查看: 3327|回复: 12
[求助] MCX3四轴加工图例
发表于 2010-6-27 22:04:44 | 显示全部楼层 |阅读模式 来自: 中国浙江台州
6 j1 @" ~2 k: {" a; _6 N
6 |. [, ~0 g- L; P1 }下图为加工刀路
2 m' ?# A; U  X$ X7 Y# X4 o. F和程序    出来的程序老是没有旋转轴
2 Q5 {3 l# g; w7 Y, p后处理也换了很多了
* U1 s" f6 u0 ?6 P7 X! A我用的是卧式机床  四轴联动   西门子系统  机床不能识别360度以上% j4 C( }7 \: b  Z5 O+ R
用四轴卧式的可以发过后处理分享下吗" b- ]  z& M; m
N100 G21' e( ]( q, G  ]- D) e, Q& u
N102 G0 G17 G40 G49 G80 G90# E: C3 S( n, s2 F
N104 T1 M6* g0 x; Z, _. z3 l
N106 G0 G90 G54 X-14.492 Y-6.743 B0. S0 M5- X9 q- b2 p7 W0 P
N108 G43 H1 Z70.684
! Z6 [! K1 p/ L0 s" I! W! I5 CN110 Y-1.957 Z25.939
0 Y2 I, i: B% nN112 G1 Y-1.425 Z20.967 F0.
9 Y# T. a3 E/ x0 KN114 X-14.491 Y-1.424 F.3
; A) F) z5 ~5 ]* h: ~; Z/ U- XN116 X-14.475 Y-1.412
+ F% c+ Z. ]: ~" j6 W4 Y6 x8 o* L* TN118 X-14.46 Y-1.4 Z20.968( D( R, R; N4 Q1 I  k- E, @% M
N120 X-14.444 Y-1.387 Z20.969* i/ E. ]7 G7 g* k, {# {) Y8 J
N122 X-14.428 Y-1.375 Z20.97
3 `7 ]( q+ V" n% ~N124 X-14.412 Y-1.363 Z20.971' K( Z& B* w3 q) u( |
N126 X-14.396 Y-1.351# x" Q; p- ]. T+ @) S2 @
N128 X-14.381 Y-1.339 Z20.972
2 F* z! L) Z% [, X8 y& f/ y9 P6 `N130 X-14.365 Y-1.326 Z20.9734 W7 B% y8 n& W; s* a  m  @( K
N132 X-14.349 Y-1.314 Z20.974. Z0 @" t: W0 \5 Y! ]) Y2 Y) W; B
N134 X-14.333 Y-1.302 Z20.975
$ u3 j* _9 _$ H1 eN136 X-14.317 Y-1.299 F5 W& r1 k! A. s2 A
N138 X-14.302 Y-1.277 Z20.976
9 O' y% `. _5 ]  SN140 X-14.286 Y-1.265 Z20.977" k: {- @& q$ n; Z& ~
N142 X-14.27 Y-1.2537 e3 o9 g- a  H$ l  t
N144 X-14.254 Y-1.241 Z20.978% O4 f2 D1 ]( D  O
N146 X-14.238 Y-1.228 Z20.9797 [7 U3 M. S* G& Z0 Y$ d4 P) {: o
N148 X-14.223 Y-1.216 Z20.98" J# x8 G+ J0 a9 q. e' X
N150 X-14.207 Y-1.204
& k7 d1 n: M; I, rN152 X-14.191 Y-1.192 Z20.981
' x% `* m: B6 r# a2 b% t7 FN154 X-14.175 Y-1.18 Z20.982
, Z! `/ Y+ H5 K% z  F) j& I4 c; R+ NN156 X-14.159 Y-1.167
& l- _) O( U; N: s% k3 Y. @N158 X-14.144 Y-1.155 Z20.983' D3 f4 y  e: T, r
N160 X-14.142 Y-1.154 Z20.981
# M6 @% i( r1 J2 FN162 X-14.138 Y-1.149 Z20.979
/ e- w1 }3 C  t" H# @* T) a3 cN164 X-14.125 Y-1.134 Z20.98; F) I/ ~4 C8 f" |8 ?; \2 u  o
N166 X-14.112 Y-1.119 Z20.981) X, \, Z9 V5 e0 |
N168 X-14.098 Y-1.104
5 Y$ m) H/ [  `0 I7 ^) D2 AN170 X-14.085 Y-1.089 Z20.982
! B" T1 t8 n- |1 SN172 X-14.072 Y-1.074 Z20.983+ f& w! R4 q) s
N174 X-14.059 Y-1.059 Z20.984
8 f- s  f4 C& `" z* X0 uN176 X-14.045 Y-1.044 Z20.985
3 z2 Q5 b0 v- c# o9 q5 Q: C2 AN178 X-14.032 Y-1.0293 _% @6 I8 _  B- h8 l$ i. v7 @
N180 X-14.019 Y-1.014 Z20.986
; h8 A3 G/ i0 k9 K/ W: @% _% r+ zN182 X-14.006 Y-.999 Z20.987& l0 d3 V; ]* I- r8 ?1 o; [
N184 X-13.992 Y-.9843 a; |1 G  [- r% }, i0 w
N186 X-13.979 Y-.969 Z20.988! v) E$ _8 L. s2 N: f+ R6 L
N188 X-13.966 Y-.955 Z20.989  [; A( b* L( [. g8 @
N190 X-13.953 Y-.947 L+ D3 M1 a( S$ G0 F1 U- _8 E
N192 X-13.939 Y-.925 Z20.99
6 ~/ B' j& x( `$ w! uN194 X-13.926 Y-.91 Z20.9918 D2 [4 S9 O% ]6 C, C
N196 X-13.92 Y-.903 Z20.989
: I5 y4 e: X! q/ T1 Y. r8 wN198 X-13.913 Y-.89 Z20.987
1 i7 Y5 S5 X& F/ |2 q2 r" H: hN200 X-13.903 Y-.873 Z20.988) i! J+ D" m* k. _. B
N202 X-13.893 Y-.855
6 x# N! U' u0 {( U' u6 ^N204 X-13.883 Y-.838 Z20.989
0 d) }  |' N# c3 K$ L& RN206 X-13.874 Y-.82 Z20.999 l* Z% h9 Q' y
N208 X-13.864 Y-.803! o/ B3 g9 u+ t3 V- [- _4 \
N210 X-13.854 Y-.786 Z20.991
4 I8 F% O9 B' JN212 X-13.844 Y-.768 Z20.992
3 p9 H; a4 D* J; ]N214 X-13.834 Y-.751
4 _! O$ N6 I( n. |9 J, aN216 X-13.824 Y-.734 Z20.9937 M/ D$ r. q* G) k
N218 X-13.815 Y-.716 Z20.994& a) h$ c# R" g8 n
N220 X-13.805 Y-.699$ l' }. m: D+ i' A+ G) Y! X% x( M
N222 X-13.795 Y-.681 Z20.9951 x& N: j; i" E1 k8 P( @7 @
N224 X-13.785 Y-.6646 k; x5 s7 {) `
N226 X-13.775 Y-.647 Z20.996
( K" k$ A) C8 W7 e& T" @N228 X-13.773 Y-.642 Z20.994
& `- A/ P$ R. h, a" X0 zN230 X-13.769 Y-.631 Z20.993* G) q9 s4 Z7 @9 h* r, {
N232 X-13.763 Y-.6125 j5 Q; z5 H- I; K) p$ u2 M
N234 X-13.758 Y-.593 Z20.9942 ?* y2 k: z7 d) s% v: ?
N236 X-13.752 Y-.574
4 N, L' z) I: m  ?& g& ]+ SN238 X-13.746 Y-.555 Z20.995
/ d( z3 f$ J0 x* vN240 X-13.74 Y-.536
- v8 M) b7 B  `) q" IN242 X-13.734 Y-.517 Z20.996
# @* A" F0 T1 z+ K$ Y4 s; g/ xN244 X-13.728 Y-.497% s9 p6 \) ?0 E0 B( q
N246 X-13.722 Y-.478 Z20.9974 l% ?  T) {8 W
N248 X-13.716 Y-.459
7 A  V% J' S: w4 |N250 X-13.71 Y-.44
( C' G. P+ g( p) j! i7 ON252 X-13.705 Y-.421 Z20.998  f3 _0 N! n1 F1 Q1 O5 Y
N254 X-13.699 Y-.402
& p4 o" Y$ Y* h* c% Q3 M( z3 N4 ~N256 X-13.693 Y-.383 Z20.999
* n+ D: ~8 _; c6 NN258 X-13.687 Y-.364
- V" {- U: O9 g" rN260 X-13.683 Y-.35 Z20.998$ b  m' z$ Q3 e2 N6 g
N262 X-13.681 Y-.333, t/ Y) `& b7 k; E+ L
N264 X-13.679 Y-.313; V: h  m" C+ |7 v6 p
N266 X-13.677 Y-.293
0 ?; H- u3 x( v, h) cN268 X-13.675 Y-.273
/ L; h5 m: V& U1 c- ?3 g! F6 \  AN270 X-13.673 Y-.253 Z20.999+ C% ]# \1 h  z% o% A% f! p1 l2 O
N272 X-13.672 Y-.233
, a0 T1 h1 Z1 nN274 X-13.67 Y-.213! {: a# @1 M; |5 w! g
N276 X-13.668 Y-.194
  R9 ?) S  a& Z; p  u$ x' U1 \N278 X-13.666 Y-.174
; q$ h. o/ d0 k1 oN280 X-13.664 Y-.154 Z21.6 c5 o3 Y1 F9 O+ D* ^2 l2 m. U0 h
N282 X-13.662 Y-.134
& S9 f  v/ x, U/ j$ z5 w9 c8 A) s0 V; o( D5 W& b# O
  A2 Y, G0 r4 o
下面就不复制了   都是这样的   没有旋转轴
ZXL.rar
201.43 KB, 下载次数: 79
 楼主| 发表于 2010-6-28 21:54:04 | 显示全部楼层 来自: 中国浙江台州
怎么没回应呢
发表于 2010-6-28 22:54:23 | 显示全部楼层 来自: 中国广东佛山
这个版本没有用过,帮你顶。
 楼主| 发表于 2010-6-28 23:16:34 | 显示全部楼层 来自: 中国浙江台州
期待啊    用过其他版本也差不多啊
发表于 2010-6-29 21:58:14 | 显示全部楼层 来自: 中国湖北襄阳
真吗没有人回应呀,路过顺便顶一下,呵呵呵!
发表于 2010-6-30 14:34:43 | 显示全部楼层 来自: 中国浙江台州
我的好像也不能用,,有时候在圆柱上铣个斜槽 只能用手编。。
发表于 2010-7-12 01:53:59 | 显示全部楼层 来自: 中国广东深圳
应该后处理没有选对吧
发表于 2010-7-14 11:02:13 | 显示全部楼层 来自: 中国上海
这后处理4轴功能没开出来,另外不能超过361度,要改后处理循环
发表于 2010-7-15 09:17:26 | 显示全部楼层 来自: 中国台湾
很寶貴的圖例,學習很多,小弟受用了!
发表于 2010-10-14 23:21:01 | 显示全部楼层 来自: 中国广东广州
边位有MCX4五轴教程
发表于 2011-3-26 21:48:03 | 显示全部楼层 来自: 中国江苏常州
多轴资料我多要
发表于 2011-3-28 17:52:45 | 显示全部楼层 来自: 中国广东深圳
" _; D9 X6 C; I, y* LO0000
& O0 C7 R. s' s5 H(PROGRAM NAME - ZXL)
, k+ [/ l! g; H" U2 U2 [(DATE=DD-MM-YY - 28-03-11 TIME=HH:MM - 17:46)/ b0 T! k! W; x7 U3 `" @
G215 Y9 z: _+ Z# B. z
  {: ^! F( d7 O0 A5 B5 Q( | TOOL - 1 | DIA. OFF. - 1 | LEN. - 1 | TOOL DIA. - 2. )- C( F+ N4 {9 A
T1 M6- i, T6 O4 a) H+ H# \
G0 G90 G54 X-32.679 Y1.051 A-317.609 S0 M5" c0 A  L2 q- U2 [' z/ [$ h
G43 H1 Z120.997 M8
9 m  x6 Y0 ^  C* A8 ~. x' b; f& ]Z22.997' v0 k7 d: l. U$ ]$ [3 p' L
G1 Z20.997 F0." T- n* _+ ~7 \  N* J0 b, k
X-31.256 Y1.206 Z20.994 A320.478* Q% Z. d& ?. J6 K! m1 x, W
X-29.767 Y.987 Z20.991 A324.302
2 Z- ~! s* _, h) J& l7 _2 IX-28.291 Y1.009 Z20.983 A327.378
5 v  N' @. z( B" nX-26.798 Y.991 Z20.975 A330.489
4 k6 W4 n8 Q+ P; F* H. WX-25.291 Y1.009 Z20.997 A333.449
# u7 x2 L  T& f. e* u* C, T. d5 SX-23.765 Y1.012 Z20.988 A336.4039 G# y* M! N9 n' ^  D9 x. n
X-22.232 Y.985 Z20.978 A339.385% Z" j' b1 x5 w
X-20.689 Y.962 Z20.998 A342.324% s) _( M  J% F; S% L! P: S& @
X-19.138 Y.931 Z20.989 A345.249  G9 J6 o; R8 C4 `, W
X-17.582 Y.899 Z20.978 A348.1516 E8 z6 `5 B' ?0 j9 e8 T0 U/ ~0 [
X-16.02 Y.87 Z20.997 A351.026+ f. m  m. ]& `3 l+ Z8 i- V/ r( N
X-14.457 Y.837 Z21. A353.892# F3 U1 L/ E0 X! q1 t- C) ?
X-14.042 Y.413 Z20.991 A356.097
4 y+ v: g2 ~8 N* h9 ~X-13.744 Y.153 Z20.985 A358.169, M2 @+ J9 F" S9 g
X-13.657 Y.005 Z20.983 A359.989 T$ U) ?9 l6 I: q! e7 G& c
X-13.748 Y-.182 Z20.985 A1.878, i# s1 H  i2 ^
X-14.05 Y-.491 Z20.982 A4.138  Z- u8 i4 l9 t5 u
X-14.505 Y-.804 Z21. A6.108
# U" _: Q! `% G3 G5 VX-16.02 Y-.886 Z20.997 A9.018
7 c. Y5 G2 W) M$ R+ j- v+ z- RX-17.581 Y-.926 Z20.978 A11.9246 G! a0 S6 ]) y- ^3 C9 f
X-19.137 Y-.973 Z20.988 A14.861
9 P  M( c! T# L3 L3 R  f2 T/ q" _' wX-20.69 Y-.986 Z20.998 A17.744
8 y) Y5 }2 k/ d* J/ k$ Y2 V4 CX-22.232 Y-1.008 Z20.977 A20.675/ y! E0 A8 @% [+ F
X-23.769 Y-1.023 Z20.988 A23.63
# E" Q: a5 ~; v  ]$ K; k: KX-25.292 Y-.999 Z20.997 A26.523
2 }+ K- c$ S" aX-26.803 Y-.973 Z20.975 A29.461
; E0 n; w  U2 A5 oX-28.3 Y-.918 Z20.985 A32.385, `/ y. g6 S  l) n
X-29.772 Y-.864 Z20.992 A35.372
1 l. M- |' C: f8 sX-31.226 Y-.849 Z20.997 A38.547# w6 U2 {( q, |* h' X4 `
X-32.648 Y-.762 Z21. A41.601
6 W( h1 y! E! wG0 Z23.
# r  Z! u$ G( U+ h4 ZZ121.
: j" ^4 \4 K* U. ?, I; K/ eM5' w: s7 R/ ^: Q$ M
G91 G28 Z0. M9- s! ?) T8 W; Z  }
G28 Y0. A0.* H6 _8 ^1 h! V
M30
) b6 n* x9 u! m  p' Q%
发表于 2011-4-14 15:48:26 | 显示全部楼层 来自: 中国江苏苏州
1,既然是四轴加工,就先检查图形坐标系是否和机床坐标系一直,接下来确认所选择的旋转轴是否和机床的旋转轴一致。$ q1 O% B$ J8 }. M- M3 S+ Z
2,确认后处理,是否是4轴后处理,有的老一些的后处理要回答164号问题,确认旋转轴是否起作用
