查看: 1489|回复: 2
[已答复] 美标焊接链的标准
发表于 2009-12-29 13:30:02 | 显示全部楼层 |阅读模式 来自: 中国上海
发表于 2009-12-29 14:17:00 | 显示全部楼层 来自: LAN
A391/A391M Specification for Grade 80 Alloy Steel Chain% r8 c' M- I+ t! V% i" ~9 r" C
' O  u! L4 k" w- j' @
A391/A391M Specification for Grade 80 Alloy Steel Chain 4 ~! c4 R# z7 f
0 r3 Q( `+ `' R' @4 F3 e) G
A906 -02 Standard Specification for Grade 80 and Grade 100 Alloy Steel Chain
5 f6 n$ i$ S+ h& z+ p8 S3 r( u- z4 d/ q6 v$ Y* q% j% }" e2 t6 ]6 N
a952/a952m-02 standard specification for forged grade 80 and grade 100 steel lifting components and welded attachment links
! ?1 I: V- j4 v6 d+ l8 @6 i
# i3 b. J. ~3 {( M; v  j8 HA413 -07 Standard Specification for Carbon Steel Chain , chain, steel chain, Building materials/applications--specifications, Carbon steel
3 J9 w& G2 m+ R8 L5 s( v6 D: z3 d5 j) }+ J. u% A; i8 l
ANSI/ASME B30.9-2003. Slings( ]; q: ?/ {/ T/ i- s7 F
, L, k3 Q, m9 y& {& }
A973 -07 Standard Specification for Grade 100 Alloy Steel Chain
 楼主| 发表于 2009-12-29 16:46:23 | 显示全部楼层 来自: 中国上海
