发表于 2009-4-15 16:12:29
来自: 中国广东东莞
#FEATURE CORE_ELECTRODE cima-d 9 31-dec-2012 uncounted$ B, w% d5 V) Y. ` A
# HOSTID=00192118C642 ISSUER="Team oDDiTy" SIGN=6DBC437817BE
/ i, B0 C; ?$ ]9 Y4 R; T& {' |4 ?# r' t5 R
FEATURE CORE_STANDARD cima-d 9 31-dec-2012 uncounted \. h8 F# _, V5 k7 u h& b
HOSTID=00192118c642 ISSUER="Team oDDiTy" SIGN=A7C560668750. T! M2 X& E2 o
PACKAGE ODT_SHOOT_PACKAGE cima-d 9 COMPONENTS="$oDDiTy 2D-TO-3D \0 p6 Q7 ~7 A6 d8 g- }$ R. g
2X_MILL_LITE 2X-MILL 2X-WIRE 3X_MILL_LITE 3X_SIMULATOR 3X-MILL \* ~% g" _$ G+ _
4X-CONT 4X-WIRE 5X_AEROSPACE 5X_SIMULATOR 5X_TRIM 5X-CONT \
2 U- T; |, f8 j: H& y. `5 I/ z5 a ABIANT ADVANCED_ASSEMBLY AUTODRAW AUTOMATED_DRILL BEND \( I; k) \% g* y' ?$ i" U$ }
CAD_MODE CADENAS CATALOGTOOL CATIA CATIAR2D CATIAR3D CATIAW2D \
" L- m+ L5 [1 Q! n CATIAW3D CHINESE_TRANSLATION CIMACABLE CIMADEK CIMADEK-NC \
8 i0 f0 k( ]& w$ _0 F2 `! Z. q3 r! n CIMADEK-RUN CIMARENDER CIMIT-D CIMIT-M CIMIT-MD CIMIT-MDN \. I, s% H1 ^& C, _/ k( H
CIMIT-MN CIMIT-N CONCURRENT_DESIGN CORE CORE-M CORE-X CPDM \
3 h, |# e J9 N3 f DIE_BLANK DIE_FLANGE DIE_FORM DIE_LABEL DIE_PLOT \
: R" A. v g/ r DIE_PLOT_SAFETY DIE_PLOT_THICK DIE_SET DIE_STRIP DIE_TOOLS DMS \; O9 @, k: U2 K9 R- L9 r/ x3 G
DRAFT DWG DXF E_STAMP EDM_SETUP_WIZARD EDM_WIZ_AGIE \
! ^+ o6 j9 e/ z: |+ B+ V% r" E EDM_WIZ_DPC EDM_WIZ_INGERSOL EDM_WIZ_MITSUBISHI EDMS-LINK \
+ g9 H7 p; `6 n ELECOTRE FAST_BLANK FEM FIKUS_IGUS FUSION_FULL GPF GPP \$ U2 [3 m& s& H7 b
GPP_DEV_EX2 GPP2_3X GPP2_5X GPP2_DEV_3X GPP2_DEV_DF2 \2 [7 W' x5 E( }( j
GPP2_DEV_EX2 GUN_DRILL IGES KINEMATICS LATHE LATHE_2X LATHE_3X \
: Y' P1 m; g2 `, _. @ LATHE_PP_COMPILER MACHINE_SIM MACHINE_SIM_CONFIG MACRO \
0 p/ `) @, V5 ~& o MICRO_3X MICRO_5X MICROSCRIBE_IF MOLDBASE3D MOLDDESIGN \, N8 b4 c3 o' ~+ h7 I
MOLD-EXPERT MULTI-USER-1 MULTI-USER-2 MX_MOTION_BUILDER \
( ]; F s2 b* p m# n! f8 M) ^ MX_MOTION_EDITOR NC_UNDERCUT NC-LINK NESTING NETWORK_ENABLED \5 A3 D0 }$ I4 q+ m3 X% _
PARASOLID_READ PARASOLID_SAT PAR-SHAPE POST_CONFIG \
+ a. S: p5 H' Z: u8 `. b POST_DEVELOPMENT POST_PRO POST_RUN PUNCH Q5X_CONT QCOMPARE \4 j$ {" J5 [. E+ j1 ^2 q
QCON_C QCON_Q QCON_S QELECTROD QSPLIT QUICK_NC QUICKCONCEPT \1 X; f: K' p* h S- q& ]
QUICKDRILL R_CATIA_2D R_CATIA_SAT R_CATIA5 R_IGES R_IGES_SAT \" H+ T- j ?/ j; M( d4 q! p
R_INVENTOR R_PARASOLID R_PROE R_SOLIDWORKS R_STEP R_STEP_SAT \6 N, q3 X0 u6 w; M
R_UG R_VDA R_VDA_SAT R_VRML RD-PTC RE-ENGE SHEET_METAL SAT \2 s- T+ i1 g( Y, q, ? |- B
SHOP-NC SIMULATOR SLA SOLFAST_FULL SOLID SOLID-ASSEMBLY \9 Z+ I: O' }7 q1 l2 a* B
STEP_READ STEP_WRITE STL SURFM TACFAST_FULL TEMP_KEY_CODE \, [- U0 V; i# `% U1 ?* P
UGR3D V_CONTROLLER VDA VERIFIER W_CATIA_SAT W_CATIA5 W_IGES \
: n; R, Z; \' ^) Y W_IGES_SAT W_PARASOLID W_STEP W_STEP_SAT W_UG W_VDA W_VDA_SAT \3 z" B: s. v- ?2 U8 i- b6 B X( G
W_VRML WF2SRF WIRE_2X WIRE_4X WIRE_STANDALONE X-CIMADEK \
/ i( |" _/ ^5 c% W0 t6 v X-CIMADEK-RUN" SIGN=B4F4ECBC63046 f+ a! g$ y& K4 u1 H! L
FEATURE ODT_SHOOT_PACKAGE cima-d 9 31-dec-2012 uncounted \
5 I4 f1 _- D* n# x0 n6 ~! y HOSTID=00192118c642 ISSUER="Team oDDiTy" SIGN=18827E122864$ G' h1 ^$ v: Y) N$ `0 g& i* `! [: o
PACKAGE ODT_CATALOGS cima-d 9 COMPONENTS="CATALOG_DANLY_INCH \
+ s( o# I* J2 d, H' {. h CATALOG_DANYL_MM CATALOG_DAYTON_INCH CATALOG_DAYTON_MM \
5 w/ O& ]! |4 {8 f0 o: w8 A' r7 A CATALOG_DME_INCH CATALOG_DME_MM CATALOG_DMS CATALOG_FIBRO \$ q/ G8 f% m0 n- @( W
CATALOG_FUTABA CATALOG_HASCO_INCH CATALOG_HASCO_MM \1 M% I. m. @ X" R' k6 _
CATALOG_HOPPT CATALOG_HYSON_INCH CATALOG_HYSON_MM \7 u% {& F8 e# W4 e* Z+ ]
CATALOG_KISHIN CATALOG_LKM CATALOG_MEUSBURGER CATALOG_MISUMI \
. I. `1 W4 a t5 {% {7 t, R/ N CATALOG_NATIONAL CATALOG_OKSET CATALOG_OTHER1 CATALOG_OTHER2 \% m3 b; w7 d( I
CATALOG_OTHER3 CATALOG_OTHER4 CATALOG_PCS CATALOG_PEDEROTTI \; n( Z' F' E3 V$ w
CATALOG_POLIMOLD CATALOG_PROGRESSIVE CATALOG_RABOURDIN \& x4 a9 c R9 {: T2 _ ]
CATALOG_SIDECO CATALOG_SISCAT CATALOG_SKF CATALOG_STAMPI \
" `% O* O; x+ `3 ~( V: C: A8 R CATALOG_STRACK CATALOG_SYSTEM3R CATALOG_TEKIS CATALOG_TVMP \* ?; t0 A: M+ g0 l# U
CATALOG_UNI CATALOG_VAP " SIGN=657DBEB623E4
" l* i4 E* E& wFEATURE ODT_CATALOGS cima-d 9 31-dec-2012 uncounted \
" H M5 D/ K9 T3 B HOSTID=00192118c642 ISSUER="Team oDDiTy" SIGN=32B334BA35EE
3 F- _- g7 a4 e# F; rFEATURE CHINESE_TRANSLATION cima-d 9 31-dec-2012 uncounted \
0 F7 s' Z, K# u! c HOSTID=00192118c642 ISSUER="Team oDDiTy" SIGN=B416503285C0 |
