------------------------------------------------------------------------------------), n5 _/ K8 c) D  s: u
(MILL                 DESCRIPTION          DIAMETER   COR RAD    FLUTE LEN  ADJ REG             )6 j' F% Y+ _, ?& _4 Z# z$ j% w* ^
(-----------------------------------------------------------------------------------------------); J7 K, I, T' ^4 n9 c% r
(D10                  MILL                 10.0000    0.0000     50.0000    1         )
4 Y: s" f/ P" x/ u  F(===============================================================================================)
+ l' W6 \& q' Q6 [7 ZG40 G49 G80 G90# o0 m: t  I* q3 |$ e# E
G91 G28 Z0.0) A. y3 P; N# H6 A3 x
T01 M06
9 K! B' }9 r1 t3 @6 Q4 }G17 G0 G90 G54 X4.016 Y-6.642, R0 o- f; J+ ^( C% A
S3500 M03! a, f8 m) O* _8 J2 q; O" I- u3 D
G43 Z20. H01 M08( R) U6 r( y9 W( ^" {8 R" w
G1 X4.016 Y-6.642 Z20. F1000.4 R, O7 a. F( l% n! O/ l
X4.016 Y-6.642 Z14.1011 G: c5 @6 T( Y6 s* d$ g
G3 X4.016 Y-6.642 Z13.114 I-1.993 J4.035 K-.157 F500.
& i. l5 m# c/ h% \! f. D$ KX4.016 Y-6.642 Z12.127 I-1.993 J4.035 K-.157
  }) u5 q& P$ I5 [' XX-.736 Y.948 Z11.601 I-1.993 J4.035 K-.1577 l7 {. b; I! `+ \6 Y
X-1.2 Y0.0 I.736 J-.948 F1050.6 g' s! r# }0 Q
X0.0 Y-1.2 I1.2 J0.0
) E0 t1 A+ j& p" P9 M/ }* t. GX1.2 Y0.0 I0.0 J1.28 v. c8 u- v$ h# Q# H
X0.0 Y1.2 I-1.2 J0.0
- I6 S! M) S1 o2 I; g3 o! n, v) D& mX-.736 Y.948 I0.0 J-1.2$ s+ p" j7 {4 z2 v3 h
G1 X-3.801 Y4.898 Z11.601 F2500.
+ b; s3 D& e3 g, `G3 X-6.2 Y0.0 I3.801 J-4.898 F1300.
5 x0 j# {. f* i. G: TX0.0 Y-6.2 I6.2 J0.0
- c/ m9 {( T; Q" {3 r0 @9 AX6.2 Y0.0 I0.0 J6.2% S' i3 k/ P$ [; y
X0.0 Y6.2 I-6.2 J0.0
* Y4 w3 d, a( N* e0 w" pX-3.801 Y4.898 I0.0 J-6.2
& z4 N+ {' k8 O0 U0 s, [G1 X-6.866 Y8.848 Z11.601 F2500.
