下面这里应该怎么修改 能是第四轴角度在0到360度
7 I; y/ ~; W: u
2 h1 l, t( M8 B* c8 M/ h/ v% q0 @9 ]3 Q0 q) ?. T5 Y0 d
& a: l! N6 z0 Y P
! |3 t3 }: ^& c4 q3 ppcoutrev #Rotary axis revolution calculation (Modify for wind-up)
+ B* b: l- E4 `' k0 Z; b if cir_at_zero = one,
% {8 ?5 I; D- Z% r [
! Q- C/ M* D6 h' k _5 h$ \ #Arcs at center position the c axis
& o- g! @2 E; K5 E if cuttype = -2| cuttype = three,& G/ w5 V+ y" W2 o& }9 a/ Z$ l
csav = czero_csav - sweep$
( E( G0 k8 X5 j: q5 \+ H7 l; H else, csav = czero_csav + sweep$
$ [+ n' }4 i# G1 V/ H, h czero_csav = csav
1 h3 \/ Q4 f4 M7 z. V) v ]
2 k( h" s2 U0 v3 c8 i: f$ b #C does not move going to CL; x" {( D, B& s
if pnt_at_zero, csav = prv_csav, a) E K! h. k7 X/ Z2 d' S0 Q
cdelta = fmtrnd(csav) - prv_csav #This calculates once, for rev
' F7 }: ~3 u% M' f while abs(cdelta) > ctol & not(cir_at_zero), #If motion exceeds ctol, add wind-up
9 V- D; G$ E9 R! S! S0 Q8 c [4 J S- z6 j, i
if cdelta > zero,
; V9 k5 |+ z* a, I" V! }; j' s [
D0 N+ x, R( q( K% z9 U1 w rev = rev - one! M2 T2 u) s2 X' {# t
cdelta = cdelta - 360
/ ~4 v4 j" q1 w Z! w+ g0 G ]& [( V- p9 c" F3 `1 s7 _$ `
else,
: e0 s, }8 [/ ~6 P- K9 s [! A0 `5 x; N2 }; X. l0 L0 v
rev = rev + one& d5 B5 T8 Y3 r
cdelta = cdelta + 3605 M' z; d# q' A7 ^8 I/ k- a, a
6 V+ ?% R2 `% R8 N' d( Y( \ ]/ E( C: _; b7 r: N3 Z- L
if cuttype <> four, c_wnd = rev * 360 + csav! g0 O4 f7 q) l; T
else, c_wnd = sav_rev * 360 + csav1 T l+ q8 }1 m9 n+ `3 @
!csav) S: c) ~9 d6 {; R
@c_wnd; \( U. r) n7 x! T$ x
#Now switch to c_wnd which is the absolute winding C calculation
2 R8 w6 F$ s$ [ #Modify for shortest direction if toolchange or toolplane
4 A9 R/ j& q7 k8 A, b #but not with axis subs
* @6 h4 A P X/ B5 O- ]* k# N if c_axistype <> three,
: F0 m4 J) V) K9 ~. h& a) J [
, @7 h% W1 v% _" j if abs(prvc_wnd - c_wnd) > 180
( c, `- V* x: A. `8 S! h & (toolchng | (y_axis & cuttype < four)),
; M& t# ^* j) X* q O( |: { [
3 z+ |8 n2 ], O9 J$ o7 m C while abs(prvc_wnd - c_wnd) > 180,
2 Z8 c8 o3 z# e4 Z7 r [7 C1 \5 l/ O9 A
if prvc_wnd > c_wnd, rev = rev + one: L% o/ q8 R$ G. H. k( Q0 R
else, rev = rev - one
- {$ {" m/ C# v% q- U% D7 d/ s c_wnd = rev * 360 + csav
6 [/ ]8 l' N# D ]
; s( l) m9 K" @' K. O8 u4 h @c_wnd) X9 ]7 S' b$ `6 m6 _* A# }
]4 v b( }3 R1 c P3 U
( Q, I8 N: i4 L1 Y, [* Npindxcalc #Index move calculations, direction is shortest exc. Asub
. @) ~- [& z: t5 D4 [ if pnt_at_zero | cdelta = zero, indx_mc = prv_indx_mc! T/ i( _( |7 W; z0 g$ S
else,4 d5 P' L2 D c
, f, F7 [" i8 r3 [6 v% j2 l3 u cdelta = fmtrnd(c_wnd) - prvc_wnd/ M- v4 K, W5 o0 G9 R3 Z6 v
if cuttype = four, #Just look at the direction3 z9 T8 A5 w2 e1 a* g
[- h% q9 b }8 m$ E
if cdelta >= zero, indx_mc = one( V M& z6 P8 Q' ^, O. G
else, indx_mc = zero( o# A7 |6 }. ?# U# @" W/ ?. V
% b! ~) Q( Z: Z+ {; c) S5 ~( T else,3 W: t/ {1 R: K8 Y1 Z6 g8 [% k
% Q/ E& }0 g2 O" d& _ b #Phase shift delta 10 revolutions, check odd/even for direction
2 K$ t1 g* H. s+ z5 U1 ] if frac(int((cdelta + 3600)/180)/two), indx_mc = zero& B; S! g, g( i2 h- c
else, indx_mc = one
/ b4 o$ D8 ]7 p s8 O2 K- B ]
4 ]/ |1 g6 S \ \ ]( y& u' L6 a; ?, _( t& D/ J6 T
#Set range 0-3604 t( o& s5 r d! w6 J1 h
while cabs < zero, cabs = cabs + 360
1 E' h2 Z5 y# r0 e6 P3 B while cabs > 360, cabs = cabs - 360 |
