楼主 |
发表于 2006-12-14 13:06:36
来自: 中国浙江宁波
在网上查了很久,有如下文章,供大家参考:
- J; D7 r7 G& T) [7 T7 H8 d/ O" Q0 GJ-me
3 ^$ ~7 o' @2 V& V( ?Hope I have not kept you too long in replying [know your urgency in servicing cutomers]# S1 `9 H1 Q2 e% o+ z
[1]"Gauge" in this context means measurement of thickness.% Y8 |, B) w }5 H7 F5 Y
Let me explain that "gauge" is a table whereby a given number takes the place of and is equivalent to a dimension. eg. in Standard Wire Gauge 20 gauge = 0.040mm
# J4 d' H& `) L7 FThere are differing "gauge" types for various application. For example :
0 I( o0 e8 q. E9 I$ T! D- Birmingham Gauge used to measure thickness of sheet steel+ b k, X, M$ j# p4 {5 [; m
- Standard Wire Gauge [SWG] used to measure diameter of wire and thickness of aluminium sheets! y! `- y! L1 E! }, S) I
- Screw Gauge used to measure diameter of "self tapping" screw which sets a corresponding hole size to accept the screw in the material . ( z! i( Q$ Z2 g4 z N9 N
) ^) M& | s* i+ N0 d2 N- @" y6 f
J-me, I do not know the gauge table used for your industry or your product." I9 B0 ?" d6 K9 ?' R' b3 q" t
May I suggest :-9 h' Y' N' o: C+ W1 D
- ask your fellow managers for information of the gauge table used for your products - in particular 80 gauge.
! I4 N; I0 j2 K+ a% T- alternatively go back to your client and ask them to confirm the thickness x mm Note: your client nominates thickness .003 [presume MM] for 1st item
' C- M( S$ [* u0 ?# D: P% z
2 U V/ ?/ @2 s; G/ G2 h: q8 R' Y+ e5 y/ Z ]2 C7 z/ g* b5 `
[2]"Machine Grade" sounds to me a specification [ I believe the tape product has to suit machine application/possibly high speed/possibly high strain/stress]
% l$ [& C* G4 C+ j* H [ like in aluminium we have Bending Grade, Machining Grade, Bright Dip Finishing Grade etc]; i0 t7 l3 g- }- F# T) j
Suggest you seek from your managers, details of their interpretation of machining grade specification for your product , then confirm with your client
* Y% P! Y" C5 o3 j that this is compatible with their requirement.
9 f! e/ I$ z* i# G
# K' G/ q2 ?3 O# B6 O3 c1 W+ c- J.
; [- V3 G1 S6 r* u/ y" pThis all takes a little time, but is is important to get it right and agreed , rather than risk supplying a non-complying product which may fail and cause inconvemience and dissatisfaction for your client. I am sure your client will appreciate you taking the trouble to ensure correct product is supplied .# a3 j& `4 b; e4 O! s5 K
This will build customer reliance on your company's product , build a good relationship and bring you repeat business.0 f) @0 q; S- C% V9 a1 d( J1 U
.& b* V- a! O& ]9 N
I will be interested to hear how this is resolved.. v0 |- U% Q/ v# D: Q- i4 ~( G5 ]
Good luck,
4 W7 T1 j5 ~9 `( j4 W0 x C8 P5 d( w1 ZGeoff0 R$ P: @6 K) W" y, V4 U/ K
1 t, f, n4 R0 F% B$ L
0 R! L/ g3 u9 D( K* M; j5 z% f英制线规(B.W.G)用以表示金属的线径、板厚、管壁厚度,其与毫米之关系(略数)如下:
, O L# r* @2 P+ I7 ^% ]; T: x [B.W.G 毫米(mm) B.W.G 毫米(mm) B.W.G 毫米(mm)* N' J# I: Q: L! J* a
0000 11.5 7
8 b! F" C. f7 F# R" Z. P000 10.8 8
8 E3 X& H4 k1 z" F* R00 9.65 9. r; O4 c7 G+ Y
0 8.63 10
% u2 v, O s* U; Z1 7.62
' d2 a+ g# I3 B8 R2 7.21 ( t* D$ M% U, Q& J' H7 N7 S w
3 6.586 h. ]3 L, ?' O$ `4 k
4 6.04
( y! D& V9 R- M+ T5 5.59
9 ~% x4 u% W4 Z( N6 5.15
% d: K* k. w; l, h2 w3 J( H$ T: {7 4.57
' K7 |7 B8 b) V4 `' [4 U- q8 o8 4.19
6 k0 `- [6 V* c3 c8 U, W9 3.762 x0 V; w' ?4 [! C
10 3.4
( q$ C- c w: B7 e* J, d& r11 3.05
# D1 e5 Q0 b8 V( s9 O4 j$ I4 T, ]6 ~12 2.77
7 ^9 S0 M- ~- r& q) E13 2.41
9 I. R( a* m" T: u, ? s! T1 c14 2.11. b8 I% E6 o5 G/ {/ u/ S
15 1.83
6 J- ]3 Y( p. D* e& R$ z16 1.65
$ \( Z. I$ X* e0 w! E- [$ ~17 1.47& B3 H3 u* A p! j) F0 F* j
18 1.246 l, p: t* }4 G7 e" x7 n
19 1.07
{% P5 D) _' m( F20 0.89' L0 W0 k9 r( O& F
21 0.81
/ g, x; k5 x& M- @" p# o. M [$ R22 0.712 y0 H3 L; |7 a* S
23 0.63
" \7 R$ t: {. M/ e24 0.56
" S( h# `/ Y+ e) j0 r6 E# i25 0.51 Y& \7 R, [7 W
D- u; i6 m4 E
[ 本帖最后由 fengxy 于 2006-12-14 13:13 编辑 ] |
