X. ^- [3 m0 P9 f
# U, |/ h! o, H& j0 \/ N# V2.2.44下载 地址. S' q3 ~9 `4 c
0 A/ A" h3 k* v完整安装包:
0 b6 t6 z! A l% f' r" g6 j' i' _! V! [
Windows 32bit
" d% k# g* w0 Z# s0 g0 j9 E r# Chttp://download.keyshot.com/keyshot_w32_2.2.44.exe1 [$ k5 _* F* K# c i$ Q
- c6 W! m. l# G9 e e ^- R& ZWindows64bit6 H$ w- \( K7 h9 i* u
http://download.keyshot.com/keyshot_w64_2.2.44.exe
, C0 I) R0 g+ J9 n T3 q; B8 }: a( W+ ~7 M1 b
Mac OS X
# u( o+ q. @ U( o( S# i, D* jhttp://download.keyshot.com/KeyShot_mac64_2.2.44.pkg; C: x& ]( W- j% a0 @- p5 T
9 G c1 J) p! p- |
9 h. n0 {& d7 e/ G; p: I8 mUpdate - Software only (for existing users KeyShot 2.x users):
9 r( o2 V9 D/ t* H# ^& n: q, }% k D( g
Windows 32bit
* ^4 z4 Y( S) Fhttp://download.keyshot.com/keyshot_w32_2.2.44_update.exe
6 \' p- l z- `0 F. X m
+ t* u( X5 c: e2 bWindows64bit
2 s/ [2 L3 e8 ?1 b% a9 m7 b: G' k5 Ehttp://download.keyshot.com/keyshot_w64_2.2.44_update.exe
$ ]8 x9 Y- ? J9 z7 t& h7 ~
; j( W, m) P" HMac OS X
- f3 V) Z1 A& Q- l2 \! J/ whttp://download.keyshot.com/KeyShot_mac64_2.2.44_update.pkg2 N- d5 g% n Z* E+ [0 B+ z
9 B; h/ ^% W4 `' W2 F' A" }
" e8 q! y8 G0 V0 ~1 J$ d/ g. u. Z
破解补丁下载:2 B. l4 {9 k: K" s) G) K
$ Y9 ?8 t' W# y* n; r# b$ F# }+ Z5 D; ?" n- g
http://uploadmirrors.com/download/0GZLT0TG/2.2.44.rar X/ L: V* _' i) _5 ^3 t
*********************************************************************************************************0 G8 D: m! k, k
由于部分坛友反映用下面的地址进行下载后是2.2.43版
- ~& r3 Y O, ], y6 R目前2.2.43版还没有CK6 n# d- x8 v. \ g& V
我将2.2.42版上传到了网盘,大家可以到网盘去下载完整安装程序2 X# K I' D+ b9 }+ ?4 H: ~
$ W6 \/ x& C/ w. k5 |
网盘地址
& D% W( O( q8 ~$ {+ }7 ^7 dhttp://dyn.www.rayfile.com/zh-cn/option/
) H, d$ L. w3 W; K
6 u# a0 Q3 v' b! m ]( b1 g& Z( a) _KS2.2.42 32位提取码
( H! ~/ b* \3 E; T3aa7dc99-40c5-11e0-9eb7-0015c55db73d
3 D% e; O3 d) |+ l# d7 ^/ |
- a$ w& f' c- {KS2.2.42 64位提取码
: S' E4 t$ i2 t9 m& ]562c028c-40c7-11e0-bf16-0015c55db73d0 ]1 n5 g+ M* a: E9 g- f
* @: O) o7 I4 L9 Q- R+ s' G, a- N6 b9 s; i. c
3 l( e- d6 m; F* Q9 D' \: \
$ w# I+ S9 b6 S# c, D- L1 x( K
' ^$ {. v% ]0 g$ x+ D2 E$ i
官方多国语言(简体中文,英语,法语,德语,意大利语,日语,韩语,波兰语)
* K2 k* {# W8 ?, \1 r关于Keyshot 2.2更新的内容详情请点这里:http://www.keyshot.com/keyshot/whats_new.html
. _5 c ^/ `, u0 _0 A: R* Y" f**********************************************************************************************+ r8 z/ F: r) D$ q" Q/ x) j9 S
之前的 KeyShot 2.2.29 是BETA版,有很多bug。% ?: ~: o# O7 L- C' y6 K5 l
后来 2.2.33 中文版推出后,发现有很多汉化上的错误。
- L& ]' n: C% _3 u; I! B8 H* A在5个小时前 KeyShot 2.2.42 版本又放出了下载,这个版本把之前的错误进行了修正! v* B! \5 }+ p' T2 G3 Q
******************************************************************************************************. H5 }6 k/ A! {( a
2.2.42相对于2.2.33的更新内容如下:* `, ~& j$ p$ |
我们很自豪地介绍KeyShot 2.2.42。此更新包含这使得它更容易,比以前更快地创建三维CAD模型卓越影像几项改进。 " i/ {+ q* k; s1 E3 n# [2 z8 `
# }2 }" H& y2 {" }: qKeyShot 2.2包括以下主要改进:( J" p: ^0 d& @: A* E* y1 h
1 Q- }+ \9 M6 s8 E- n8 [9 @
" s1 |; @1 R, \& E6 P/ `9 ~
*保存模型在CAD模型,包括所有层和组件结构, d" ^, W _; e* z
*与更快的实时交互复杂的对象" }2 A2 N. y q) j% [ H
*先进的材料和复杂的设置提供高达15倍的速度
3 C/ ~8 G# k" @8 I3 y. S% f *支持3Dconnexion 3D鼠标
; ]/ c1 T) ^5 n" r2 @ *能够重复的对象直接在KeyShot几何1 W, K+ G: C- g; c, b1 I
*进口和出口的材料* o; i, I" t0 d3 `3 y, T5 B
*更方便,更强大的发牌
5 G% u: r0 `- @5 \9 W7 }4 i" H' W* ~. j5 |
3 A) ?- A# {1 N" w! H6 x S2 D
*使用较少的内存,并显着高达50%的速度提高进口商7 S2 a5 P8 E* a7 d- Z$ H, [
*支持多种新的CAD格式,包括SolidWorks的2011年,CATIA V5的,
/ i% d7 i6 F' L/ |5 m0 S2 Q* W FBX的照相机,Autodesk Inventor的AutoCAD和SketchUp中8
' I/ q- p m: p1 ] *中文,法语,意大利语,韩语,波兰语附加语言支持: t' @2 u, ]; r1 y; W% o8 J1 ]
*能够保存KeyShot包(。溶度积)的所有几何形状,材料,照明和纹理文件1 z( x* t$ D' x! m/ f) q
) U. J) a1 [; M+ w一种全新功能的完整列表可以在这里找到。 KeyShot 2.2是所有现有KeyShot 2客户免费。2 P- F q$ L1 V" X9 w6 E
$ C1 i' R8 h9 a8 y* e' V下载地址
) B$ W, X1 F9 H" J* y4 G在KeyShot 2.2中仅需运行“检查更新”(破解版不建议使用)。6 V' q+ ]; S, j( n* i v
1 s% v, e& P) _
在KeyShot 2.1中使用下面更新安装:
6 i4 [$ y5 e" ]! d
4 u( P* ^1 c; a% M% ~; |win64: http://download.keyshot.com/keyshot_w64_2.2.42_update.exe
% S( ^# N+ g: v3 Z8 u" h# pwin32: http://download.keyshot.com/keyshot_w32_2.2.42_update.exe* S) c& a& }: U( N
mac64: http://download.keyshot.com/KeyShot_mac64_2.2.42_update.pkg5 M% g/ t9 ~" o- K8 O
$ W4 Y( P: a% l
运行2.0.x或全新安装的,则需完整安装包(建议大家安装完整包):' H5 K A; Y N* \
: M: M# r2 G- e1 r+ p) H5 M- O
win32: http://download.keyshot.com/keyshot_w32_2.2.42.exe" Y8 t( Z7 q. ~" e- h6 c5 P, R
win64: http://download.keyshot.com/keyshot_w64_2.2.42.exe2 B. o1 D; c# m& I
mac64: http://download.keyshot.com/KeyShot_mac64_2.2.42.pkg& _% a7 d; L$ y5 n- ]
$ I6 P6 b. d: t8 `CK文件32位4 f, P+ F% G# \+ D. g' v' Y$ n
http://u.115.com/file/f482a9583a
$ l+ _( t8 x& n: S0 T) a# F+ SCK文件64位: q) d# }+ M3 A+ k
http://u.115.com/file/f4c316f525" ^3 Y/ [, p. F% P
% P, e; X7 F4 f/ T+ V8 q/ W# V破解补丁说明:
& ^- Y# Z" ~) `5 T& v1、下载并安装keyshot,安装目录注意不能有中文9 q8 U' k6 J! X- Z
2、解压补丁包,解压前把杀软关了,复制keyshot.exe到安装目录\bin,覆盖原文件,注意做好备份
; L3 u5 D6 I' O5 f/ G3、运行keygen.exe获取你的lic文件,保存到安装目录\bin中
0 e7 ^# j; O- N3 W/ F1 X, m4、运行keyshot,点击install license,选择你从第3步中获取的lic文件
6 y1 I# V8 z U& v- y+ q5、完成8 ]+ C+ ^5 U$ [" |& F! P5 B8 K
8 ` @5 D+ d y4 \- G4 ~# L注意:
d5 g6 b: ^& W$ F4 N1、下载完整版本full install" C- {- i1 Q6 V; E, B. U
2、安装路径不能有中文,安装过程中有两个地方
( T) l; @ m8 c4 |% c0 A3 }3、破解时要把杀毒软件和安全辅助软件暂时关闭
3 R* A, @6 T. {
) ]3 E" j. d. \7 Z7 `安装破解完设置为中文界面的方法:
% n k% z1 I6 Y d/ \, EEdit→Preferences→User Interface→Language→Chinese→OK→OK→重启Keyshot→完成; E/ t* I3 ^( }6 t7 t o
**********************************************************************************************. R8 f9 F8 t% Y: R- y. d3 J7 R4 q
KS2的材质汉化方法,汉化文件见下面的附件3 i9 i" E* O$ w
直接复制Materials中文件到KeyShot Resources\Materials 文件夹替换就OK
, N, x3 d4 k j: Z& c: a. \
5 E* P. A- s+ y5 U5 \, c2 M+ m1 l; y% Z1 g
KS2 材质汉化文件.rar
(14.3 KB, 下载次数: 100)
