发表于 2006-1-2 10:29:00
来自: 中国浙江温州
This is a CAD AutoLISP developing sample. save it as "chamdim.lsp" in folder "c:programe files\autocad 2000\support\" ,on autocad toolbar do rightclicking,select "custom",add a button ,define it with command "^C^C(load "chamdim")dimchamfer".then click this button,you will dimchamfer as you want这是一个CAD AutoLISP开发样板,在文件夹"c:programe files\autocad 2000\support\"另存为"chamdim.lsp" ,在工具栏上右键,选择自定义,添加一个按纽,用命令行"^C^C(load "chamdim")dimchamfer"定义它,之后你再点击它时,你用可以随心所俗欲的标注倒角 1 N. a. k0 U3 j5 E3 ]4 X
9 j9 B2 h$ V. l9 ?( o[ 本帖最后由 bbsjava 于 2006-7-1 10:42 编辑 ] |
