查看: 1342|回复: 0
[环境科学] 含氧化铁粉粒状脱硫剂的脱硫性能研究CAJ【期刊文献】
发表于 2009-9-3 09:51:51 | 显示全部楼层 |阅读模式 来自: 中国上海
含氧化铁粉粒状脱硫剂的脱硫性能研究2 \: s8 x5 V7 V# t' P
张佩芳,黄学敏
% p# Q9 _7 Q, y- s  b(西安建筑科技大学环境与市政工程学院,陕西西安710055)
) g; d; H2 x, P- b- ?& ?' I; s摘 要:干法脱硫由于其脱硫剂利用率低而未达到广泛的应用,为研究高效的干法脱硫剂,在干法粒状脱硫剂
3 X: W1 Q' _( f中加入金属氧化物Fe2O3作为催化剂,通过实验确定直径、蒸汽活化、加湿和加入Fe2O3粉对脱硫剂脱硫速率& i0 Z9 w# }- @' d- n
及钙利用率的影响,从而确定Fe2O3粉的催化性能并初步分析其催化机理.由曲线图中曲线对比可得,Fe2O3' Y0 p2 w0 K3 @( L6 e5 b6 F
粉的催化性能与其投加量有关,少量Fe2O3粉与过量Fe2O3粉对反应的促进作用不明显,所以存在最佳的添加" \( |: ]9 U% Z- d, p# N
量,由实验可得其最佳添加量在总质量的1.5%~6%之间.
, l0 ?! B: @# }8 S6 D关键词:粒状脱硫剂; Fe2O3粉;脱硫速率;钙利用率
- v/ L( [! W1 |& a中图分类号:X511       文献标识码:A       文章编号:1006-7930(2004)02-0163-03  1 z5 m, ?  U* o# p' L6 ^
The research of dry SO2absorbent with Fe2O3
' Q% I6 v$ b! P/ @* M- bZHANG Pei-fang,HUANG Xue-min& M; |) b& m2 q
(School of Envi.And Muni. Eng., Xi’an Univ. of Arch. &Tech., Xi’an 710055 ,China)/ U# h' h  A- Y6 _& ?% \
Abstractue to its low efficiency, the method of dry desulphurization, cannot be widely used .In order to get high5 f4 a$ c& h9 C) j! }% b8 L  C8 f+ S
active absorbents, the metal oxide Fe2O3is mixed with absorbents as the catalyzer .By experiments the effect of particle: @5 k: G! e5 }' F
diameter and steam activation, wetting, Fe2O3on desulphurization velocity and calcium efficiency is defined.So is derived
/ `, K$ V1 g/ _the catalysis of Fe2O3is derived and primariy analysis on the catalytic mechanism is fulfilled. From the figures the% n/ g$ T/ v* N" s! f9 B2 G
catalysis of Fe2O3is connected with the quantity is obtained. Less Fe2O3and more Fe2O3cannot promote the reaction.$ J+ {; o  W3 e- Z8 _$ W/ ?0 Z. d
The optical weight is caught between 1.5% and 6% of total weight from the experiments.
) i5 `9 P: v! t7 y9 @# }& i! OKey words:columnar SO2absorbent;Fe2O3;desulphurization velocity;calcium efficiency
含氧化铁粉粒状脱硫剂的脱硫性能研究.rar
35.56 KB, 下载次数: 5
武昌鱼 + 2 好资料,感谢您对论坛的支持!
