发表于 2010-12-14 21:10:38
来自: 中国台湾
Command: list0 G* l V; s+ A5 m6 n
Select objects: 1 found ; white entity
" h; o9 R p) f" U3 _7 {Select objects:: a; k/ w M9 }7 y. @. K
SPLINE Layer: "0"; E, j; c4 H! h9 j$ t, }1 M
Space: Model space; E/ g4 e0 t6 d( |+ M
Handle = 21c
: Y* ]9 i1 d5 V& ^2 Z' ~2 R8 X! K Circumference: 3012.0039
5 J4 V. R3 o8 { Order: 4) g& ~: w5 ?+ n/ A
Properties: Non-Planar, Non-Rational, Periodic
7 I5 m1 j- D: _0 ] I. E Parametric Range: Start 0.0000
; q1 I; V5 a( t7 L) w8 r End2917.7171
+ A1 @! z9 j' W/ X Number of control points: 214' y j/ e/ }/ Z' N ~' ^ @
Control Points: X = 6807.0361, Y = 1332.2355, Z = -400.0000+ _( l6 t: }* Y- v$ t4 k
' E- w9 o, x% Q" e8 g2 ]- _3 Y
3 q$ ]1 T! g; P' D
您是要提取这个吗? Circumference: 3012.0039
( n( A2 `" b; g6 Q7 ~" q |
