发表于 2010-10-13 15:30:44
|阅读模式
来自: 中国河北秦皇岛
我用的是MATLAB2008a,AMESIMRev8a,做完软件的接口设置后,用AMESIM里自带的联合仿真的例子做练习,编译的时候出现错误如下9 S3 J0 E1 E# j
Setting environment for using Microsoft Visual C++ tools.
5 p. h2 S+ b" z2 X. r& OMicrosoft (R) Program Maintenance Utility Version 6.00.8168.0
' H% L. Q$ n' K. }Copyright (C) Microsoft Corp 1988-1998. All rights reserved. 6 _* e% C2 ^, t- G& W6 @' s
cl.exe -c -DWIN32 -DAMESIMULINK -ID:\Program Files\MATLAB/extern/include -ID:\Program Files\MATLAB/simulink/include -ID:\AMESIM/interfaces/simulink -nologo -DWIN32 -MTd -W3 -Zi -Od -D "_DEBUG" -D "_MBCS" -GX -Zm1500 -o AMESimulinkCosimulation_.obj AMESimulinkCosimulation_.c
2 R% e5 {" l4 ]9 iCommand line warning D4024 : unrecognized source file type 'Files\MATLAB/extern/include', object file assumed
( }0 ~) {+ S+ Z* w8 b7 o' s" @6 DCommand line warning D4027 : source file 'Files\MATLAB/extern/include' ignored
; {8 e$ l# z9 @& o( b* PCommand line warning D4024 : unrecognized source file type 'Files\MATLAB/simulink/include', object file assumed " [' W. S$ r. a+ F$ Y: {. k1 J
Command line warning D4027 : source file 'Files\MATLAB/simulink/include' ignored
) Y5 t, k5 S" w( AAMESimulinkCosimulation_.c : S J M5 D k
AMESimulinkCosimulation_.c(888) : warning C4101: 'n' : unreferenced local variable
& b9 g; t, z6 L1 I& GNMAKE : fatal error U1077: 'cl.exe' : return code '0x2' 5 E5 n+ R1 f0 h5 k" W, |
Stop.
1 M' b% {1 e: J2 u. n+ ID:\AMESIM/interfaces/simulink\ame_simulink_cosim.c(86) : fatal error C1083: Cannot open include file: 'simstruc.h': No such file or directory , X# e* K+ w, W6 p, T" Z/ ~8 L
- For free edition of Microsoft Developer Studio, you may need to set the MSSDK environment variable to the installation directory of your MS Windows SDK
/ W* l% {- @6 Q3 `. p& y+ ASystem build error!
1 x1 ] z# {! ?( H: X* U, A( ?, m& A ^6 g
打开creater interface icon 之后type of interface 中没有simulink呢?谁知到这是怎么回事啊?谢谢了 |
