发表于 2007-11-22 11:18:22
来自: 中国广东珠海
thanks for solid-user!~ 但是MICRO在进行并行运算时好像有点小问题!~
4 t2 N" M }4 @( Z2 V: X! {' A
. e$ Q6 E) A: l2 h7 Jinformation:: {8 ]" Y( K* N% I) ?
E:\procast\abb7>set MPI_ROOT=d:\PROGRA~1\ESISOF~1\ProCAST\2007.0\HPMPI
( U! _( ?4 B/ |: ]E:\procast\abb7>"d:\PROGRA~1\ESISOF~1\ProCAST\2007.0\bin\datacast.exe" abb7- K/ x c# W3 f; w5 e* `7 N1 d" b# f
DataCAST Version 2007.0, Compiled on May 28 2007 at 14:46:49
3 a0 ?6 t2 ~$ `7 dWarning -- Velocity BC Node 6423 is in a non-fluid region.! |/ U1 v: [5 M: [8 C' Z
Warning -- Velocity BC Node 6627 is in a non-fluid region.) ]- V9 E/ B" t, u, a
Warning -- Velocity BC Node 12954 is in a non-fluid region.% D" P( l% P1 d2 w% @3 u8 i" n/ X
E:\procast\abb7>"d:\PROGRA~1\ESISOF~1\ProCAST\2007.0\HPMPI\bin\mpirun" -np 2 -
' d6 j: d. A8 g se LD_LIBRARY_PATH="d:\PROGRA~1\ESISOF~1\ProCAST\2007.0\HPMPI\bin" -e MPI_WORKDIR
/ k$ {5 K8 ^8 {* z1 _="E:\procast\abb7" -e ProCAST20070="d:\PROGRA~1\ESISOF~1\ProCAST\2007.0" "d:\P
5 Q- I2 x& b+ y! @* x2 o$ HROGRA~1\ESISOF~1\ProCAST\2007.0\bin\procastDMP.exe" abb79 W. o" v1 ?& ?2 J
WARNING: No cached password or password provided.
3 ^2 Q) t& u" y use '-pass' or '-cache' to provide password
" n e. m2 o7 M$ kHP-MPI licensed for ESI-Group.7 P+ m" U' Q2 a& @, ^. p) V. x1 b4 G5 C
ProCAST Version 2007.0, Parallel, Compiled on Jul 4 2007 at 13:01:29
4 U7 h. G5 [; }; ]- c: NCopyright ESI Group (France) 2004-2007- f4 C# s- s; _& E/ X8 S
Executable adapted for HP-MPI!* ^- g0 s+ _& q- x7 p
Phase Diagram Calculation Code& b$ V/ y ]7 n$ `. f- `5 \
Original code by H.L. Lukas, MPI, Stuttgart, Germany: r9 d6 p/ F. N4 N8 c' L
Modifications by U.R. Kattner, NIST, Gaithersburg, USA: |' G, K0 V4 A! O
T = 535.000000: Calculation of enthalpy failed for phase AL3TI
8 a5 \) I( t# b0 s7 `8 ]9 p3 uoptimal communication in use.0 |. D6 Y' Q& V+ z' {" }% t; T3 x
XYZ Cut: 9862 Balance: 1.000 [7536 15071 2]
: y& ^/ h' E, A% IFinal 2-way CUT: 1685 Balance: 1.011 avg: 1.011
2 V; j5 A% k7 \. u- o4 dXYZ Cut: 6030 Balance: 1.000 [2615 5230 2]
! A# i5 ^# m/ g; x9 c9 d& u+ P# lPartitioning a graph of size 5230 serially; ]9 S, @0 }; v" C: {- i
Final 2-way CUT: 535 Balance: 1.000 avg: 1.000 |
