发表于 2008-12-16 19:05:17
来自: 中国江苏苏州
#选单开始 U
+ {" r! A1 D( D% f- g1 l. h) Z) DU user_menu
4 B5 c9 H$ l; S9 |/ [1 vT "右键菜单"
" D# f3 F3 n; ]9 c$ p8 P/ W" T1 N) ^2 A* _# N/ t+ l2 v
; K* d7 {$ o" C. n! B
S& i5 m9 m6 g2 d C* C
5 A* N+ C; ~! C+ v( JM " 刀具库"# S4 C# a$ b' R" Q/ [+ I" _+ R
M "牛鼻刀"0 _ t r9 c! ? `; B
I "63R6" 1 "CREATE TOOL '63R6' tipradiused EDIT TOOL '63R6' DIAMETER 63 EDIT TOOL '63R6' TIPRADIUS 6 EDIT TOOL '63R6' FEED_RATE_REC 3000 EDIT TOOL '63R6' SPINDLE_SPEED_REC 900 FEEDRATE ACCEPT
6 C: M9 x; z! W4 N4 {( ^2 v5 D8 ZI "50R5" 1 "CREATE TOOL '50R5' tipradiused EDIT TOOL '50R5' DIAMETER 50 EDIT TOOL '50R5' TIPRADIUS 6 EDIT TOOL '50R5' FEED_RATE_REC 3000 EDIT TOOL '50R5' SPINDLE_SPEED_REC 900 FEEDRATE ACCEPT N8 e0 }0 I+ e0 ]
I "30R5" 1 "CREATE TOOL '30R5' tipradiused EDIT TOOL '30R5' DIAMETER 30 EDIT TOOL '30R5' TIPRADIUS 5 EDIT TOOL '30R5' FEED_RATE_REC 2500 EDIT TOOL '30R5' SPINDLE_SPEED_REC 1500 FEEDRATE ACCEPT
8 a/ G0 X, W) I. g* oI "20R4" 1 "CREATE TOOL '20R4' tipradiused EDIT TOOL '20R4' DIAMETER 20 EDIT TOOL '20R4' TIPRADIUS 4 EDIT TOOL '20R4' FEED_RATE_REC 2500 EDIT TOOL '20R4' SPINDLE_SPEED_REC 2000 FEEDRATE ACCEPT
( A3 A7 V/ y# t4 y0 ^' gI "32R0.8" 1 "CREATE TOOL '32R0.8' tipradiused EDIT TOOL '32R0.8' DIAMETER 32 EDIT TOOL '32R0.8' TIPRADIUS 0.8 EDIT TOOL '32R0.8' FEED_RATE_REC 1500 EDIT TOOL '32R0.8' SPINDLE_SPEED_REC 2000 FEEDRATE ACCEPT
; ?: H i# R) r$ xI "25R0.8" 1 "CREATE TOOL '25R0.8' tipradiused EDIT TOOL '25R0.8' DIAMETER 25 EDIT TOOL '25R0.8' TIPRADIUS 0.8 EDIT TOOL '25R0.8' FEED_RATE_REC 1500 EDIT TOOL '25R0.8' SPINDLE_SPEED_REC 2000 FEEDRATE ACCEPT ! X4 F- l8 [& h3 P+ q1 w
I "20R0.4" 1 "CREATE TOOL '20R0.4' tipradiused EDIT TOOL '20R0.4' DIAMETER 20 EDIT TOOL '20R0.4' TIPRADIUS 0.4 EDIT TOOL '20R0.4' FEED_RATE_REC 3000 EDIT TOOL '20R0.4' SPINDLE_SPEED_REC 2500 FEEDRATE ACCEPT
1 [* G; B. x' FI "16R0.8" 1 "CREATE TOOL '16R0.8' tipradiused EDIT TOOL '16R0.8' DIAMETER 16 EDIT TOOL '16R0.8' TIPRADIUS 0.8 EDIT TOOL '16R0.8' FEED_RATE_REC 3000 EDIT TOOL '16R0.8' SPINDLE_SPEED_REC 2500 FEEDRATE ACCEPT/ u8 @' `/ | w, E
I "12R0.4" 1 "CREATE TOOL '12R0.4' tipradiused EDIT TOOL '12R0.4' DIAMETER 12 EDIT TOOL '12R0.4' TIPRADIUS 0.4 EDIT TOOL '12R0.4' FEED_RATE_REC 1500 EDIT TOOL '12R0.4' SPINDLE_SPEED_REC 2500 FEEDRATE ACCEPT5 V. s% f2 @& O5 T& u7 ^% E6 C. S
6 C" U& Y+ }) m: ^" h; n8 u# a
Z
! M2 {- B+ l7 K' F! j6 S9 f" RS
" h \) i* E _- ?% U1 FM "端铣刀"
$ v. C, \% K- H, K9 b) zI "20 " 1 "CREATE TOOL '20' ENDMILL EDIT TOOL '20' DIAMETER 20 EDIT TOOL '20' FEED_RATE_REC 200 EDIT TOOL '20' SPINDLE_SPEED_REC 300 FEEDRATE ACCEPT"
6 n4 \# B7 w* h; P! NI "16 " 1 "CREATE TOOL '16' ENDMILL EDIT TOOL '16' DIAMETER 16 EDIT TOOL '16' FEED_RATE_REC 200 EDIT TOOL '16' SPINDLE_SPEED_REC 300 FEEDRATE ACCEPT"
1 M: _ a M3 `' P8 y/ J( F: M, zI "12 " 1 "CREATE TOOL '12' ENDMILL EDIT TOOL '12' DIAMETER 12 EDIT TOOL '12' FEED_RATE_REC 1000 EDIT TOOL '12' SPINDLE_SPEED_REC 2500 FEEDRATE ACCEPT"
9 I, _( F, E" k% I- QI "10 " 1 "CREATE TOOL '10' ENDMILL EDIT TOOL '10' DIAMETER 10 EDIT TOOL '10' FEED_RATE_REC 800 EDIT TOOL '10' SPINDLE_SPEED_REC 2500 FEEDRATE ACCEPT"5 y4 R! t, Y1 g
I "8 " 1 "CREATE TOOL '8' ENDMILL EDIT TOOL '8' DIAMETER 8 EDIT TOOL '8' FEED_RATE_REC 800 EDIT TOOL '8' SPINDLE_SPEED_REC 3000 FEEDRATE ACCEPT"
" k( ]* _. I/ @- P2 Z1 O! |I "6 " 1 "CREATE TOOL '6' ENDMILL EDIT TOOL '6' DIAMETER 6 EDIT TOOL '6' FEED_RATE_REC 600 EDIT TOOL '6' SPINDLE_SPEED_REC 3500 FEEDRATE ACCEPT"
8 Q2 F' a' a$ X, M3 bI "5 " 1 "CREATE TOOL '5' ENDMILL EDIT TOOL '5' DIAMETER 5 EDIT TOOL '5' FEED_RATE_REC 600 EDIT TOOL '5' SPINDLE_SPEED_REC 3500 FEEDRATE ACCEPT"- q% z% O, \& C- c7 z0 d5 S
I "4 " 1 "CREATE TOOL '4' ENDMILL EDIT TOOL '4' DIAMETER 4 EDIT TOOL '4' FEED_RATE_REC 400 EDIT TOOL '4' SPINDLE_SPEED_REC 4000 FEEDRATE ACCEPT"
@. u1 @ G& S/ V1 ?I "3 " 1 "CREATE TOOL '3' ENDMILL EDIT TOOL '3' DIAMETER 3 EDIT TOOL '3' FEED_RATE_REC 200 EDIT TOOL '3' SPINDLE_SPEED_REC 4000 FEEDRATE ACCEPT"
: b9 W2 ?, x* u! i6 S( t0 W8 U/ e) U) P- l; n; F0 w
Z' d$ _, t1 a3 {0 Y, t! v6 f
S4 ]0 x8 y$ ^* }, S1 x
M "球刀"
5 P0 U. Z- r/ e/ wI "16R8" 1 "CREATE TOOL '16R8' BALLNOSED EDIT TOOL '16R8' DIAMETER 16 EDIT TOOL '16R8' FEED_RATE_REC 1000 EDIT TOOL '16R8' SPINDLE_SPEED_REC 2500 FEEDRATE ACCEPT
/ Q5 o8 ~/ Y3 K4 Z8 N$ [* KI "12R6" 1 "CREATE TOOL '12R6' BALLNOSED EDIT TOOL '12R6' DIAMETER 12 EDIT TOOL '12R6' FEED_RATE_REC 1000 EDIT TOOL '12R6' SPINDLE_SPEED_REC 2500 FEEDRATE ACCEPT
1 q- p: A3 \- w" v9 E# lI "10R5" 1 "CREATE TOOL '10R5' BALLNOSED EDIT TOOL '10R5' DIAMETER 10 EDIT TOOL '10R5' FEED_RATE_REC 1000 EDIT TOOL '10R5' SPINDLE_SPEED_REC 2500 FEEDRATE ACCEPT
7 Z2 L: u/ M2 C0 K$ m+ w2 {I "8R4" 1 "CREATE TOOL '8R4' BALLNOSED EDIT TOOL '8R4' DIAMETER 8 EDIT TOOL '8R4' FEED_RATE_REC 1000 EDIT TOOL '8R4' SPINDLE_SPEED_REC 2500 FEEDRATE ACCEPT / w9 d/ c' |1 I/ {" e
I "6R3" 1 "CREATE TOOL '6R3' BALLNOSED EDIT TOOL '6R3' DIAMETER 6 EDIT TOOL '6R3' FEED_RATE_REC 1000 EDIT TOOL '6R3' SPINDLE_SPEED_REC 3000 FEEDRATE ACCEPT
* X1 w, L8 N) C AI "5R2.5" 1 "CREATE TOOL '5R2.5' BALLNOSED EDIT TOOL '5R2.5' DIAMETER 5 EDIT TOOL '5R2.5' FEED_RATE_REC 1000 EDIT TOOL '5R2.5' SPINDLE_SPEED_REC 3000 FEEDRATE ACCEPT 8 A' |( d* n& k3 c" J6 u# w' c% ?, b
I "4R2" 1 "CREATE TOOL '4R2' BALLNOSED EDIT TOOL '4R2' DIAMETER 4 EDIT TOOL '4R2' FEED_RATE_REC 1000 EDIT TOOL '4R2' SPINDLE_SPEED_REC 4000 FEEDRATE ACCEPT
! F5 D. g. F/ qI "3R1.5" 1 "CREATE TOOL '3R1.5' BALLNOSED EDIT TOOL '3R1.5' DIAMETER 3 EDIT TOOL '3R1.5' FEED_RATE_REC 1000 EDIT TOOL '3R1.5' SPINDLE_SPEED_REC 4000 FEEDRATE ACCEPT * r+ x3 b1 H$ z7 p% R
1 k' X* Q7 \/ k$ x4 n& e) F: b/ s" P2 J8 I( [
Z6 {9 H8 |* y3 F5 e. B, \$ [
S
& n" x+ }( O- ?, j' _# VM "钻头"! L, K) J* A2 R) @
I "钻头3R1.5" 1 "CREATE TOOL '钻头3R1.5' BALLNOSED EDIT TOOL '钻头3R1.5' DIAMETER 3 EDIT TOOL '钻头3R1.5' FEED_RATE_REC 15 EDIT TOOL '钻头3R1.5' SPINDLE_SPEED_REC 4000 FEEDRATE ACCEPT
5 F4 q8 |: |3 V# b3 \Z
( [: c" o/ S% bZ# u9 _# ^8 J) [: u% u& j; J
S7 H' D; a F3 T8 {. H
M " 参考线精加工". ?$ b; p6 r$ N6 O( u1 U
I "刀具路径转参考线" 1 "CREATE PATTERN ;\r EDIT PATTERN ; INSERT TOOLPATH ;\r"
; Y0 S& K2 F6 G; N+ X- yI "参考线转刀路路径" 1 "COMMIT PATTERN ; \r PROCESS TPLEADS" # s! p# N9 }! [! X/ r
Z4 U: ?5 W' o$ K# }+ i1 |, [2 n
S' `' }1 @, M# }' }5 _
M " 中英文转换"* J2 _' X5 o2 | D
I " 英文界面" 1 "lang english"
( @: \3 @3 M0 HI " 中文界面" 1 "lang chinese"+ J9 {+ x7 [% S$ ]
Z
! i( Z1 _3 s5 W/ b) c$ @S
1 c" ^9 e7 C, y( f% P. q1 S8 f
6 E, V9 A! O2 [: t iM " 程式单": z7 x; s0 D, x: m1 O: Q* v, r, k7 v
I " 出程序单" 5 "PMILLHELP URL 'c:\dcam\product\PowerMILLUtils4000\sys\exec\PowerMILLUtilities.html'"
; b* N8 j: [& w% Y# S6 |Z
- C1 H' H( a% P1 O- r! XS) ]! z6 D$ s8 `% ~
I " 只读转为可读写" 1 "PROJECT CLAIM"
4 }- ^+ w# `5 _2 K+ d: l) o" _
, `! `% x7 v, Z
' K) s( d1 W0 f
3 I) B+ w8 b- _5 r9 U2 r4 t, rZ |
