发表于 2009-11-1 11:17:40
来自: 中国江苏常州
By fine-tuning the characteristics of the joint between the bearing and the housing, the tolerance ring helps reduce the vibration within the bearing, which reduces noise.6 @- d5 y5 I3 d! r# s" i' x6 E, b+ B
: b' a9 L4 r0 R) w! _-------------
0 N9 o2 \* K) y, ]- u& VThis mounting has a positive effect on the electric motor and bearing life, enabling it to run quieter and smoother for longer.
" j& [+ v6 p- M2 H1 \ V: p6 R7 ^$ T8 e* g- h% L" d7 H
