楼主 |
发表于 2009-7-30 20:51:09
来自: 中国浙江温州
: W; b* Q* w+ P, |7 c3 B7 Q5 q
+ h5 H0 \$ Z2 E$ ~, w
, \: i7 \. [# r1 N2 L我也联系了美国的制图者,刚收到他的回复,基本和上述仁兄的分析吻合。 现分享下他的回复内容,如下:) x' _* B2 q- Z; w
) I r9 ~1 Y' l+ Z“$ z% X: I, U0 N1 T, o
Hi XXX,
& B& y0 U% U1 D- R4 W. o: u5 ~4 w9 Q' Y" G. U
! H, a( o) T8 E1 PAccording to ASME Y14.5-1994 para. 2.5, single limits dimensions such as those indicating MAX or MIN:
! t' ]( ?" j2 b+ L9 E
7 F* b; L% |1 v0 W4 @: _ l2 x( q/ R0 R6 O: _
“Single limits are used where the intent will be clear, and the unspecified limit can be zero or approach infinity and will not result in a condition detrimental to the design.” n- g5 M, ?9 s5 x6 G* z& d
0 [+ _/ O( G, g# _; p
% _! C( s+ _2 j1 d; ~4 @* u8 }
Therefore, the .0015 max. radius or chamfer on drawing does not require a radius or chamfer, and the edge can be sharp, but if a radius or chamfer is present, it must not be any larger than .0015 [0.038 mm].( q1 X1 s! G7 I) x5 A
7 \- ~! u% Z& m) t1 j6 C( E/ K n2 o P4 `3 ^5 U
I hope this answers your question, but if it is still unclear let me know and I will try to explain further.
( \+ V6 E( B0 Q* R
) w k# ? }( O3 S9 L: F1 Y+ {
* d9 u& h5 I1 w8 [9 g e N4 j/ f1 X5 uThanks# V* Q# \! r) O e; s$ H
XXX
' a3 L W! C n; K3 \”5 V, d/ ?) u5 y- L$ t
M4 c+ Z- r' B' w
谢谢大家的关注!7 d/ K6 |( N/ U1 Q" w) ]& T# U |
6 |; S0 [% @2 J4 Y
[ 本帖最后由 wangyanwei 于 2009-7-30 20:53 编辑 ] |
