10天前
查看: 2718|回复: 2
[推荐] 西门子发布最新的Solid Edge ST2 补丁MP12
发表于 2011-3-8 08:06:22 | 显示全部楼层 |阅读模式 来自: 中国广东江门
Dear Solid Edge Customer:
+ g6 ^8 g8 E0 N4 X9 K
We are pleased to inform you that Maintenance Pack 12 (MP12) for Solid Edge ST2 is now available for download on the GTAC FTP server.
. h$ r- E3 p9 M' S0 x, [8 o
This Maintenance Pack addresses issues reported by Solid Edge customers. We appreciate your participation in the software support process - - your reporting helps us make Solid Edge more productive for the way you do business.
8 z- y( @, L& `6 O& [
Sincerely,
- S! K4 U) }9 w0 w
The Solid Edge Team
2 l+ y( B$ z- W; I
+ b# \# @: L$ q. b/ E0 J
Download Location:
$ `. o4 W6 }# P8 x( F
( }: J/ F& A0 k( r
Solid Edge (Maintenance Pack)
- L, T) t  [7 i1 M. R: o/ z
  @5 |# [/ u! A, F1 i
Solid Edge Insight Connect (Maintenance Pack)
/ N6 j" V: j3 W$ b0 `
8 `1 E% y5 ]3 I( ?7 {  |* z7 I
Solid Edge Viewer (Maintenance Pack)
: ^- o/ R2 G6 q2 t' i* F# I% l
/ Z6 Q  Q0 z0 T# g6 a0 o! B9 w
Solid Edge Mold Tooling (Maintenance Pack)
. ?1 P; w! W$ m' t5 Z+ u
; W- p: b  e1 b7 B4 m
Solid Edge Insight Server WSS 2.0 (Maintenance Pack)
: m3 b  Y1 K6 ]2 M- j0 s) u$ s  v+ A* r8 A. n8 G$ G
Solid Edge Insight Server WSS 3.0 (Maintenance Pack)
4 a5 \" k9 `- M. b0 Z
/ i& i0 v9 M7 m8 ]9 Y$ E5 q. K; q
Solid Edge Embedded Client (Maintenance Pack)
# C. u7 @' l" A5 F" i
. {7 Q/ B, ?! g+ C
Solid Edge Embedded Client Administrator (full install)
- c; H1 V3 Y3 ?# W( J( Y+ A( A4 o# r) a; L
/ r: L( L' a  p, J' d9 Z. J/ s
Installation:
9 }  L: B  W9 q) T/ ~: O3 j7 u
8 a9 A: l' Y9 j8 p& Y& u
After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on setup.exe to install the Maintenance Pack.
, r- a( {# ~9 A- F& U1 g
! }0 T/ P- @6 S8 j- d* w- T" y. |
E-mail Notification:
9 h" b4 Y/ v( \$ `
6 L) T, O" v( K; U
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: http://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com
6 S' Z+ X6 c' ?, ]- S
: O. P- g; K" W3 J6 R; ?; W
This Maintenance Pack addresses the following PRs:
0 \# X9 E# n& c8 w; \5 i  }5 K1 {
8 p) y4 q% m7 f- z# o" |
===API===
: S* n* o4 a5 \5 W
PR 1826916: PropAuto.dll library in SE ST2 MP11 returns wrong string values
( v+ Y( k; `6 j3 O9 v7 v
=====Assembly=====
+ H9 [2 D7 F9 w0 z, \; R
PR 1824462: Fixed crashes identified in the crashlog analyzer
% r# z9 ]7 ^2 I5 {' ]
PR 6464369: Fixed crashes identified in the crashlog analyzer
, e* I% ~0 g4 `, U8 v
PR 6474039: Fixed crashes identified in the crashlog analyzer
; \5 g0 B( k1 N+ Q( ?% d. u( ~
PR 1819591: Assembly aborts when creating relationships
% r* Q# H# }' f
=====Draft=====
9 v! N, p0 N  D+ b) h/ r
PR 2162210: Thread Display Mode changes value when Apply button is clicked on other property pages
3 W5 D( }( u: V2 M* ~  a/ q
PR 6327121: Fixed an abort on close if dim tracker has been run and something remained in the select set
2 k$ v$ T; z$ T0 F8 ?) _0 g) j
=====Part/Profile/Sheet Metal=====
5 o0 P, q5 w" A' c- D
PR 1824158: Invalid relationships created when Relationship Colors is on
- }! Y9 }+ w0 u+ ^% T1 ?
PR 6417621: Curve by table does not work with Office Pro 2010 (32 bit)
& q( h# v' R; E: B, Q% _
PR 6475818: Send Mail & Crashlog tracking failing under Lotus Notes
1 V5 t9 A% ^& L
PR 6466294: MP11 will not install on a 64bit Windows 7 machine that has MP10
+ B5 q) f1 J# C5 P  h6 u
===== Solid Edge Embedded Client=====
# |) q9 m& c3 g2 H
PR 6401679: Save As Draft puts the part & JT data under the old item revision
. i. Z$ |. h9 q, H4 d  M, ]
PR 6458567: Crashing during Save As on large assemblies
- F! t! S3 t" L; e' i3 a0 o# S
PR 1795398: QAT customization causing uncontrolled memory growth
发表于 2011-3-8 08:25:39 | 显示全部楼层 来自: 中国北京
ST2的补丁已经用不上了
发表于 2011-3-8 15:23:07 | 显示全部楼层 来自: 中国安徽六安
呵呵。你用ST3当然就用不到ST2的了
