发表于 2015-5-6 22:10:01
来自: 中国江苏盐城
parc #Select the arc output# y' C! Y1 P& L+ C& s0 r. q
if arcoutput = zero,
# ` |1 }; [6 [9 p/ R- \ [
, X* X& J; Z+ |( I5 D! T #Arc output for IJK% _8 ]% w* k- v7 y. B+ t
i, j, k& ]! N/ O3 n' a( r' R4 P8 Z$ w
]+ r; p5 s8 d9 `; G. g6 R- ?
else,
) P% Z7 E- Y$ W [3 C Q. u4 h3 F6 y" p2 O
#Arc output for R5 t" y$ g( X% p' N# w0 o. a
) d: d" g) u. _& _6 j if abs(sweep)<=180 | arcoutput=one, result = nwadrs(srad, arcrad)
$ A- p# H9 i; u8 j6 @" B/ v+ E0 ~' Y3 }' z+ G1 u. \/ g
& ` G* y* `' I9 r [" `替换为下面的内容($ 这个符号可能要去掉)) t& E4 }, p' e( w' g
; y, D" G( Y1 x( y if (plane$ = zero & (arctype$ = one | arctype$ = four)) | #XY Plane' @3 n o3 R# v. L
(plane$ = one & (arctypeyz$ = one | arctypeyz$ = four)) | #YZ Plane
" S( X3 [! J& g, f (plane$ = two & (arctypexz$ = one | arctypexz$ = four)), #XZ Plane5 ^2 O4 z& R0 G# j: P
[( `6 s% z& W9 M! t8 K
result = newfs(two, iout)! F+ W' M0 D7 O7 C+ X' s; V! H
result = newfs(two, jout)7 W. [& K9 \% f+ D( g I
result = newfs(two, kout)
8 @3 k6 o! ~! x, \ D8 q* i ]& U6 s/ G! J! w/ n7 \
else,
2 i& j+ n: k6 \) {% ~( J9 F [
, I! U C" A3 }& C result = newfs(three, iout)
, T0 }0 h# R" H0 X result = newfs(three, jout)
. ]2 v9 ]4 H, n' B- W result = newfs(three, kout)3 K1 z2 }) j/ U+ q8 N
3 @( j E# P/ T# _* x% V7 d if (plane$ = 0 & arctype$ < five) | (plane$ = 1 & arctypeyz$ < five) |0 K: r5 A3 |7 q, x. P ?) Y+ Z0 U
(plane$ = 2 & arctypexz$ < five) | full_arc_flg$ | arc_pitch$,
0 n" \0 M& x* h0 i, N% S [
- a; o Y' W& H: O/ W #Arc output for IJK( v' r3 L0 z# D7 I
# If you do NOT want to force out the I,J,K values,7 L4 W' s- k+ f" f6 \
# remove the "*" asterisks on the *i, *j, *k 's below... U7 t. n' c6 Q
if plane$ = zero, *iout, *jout, kout #XY plane code - G17
/ H4 D& `4 y6 S& a' P if plane$ = one, iout, *jout, *kout #YZ plane code - G19
& W: T1 c6 ?- R9 f& Y if plane$ = two, *iout, jout, *kout #XZ plane code - G18# Z, k3 c' P" e- g7 H% L; Y# m
!i$, !j$, !k$
2 }& a& }2 P/ l/ W$ s$ Y ]8 j4 e+ b2 I/ C; B
else,5 s" x- Z/ w& A0 ~4 n+ L
[; Y/ v' e# l1 K8 R2 k: f2 K. e
#Arc output for R# D+ p- Z! C7 z& f
if abs(sweep$)<=180 | (plane$ = 0 & arctype$ = five) | (plane$ = 1 & arctypeyz$ = five) |
8 [$ U, v# w) s( |* h5 @ n: Z (plane$ = 2 & arctypexz$ = five), result = nwadrs(srad, arcrad$)
! F- N4 n, u# o/ _+ { |
