如果装的是2009或者2010,注册表项中2011就是2009或者2010。" q# m, U8 j2 L
/ ^6 b1 ?; P0 g! _
% E' P. R) s7 \( }0 GI've found in a russian forum post a guide to activate the fullscene anti aliasing + realview for the consumer video cards* ^" S+ d$ y6 d e. }- M$ ?
goto: HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Current
C' Z, B% [. E+ `and copy the string 'Renderer' in my case is:! Q8 W( Z5 w ^1 R3 r8 K2 o
"ATI Radeon HD 5800 Series " (i've also a space at the end)2 Q2 @0 ]9 x& `
now if you have an ati go to:/ O# J) j$ F# L
"HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Gl2Shaders\R420"
3 P4 n7 l- ~% F3 s& Fmake a new key and as name paste that copied above, so now we have:& X$ x; O% T A* \5 g0 b B
"HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Gl2Shaders\R420\ATI Radeon HD 5800 Series "
/ O* P _5 o0 i- e3 X( Gnow add a new dword called "Workarounds" and set it to 40000
$ t# A2 y3 p* Y. m: AStart solidworks and see the reflection shadows effects etc.5 `- C- ^& s% C: A U& y
if you want the full scene anti-aliasing now is disponible in system options dispaly/selection frame./ g: M3 K0 v, { R5 U
Windows Registry Editor Version 5.00 F6 m1 m9 S% _% z% E
[HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Gl2Shaders\R420\ATI Radeon HD 5800 Series ]
2 X# ^4 t: i( V6 a+ i' o"Workarounds"=dword:000400008 p. w1 T3 |( h# q) q: T
For the nvidia is the same thing but the new key should be inserted in:
& N3 `: c ?' a0 D8 I, W# Q"HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Gl2Shaders\NV40"8 m6 ?0 B$ F8 ~' T2 Y2 J+ t2 \
and the new value workarounds could be 80008! i" ^; x5 N8 o2 X$ H
an example but i've not tested it(the name of the vidocard is invented
5 T; p! x: p, aWindows Registry Editor Version 5.00 R2 D; k1 Q% W7 H
[HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Gl2Shaders\NV40\GeForce GTX 480]
! D' E* j( ]# e& t"Workarounds"=dword:000800089 Q) R ^) W7 c$ G- G8 X
Good Luck |
