楼主 |
发表于 2010-9-13 19:42:19
来自: 中国福建厦门
@sibnia # z$ r5 K5 y7 w" t
看了你的pdf,这种方法似乎不起作用' E, G. q( A! B O4 u# M) G
其实我已经设置了如下的配置文件& l5 O$ R h1 ~
DEFAULT_1" @8 U. ~0 A0 r
DEFAULT_25 G+ i% \4 I2 f! n B' v! G2 y5 o
DEFAULT_3
9 U) ^: N2 c4 d J# \' B8 E$ g输出的层还是* H/ g$ w/ \. n3 ~1 @
DEFAULT_1
! S" U1 C: w+ {0 x3 b3 K; qDEFAULT_2. k1 F8 e- F. T( p
DEFAULT_33 I0 W! U4 m; w& E" R( p
( q2 H. y" z% ]9 U7 \/ U( Hmap_color Centerline_COLOR 63 i9 c+ v! N, V/ O
map_color LETTER_COLOR 1
! F6 D$ v- n& o& V ~( ]map_color GEOMETRY_COLOR 7& M0 R! _+ W$ Y4 T
map_color sheetmetal_COLOR 7 ' L" e: J p$ ^4 q
map_color SECTION_COLOR 45 N% \3 g( }1 l |6 {+ \* @
map_color Leader_COLOR 3$ C; k' {5 V. O8 B* @+ c
8 [0 I& T. I: `. H: Kmap_line_style CTRLFONT CENTER
) K! k1 F$ [* C$ X6 p) k% u% B3 b1 {2 c5 `
map_layer Dxf_Axis _axis, d5 g! k: |3 v x! l! a1 l
map_layer Dxf_Continuous_Line _solid* f' c; L7 {4 T5 }
map_layer Dxf_Hidden_Line _hidden
% c7 e% `* E% O7 H. S& a6 t' ymap_layer Dxf_Dimension _dim! Y& p, Z& b* W% S( R
map_layer Dxf_Text _text
+ \! u4 T" e( r3 |6 k8 tmap_layer Dxf_Hatching _section
9 @' B1 {3 v; @( D6 H$ @map_layer Dxf_Table _table
; [/ P! b: |" p% ~" dmap_layer Dxf_Balloon _balloon
: ~# V+ C% S5 w6 ?map_layer Dxf_Format _format5 _8 o1 x, r+ Y& J0 v f
8 N( Y+ j/ |: M e
map_layer 0 solid : {% w9 p( k+ E, q) z
map_layer 01___PRT_ALL_DTM_PLN solid
( w) q% T& E9 f# Tmap_layer 01___PRT_DEF_DTM_PLN solid 1 _' |; g, x* j; T1 e3 N
map_layer 02___PRT_ALL_AXES solid ' \) C7 l: S& S" g$ v3 b# A
map_layer 03___PRT_ALL_CURVES solid
9 w9 B$ [; T+ D, v8 t5 Omap_layer 04___PRT_ALL_DTM_PNT solid
6 t2 t( f! j( T# Y+ Gmap_layer 05___PRT_ALL_DTM_CSYS solid 1 u% o, t. x2 x% ~0 p4 B5 [" S
map_layer 05___PRT_DEF_DTM_CSYS solid : |) A L; R, Z3 ^+ O" E- f
map_layer 06___PRT_ALL_SURFS solid & f9 ?1 ]- n! ~8 c' k5 z% {
map_layer DEFAULT_1 solid t% V, h: H& ~
map_layer DEFAULT_2 solid ' b8 q, S6 t, K/ v0 v$ z
map_layer DEFAULT_3 solid |
