楼主: solid_user
[分享] ProCAST2006 R1 crack (by gellmaR)
 楼主| 发表于 2007-10-11 18:22:54 | 显示全部楼层 来自: LAN
原帖由 chinalaowang 于 2007-10-11 09:08 发表 http://www.3dportal.cn/discuz/images/common/back.gif  k# ^) v6 `3 G' R6 d- Q- J7 @% n
如果能将magmaCrack了就ok啦!
% T% L6 i' l4 t9 F. Y; J
I do not use MagmaSoft and have no got Installation of that Apps...
发表于 2007-10-12 22:54:45 | 显示全部楼层 来自: 中国上海
并行的有人试了么?我试了好像还是没什么效果,出来的那个cmd与提供的不一样啊
发表于 2007-10-13 14:35:50 | 显示全部楼层 来自: 中国浙江宁波
谢谢!我可以上传MAGMASOFT4.2 ,不知能否Crack呀!
发表于 2007-10-13 15:45:25 | 显示全部楼层 来自: 中国湖北荆州
ProCAST2006 R1 crack (by gellmaR) » 发表回复
MAGMASOFT4.2FTP上早就有了,只不过到现在也没人能弄开
发表于 2007-10-16 11:58:54 | 显示全部楼层 来自: 中国广东广州
dear solid user,* Q$ o4 U5 c; N9 }  b7 {1 y
i really appreciate your great work for the crack. while  the database which used in microstructures do not included in this license and i really need it to sovle my problem. i am expecting for your new crack on it, thanks7 X4 a( b2 Q/ L$ v- Z8 z& ^
; P: ^" G# P& R
4 m/ E. ~. a& E- h
 楼主| 发表于 2007-10-16 22:32:34 | 显示全部楼层 来自: LAN
原帖由 jojo1983 于 2007-10-16 11:58 发表 http://www.3dportal.cn/discuz/images/common/back.gif) u4 f0 s+ u6 _, L
dear solid user,
. R) j. T( t9 fi really appreciate your great work for the crack. while  the database which used in microstructures do not included in this license and i really need it to sovle my problem. i am ex ...
; ~/ b- x: K+ c4 `5 S9 C2 U: h
I can try to fix but I need a simple test file (please make a folder with all needed files: geometry, materials, initial and other date...) so I can run your study in ProCAST module and see the problem!
' D8 A. K' @) P5 W4 X; @% Q. C1 aCheck your PM for my e-mail adress
发表于 2007-10-17 21:05:14 | 显示全部楼层 来自: 中国广东珠海
mirc test file
tcast.rar
348.93 KB, 下载次数: 21
发表于 2007-10-17 22:37:24 | 显示全部楼层 来自: 中国江苏南通
good 谢谢各位楼主,我也遇到40楼同样的问题,望楼主solid-user早日Crack
0 a# Z" |. h: N/ Q; q# E" \  U; |0 {. f& M! w! H! a+ W/ R3 m" _
[ 本帖最后由 xfzcgzs 于 2007-10-18 06:32 编辑 ]
发表于 2007-10-22 19:20:17 | 显示全部楼层 来自: 中国浙江宁波
确实是高人啊!, n0 I0 h" a" o' y7 P: R  ~$ P
如果能将magmaCrack了就ok啦
 楼主| 发表于 2007-10-29 05:35:07 | 显示全部楼层 来自: 俄罗斯
jojo1983 ,  zqlong and all..
( `4 z: q0 M0 ]6 c" pNow MICRO calculation is fixed!
, {* \4 L% a6 Q0 j, PHere is a additional patch... Use this patches for already cracked ( not original ) "pro_icc.exe" and "pro_vcc.exe"!
/ s  `: m! {. t
# K2 V) ~* e: V) HGood luck!
procast2006.1_micro_crk_gellmaR.rar
9.91 KB, 下载次数: 54
发表于 2007-10-29 14:49:45 | 显示全部楼层 来自: 中国江苏南通
请教一个问题我已经把文件复制到bin里怎么还出现这个图形,望帮助?谢谢!
发表于 2007-10-29 14:53:37 | 显示全部楼层 来自: 中国广东广州
dear solid_user ,
, w5 e7 \0 r& G7 ^: q. c0 s        I'm sorry to trouble you,  I fall into a new trouble that the procast can not work after I followed the readme file ,put the patches into <ProCAST2006.1 program directory>\bin and run them, the cmd information is " Unable to open formatted input file p.dat"   . would you please help us one more time ,thank you very very much! 111.jpg
发表于 2007-10-29 14:56:10 | 显示全部楼层 来自: 中国广东广州
xfzcgzs 兄弟,那两个文件复制了还要在里面运行的4 M) i/ L/ Q& R: U/ r* r
% k$ j5 n: K2 @/ K
但是运行后 procast计算时却打不开p.dat了, 不知道你会不会遇到这个问题啊
 楼主| 发表于 2007-10-29 17:40:45 | 显示全部楼层 来自: LAN
原帖由 xfzcgzs 于 2007-10-29 14:49 发表 http://www.3dportal.cn/discuz/images/common/back.gif' p" G$ Y: q4 R" H
9 \! A! O) ]" s3 Z& W) C3 R! E2 I# }) i/ E. L. g' S7 z
To use MICRO module you need to:
( l! X4 U, m, H5 k2 ?. J4 W5 ~/ H. z$ v. s9 p- K. E
1) Install ProCAST2006.13 I& P8 F8 Q8 y# r  B) a* j
: u( D  ~1 G" ?2) Replace original *.exe in "<ProCAST2006.1 program directory> \bin" directory with craked ones from archive in my post#11 Y- x* ]7 ]. S  r& _0 W# U
4 j" }6 m& V6 C; Y  f; r  u& K
3) Download a additional crack "procast2006.1_micro_crk_gellmaR.rar" from my post#46, unRAR two patches from that archive into  "<ProCAST2006.1 program directory> \bin" and run them& @( ?- r- m# I' y4 R1 z* ^
; V3 m# f# H& G
[ 本帖最后由 solid_user 于 2007-10-29 17:47 编辑 ]
 楼主| 发表于 2007-10-29 19:30:26 | 显示全部楼层 来自: LAN
原帖由 jojo1983 于 2007-10-29 14:53 发表 http://www.3dportal.cn/discuz/images/common/back.gif- Q. B* O' S4 ]4 ^& a% i2 b
dear solid_user ,
8 ~: E7 F! y% T5 e: J: z1 b        I'm sorry to trouble you,  I fall into a new trouble that the procast can not work after I followed the readme file ,put the patches into \bin and run them, the cmd informat ...
/ q, \/ q) B6 H8 ]: d% b" p- x8 s
I did not see such a problems on my computers!
& K% L! g& S; g8 T; q0 H  b$ ~$ [Did you create that *p.dat files in licensed or cracked PC2006.1?7 E0 G( \- W" ]9 c" S+ V0 ~1 U& R4 H
! R# P6 d8 D3 ^0 g; G9 c+ [
[ 本帖最后由 solid_user 于 2007-10-29 19:31 编辑 ]
发表于 2007-10-29 19:51:21 | 显示全部楼层 来自: 中国广东广州
oh ,may be that's my fault, The ProCAST2006.1 Installation which I didn't download from this forum because of our bad campus net . I asked a friend to send me an installation file which may not fit the crack,   really thank you very much ,solid_user.   I'll try to find a way to download the installation from the ftp and try again..    thank you
发表于 2007-10-29 21:53:31 | 显示全部楼层 来自: 中国广东广州
http://www.3dportal.cn/discuz/ftpse/    procast06R1下载
 楼主| 发表于 2007-10-29 22:52:44 | 显示全部楼层 来自: LAN
原帖由 jojo1983 于 2007-10-29 19:51 发表 http://www.3dportal.cn/discuz/images/common/back.gif% K- o- W6 a+ M& y8 N3 E2 M
oh ,may be that's my fault, The ProCAST2006.1 Installation which I didn't download from this forum because of our bad campus net . I asked a friend to send me an installation file which may not fit th ...
7 \- ^; A" ?% ]" t+ {6 F: Q8 J
It will be very usefull if you can compare ORIGINAL files in "ProCAST2006.1 program directory" from your Installation and from this forum ftp-Installation and report what files are different!
发表于 2007-10-30 09:27:08 | 显示全部楼层 来自: 中国广东广州
原帖由 solid_user 于 2007-10-29 22:52 发表 http://www.3dportal.cn/discuz/images/common/back.gif9 ?/ G8 S) v7 h* R
& ]0 ]% K2 f- i2 FIt will be very usefull if you can compare ORIGINAL files in "ProCAST2006.1 program directory" from your Installation and from this forum ftp-Installation and report what files are different!
6 R" H$ t8 [/ a+ U$ q2 H  G% r7 _$ S
' c  T) F% \. F1 a# F- @/ Ihi,  yesterday evening I got a installation from this forum ftp,which I found that was same from the installation I used before . The problem which i found out is on my operating-system . I'm sorry that I don't have ORIGINAL files,although I really wish to offer it ,in order to requite your big help.  I don't know that there are really a difference between the assemble module in meshcast and that mentioned in meshcast's users guide. I believe that you're sure to solve it some day ,cause you are our hero, thank you !!
发表于 2007-11-20 17:12:35 | 显示全部楼层 来自: 中国广东广州
非常感谢楼主的付出,尽管我还不能下载。提个外行的问题,楼主能否直接做个license文件,就象老版本的Crack一样?这样可能更方便,吹毛求疵了。% Q( A% E: `3 D  z" J0 x; W* @
yet,i thing if we can crack it like the old version that by using a license work?
发表于 2007-11-30 22:37:50 | 显示全部楼层 来自: 中国江苏苏州
我的procast2006.1在检查网格时老是应用程序错误,请问老大们是怎么回事
 楼主| 发表于 2007-11-30 22:50:08 | 显示全部楼层 来自: LAN
原帖由 wlm508 于 2007-11-30 22:37 发表 http://www.3dportal.cn/discuz/images/common/back.gif
: A; n8 Q2 T0 x! |我的procast2006.1在检查网格时老是应用程序错误,请问老大们是怎么回事
9 @! `5 k; u5 f2 g
7 \% C+ R! ~4 H* m. |. y& l8 VIt is ussual thing... MeshCAST can not automaticaly create a mesh on complex geometry with default settings
2 p8 n% U- q, j  q. M" @YOU HAVE TO EDIT MESH MANUALY! (read MeshCAST Manual )
* V" Q: G& ?( D, V, ^
: @# Z- h7 O2 i" R$ ~7 ?) ]Or use a Geomesh http://www.3dportal.cn/discuz/viewthread.php?tid=4056461 W: @! a- f% M
or Visual-Mesh for meshing models for ProCAST( |! [7 s; l& X; P
' \% e& |" R& X: h
[ 本帖最后由 solid_user 于 2007-11-30 23:47 编辑 ]
发表于 2007-12-1 07:53:30 | 显示全部楼层 来自: 中国江苏南通
我做那一个
发表于 2007-12-7 16:53:02 | 显示全部楼层 来自: 中国陕西西安
solid_user,you are great, thank u very much.
) ^# \1 K9 Z5 H$ z. h4 x, Hbut now, I have a problem.when I run "calcosoft result" or"porosity_post",It has the warming" no valid token for using this postprocessor" ,i don't know why ? Please help me!( t; N- i( M3 c1 H) L! W5 [/ y9 [3 g
7 L; d" q- ]8 w1 c[ 本帖最后由 bopie 于 2007-12-9 11:19 编辑 ]
发表于 2007-12-15 08:47:12 | 显示全部楼层 来自: 中国浙江宁波
原帖由 solid_user 于 2007-10-11 18:22 发表 http://www.3dportal.cn/discuz/images/common/back.gif
% j9 s+ i' h; G- X: O* f  k
' t9 O# H% Q4 M7 i9 q2 [- ?I do not use MagmaSoft and have no got Installation of that Apps...
8 m4 M9 [! @5 f" k
, Z3 C; f1 _$ A7 F+ o$ N. a$ c0 N: y; o: F! \: {
楼主,我已个传了MAGMASOFT4.4,麻烦您CRACK吧
