楼主 |
发表于 2020-2-7 13:44:10
来自: 中国广东广州
本帖最后由 yjyeming 于 2020-2-7 13:45 编辑 * w, a1 E8 ]' B# ~3 x; o! ~! F( `) R
% q. c" F& k5 J
改写宏重新设置为单一色
a! }) V% P. A. O/ g$ L4 g" |2 a* T9 R$ [3 ?# a
; f/ ^8 D! M1 M/ B) ?) @' C:\Documents and Settings\Administrator\Local Settings\Temp\swx5520\Macro1.swb - macro recorded on 04/02/19 by Administrator/ Z; ?% Q& G" m9 j
' ******************************************************************************, x6 Y8 \& X5 B' z f$ a- z$ u4 u
Public ckColor1 As Double& f( l' E0 y& N: t6 N
Public ckColor2 As Double7 u# J& f5 q/ N: c! w2 Z8 [, @
Public ckColor3 As Double
: C. M7 z9 h5 x8 { p
7 E! |( I8 ]' p* VSub main()* W" A# x3 W9 ~
Dim swApp As SldWorks.SldWorks
2 F3 ]& k- K9 ^6 zDim swModel As SldWorks.ModelDoc21 v! c4 i( l% s& b/ z N; ]+ Y
Dim Model As SldWorks.ModelDoc20 c# F$ P' L/ [" U' v
Dim swSelComp As SldWorks.Component2
4 f9 w3 o' k1 \* V" U3 f4 m Dim bRet As Boolean% ?4 i- f, L F# c7 M
Dim sss As String
Y- c7 h" ]( r; a6 DDim vModels As Variant* x3 _9 x @" i% h
Dim Count As Long5 Y8 |( s S. j. }
Dim value As Integer
" r; N. o8 U6 FDim index, j As Long9 Y0 N9 H8 |9 ? j. v" {3 G
Set swApp = Application.SldWorks6 Z1 m9 t+ ^8 M( \+ p9 e4 d
ckColor1 = 0.7164
7 b$ I/ A0 E6 [4 d0 J# w `ckColor2 = 0.5921. t% M+ F3 D/ s1 x' K- n" B
ckColor3 = 0.6235
: m- O& C) Y l7 U" OCount = swApp.GetDocumentCount f' j* v; a/ J! t N7 R) r; E
Debug.Print "Number of open documents in this SolidWork session: " & Count
0 ]) k/ x6 d1 p) Z" \5 nvModels = swApp.GetDocuments
$ m; H* g% s+ _$ N" v2 I% k j = 1
. X$ Y5 x+ O# ~# g `7 j For index = LBound(vModels) To UBound(vModels)
6 g" j. H3 F, u$ n8 k
# O# U) y; E; q: e9 G Set swModel = vModels(index)
' @ ?% j, x4 }$ M' U9 k If swModel.GetType() = 1 Then
$ t2 R- n! x1 k* _3 Z
" m/ n. u& e" u; d 'Set swSelComp =
S0 m1 _0 a" }; n& o2 J, F swModel.ShowComponent25 {0 B; k" W( k7 S7 I+ e1 G3 B
sss = swModel.GetTitle6 f1 [+ y; h/ D5 b% J
8 i$ l+ `* O4 x @
' bRet = swModel.Extension.SelectByID2("轴15-1@卷卷卷aaa", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
% D, L, i2 d, q' c+ T7 E bRet = swModel.Extension.SelectByID2(sss, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)5 a9 f0 ]+ R) Z$ H
& l [( w) l, J/ ?+ O, d! ^9 ` bem1 swModel$ J3 n5 _5 b2 j! z
& K h+ |2 x, a8 `8 j( v+ X
Debug.Print "Path and name of open document: " & swModel.GetPathName & swModel.GetTitle( t- a7 z/ @# Z$ u( [2 J
j = j + 1
- E5 W# W% |7 n2 v$ p- }+ P, a, pEnd If ]# A' R2 ]. @( `, a e% ?
Next index
* Y! T5 D" G' _* W* Q
x7 P) l. p( n+ _$ q# W! t1 LEnd Sub$ ?9 z6 m" H) l1 s
# v7 ?' l+ \5 X3 `
Function bem1(wm1 As SldWorks.ModelDoc2)) \7 h- k$ [2 @2 y" W
Dim swModel As SldWorks.ModelDoc2: C/ l2 b8 z- }/ N4 x* K+ B
Dim swPart As SldWorks.PartDoc# p7 t; l2 f4 y0 k2 K
Dim vMatProp2 As Variant
- q3 r, w A# b6 Z9 |6 i {2 R Dim bRet As Boolean
* S' v$ r) V, A. Y, J, _0 h) N4 o7 a1 t& d1 [9 y
. s ]9 `$ p1 e0 t# M
'bRet = wm1.Extension.SelectByID2("轴15-1@卷卷卷aaa", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
1 Q2 e( B3 _# K+ R. t2 b5 K vMatProp2 = wm1.MaterialPropertyValues0 l' c4 I$ H, H# F* X* r
+ @6 N( Z& f, v+ H
vMatProp2(0) = ckColor1 《《《《《《将ckColor1改为1。! f4 O# r& c u/ c
vMatProp2(1) = ckColor2 《《《《《《将ckColor2改为1。
: p' Y- ?! y% h) i8 N vMatProp2(2) = ckColor3 《《《《《《将ckColor3改为1。
( ^1 g5 r4 [: [2 S$ R/ k+ T
2 b! M2 O4 u* E r: b/ Fwm1.MaterialPropertyValues = vMatProp2
& k( \0 h- s7 i8 x* H0 Y2 F9 F' swPart.MaterialPropertyValues = vMatProp2
6 @; A( P' F1 M+ M8 M2 K ckColor1 = ckColor1 + 0.2% U H/ M) |& Z8 e3 I/ J
If ckColor1 > 1 Then
5 _0 o, U9 b$ l7 y {( A ckColor1 = ckColor1 - 10 m- i- t0 f9 C5 Q6 s$ H$ ?- |
End If. Y3 {! ^5 T [& [4 u/ Z
ckColor2 = ckColor2 + 0.081 r5 ?, ]: s. r7 n9 `( n7 W
If ckColor2 > 1 Then
9 n! D+ n% `; ~* P' q) T3 ^ ckColor2 = ckColor2 - 14 E4 k" u1 b& M* Z( E
End If
: m i, I/ c$ ~3 a; w9 H B G' q ckColor3 = ckColor3 + 0.31% I: j5 P" Z- U% ]+ d y
If ckColor3 > 1 Then& L$ m/ p: G" F% \' J" x. U
ckColor3 = ckColor3 - 1
5 \( z0 |/ T( Z4 n3 \; J C End If+ `. O, d6 O7 x I/ b
1 @2 }$ x! z+ _+ e. t, eEnd Function+ \. T R- E' @' \+ H
