下载了本论坛的软件 6 Q" I2 Z; K! O. O2 F/ k
! k- E' i6 |& T. f; |
但是安装说明为英文,本人实在无法看懂,请已经安装或者能看懂的的朋友指导。: }" N1 h# f2 ]! s
+ z' V. P: z6 J' T2 h1 f+ X1. SolidCAM 2010 HF1 SP2 Setup3 Y' ?8 C% F4 H5 w# E5 w
1.1. To install SolidCAM 2010 HF1 SP2 run ..\Setup.exe
4 ~+ l0 D' r. E2. USB-HASP-Emulator Setup
) }: b W' [6 y3 _2.1. If you already have got installed and working previous versions of SolidCAM2009-2010 with USB-HASP-Emulator you need to install SolidCAM2010 HF1 SP2 only.- C6 [- {0 e h/ `9 p' ~
2.2. If you have no got SolidCAM2009-2010 installed and working but you've got USB-HASP-Emulator installed (USB-HASP-Emulator with service vusbbus.sys, mcamvusb.sys or any other service using for dumps Window Registry [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\NewHasp\Services\Emulator\HASP\Dump\] ) you do not need to install Emulator. Just register the dump (run "solidcam2010.reg") and restart or reinstall your Emulator) c1 c, ?& c- g$ v# W" m
2.3. If you have no got USB-HASP-Emulator installed you need to install it ?% C, d$ ^) P3 {" k/ ^) [
ATTENTION!$ e% z9 T; n9 i) r) o/ Q* m) ?
To install emulator you need Administrator rights!0 u, y* O3 U* G
To install emulator for Win Vista or Win7 you need to boot computer in mofe F8 > Enable Enforcement Unsigned drivers!
; ?: O0 E& O( A+ FMoreover you need to use boot mode F8 > Enable Enforcement Unsigned drivers at every reboot of computer!
: ?" U' q- K+ S1 b+ S7 O2.3.1. Copy folder USB-Emul_Win64 to C:
5 X! O/ M |- {2 i: [2.3.2. Register dump (run ..\USB-Emul_Win64\solidcam2010.reg" and confirm to add info in Windows Registry), r/ X. C. ]! J- z$ A' N( [1 T1 k
2.3.3. Run Start -> Control Panel -> Add Hardware (Yes, I have already connected the hardware) -> Add a new hardware device -> Install the hardware that I manually select from a list -> Show all Devices -> Have disk -> Browse -> (browse to folder "USB-Emul_Win64") -> OK -> Confirm to install not certificated drivers if Windows ask for..* y8 b/ V0 ]4 C
If setup is succesfull you have to see new devices:
/ H0 C( X! p2 b5 h$ ~& z7 M. r2 LDevice Manager -> System devices -> Virtual Usb Bus Enumerator
$ E% G2 a I) [) IDevice Manager -> Universal Serial Bus controllers ->SafNet inc. HASP key
$ g8 K/ \6 ?& n3 v1 }Device Manager -> Universal Serial Bus controllers ->SafNet inc. USB key
! j6 i' v0 @- @5 [/ q/ G) a# mThat is all
& k* {( ?4 v b# t3 I2 eThat's all |
