发表于 2010-11-5 23:02:54
来自: 中国四川成都
我下载了,但是64位的安装说明看不懂,请朋友翻译一下3 r7 w3 H& O1 M S
1. SolidCAM 2010 HF1 SP2 Setup
! i v% E- Q3 V _# x% A4 F
9 I! [5 _5 F8 E2 g1.1. To install SolidCAM 2010 HF1 SP2 run ..\Setup.exe
0 C( U/ \/ u/ u' a2 w# O; S3 a) `9 _, x
2. USB-HASP-Emulator Setup
/ u8 R/ E- C& g1 R/ u9 K: s' b6 q2 i+ N
2.1. If you already have got installed and working previous versions of SolidCAM2009-2010 with USB-HASP-Emulator you need to install SolidCAM2010 HF1 SP2 only.
5 }- S/ t$ ]: `
1 U/ O' N: d$ ] E/ ^! R! I2.2. If you have no got SolidCAM2009-2010 installed and working but you've got USB-HASP-Emulator installed (USB-HASP-Emulator with service vusbbus.sys, mcamvusb.sys or any other service using for dumps Window Registry [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\NewHasp\Services\Emulator\HASP\Dump\] ) you do not need to install Emulator. Just register the dump (run "solidcam2010.reg") and restart or reinstall your Emulator) _& w$ S/ S+ ^5 E
, h2 V: J+ M3 h# W4 v1 I2 b% z/ d* C5 Y
2.3. If you have no got USB-HASP-Emulator installed you need to install it
: g9 K! ?$ Z) X1 `" V, |# m: }, G9 H- h) B" h" r# ^. J3 ?
ATTENTION!
/ u. F6 ]: t, ] v* L3 {) S* r8 T9 |To install emulator you need Administrator rights!
2 O7 y5 j0 X+ C% K& P- e4 ~To install emulator for Win Vista or Win7 you need to boot computer in mofe F8 > Enable Enforcement Unsigned drivers!: q$ ]! y" Q e' i, e3 q
Moreover you need to use boot mode F8 > Enable Enforcement Unsigned drivers at every reboot of computer!' L2 b- ]# m9 A' v, ^
& w# J% d/ c4 e2 t* d/ R3 {+ S2.3.1. Copy folder USB-Emul_Win64 to C:( u. s" f7 b7 H6 ?8 c% t
* e7 \9 ?$ J% h9 Z* u5 \2.3.2. Register dump (run ..\USB-Emul_Win64\solidcam2010.reg" and confirm to add info in Windows Registry)
x+ @, s' Z% f4 `+ y* w7 D' _: b- Z, ]1 H$ _" N# {
2.3.3. Run Start -> Control Panel -> Add Hardware (Yes, I have already connected the hardware) -> Add a new hardware device -> Install the hardware that I manually select from a list -> Show all Devices -> Have disk -> Browse -> (browse to folder "USB-Emul_Win64") -> OK -> Confirm to install not certificated drivers if Windows ask for..+ \: X8 A* E4 {, H
If setup is succesfull you have to see new devices:
! y Q# G/ }- q( t& VDevice Manager -> System devices -> Virtual Usb Bus Enumerator
6 S! ^3 d L6 }Device Manager -> Universal Serial Bus controllers ->SafNet inc. HASP key
5 a- S& { `( k6 O) sDevice Manager -> Universal Serial Bus controllers ->SafNet inc. USB key Y/ x) r% L2 @. |
' P' f8 G- a+ W+ p+ J5 F2 M
That is all2 f1 W- r% N3 O' [0 a: C( A# W3 L: c
That's all |
