Dear Solid Edge Customer:
0 H# K: J5 I8 y4 sWe are pleased to inform you that Maintenance Pack 3 (MP3) for Solid Edge ST3 is now available for download on the GTAC FTP server. $ r7 F2 f, W; a7 T; r. X
This Maintenance Pack addresses issues reported by Solid Edge customers. We appreciate your participation in the software support process - - your reporting helps us make Solid Edge more productive for the way you do business.
8 r8 r8 [6 c! W% ?' S7 n3 E# jSincerely, 5 C& A! k. d& ^4 j/ f5 \: v0 u
The Solid Edge Team
- P& \5 H9 w5 m! _9 {0 j4 x3 p================
, B" h' u l& ^9 F( S2 lDownload Location: 5 ^3 {) h; L- f
================ & u$ \7 }9 f: l x/ m4 d* N
Solid Edge (Maintenance Pack)
! ]' x I w+ l# h0 f4 K: W& ^: `. B8 e% F5 E
Solid Edge Insight Connect (Maintenance Pack) + ]' J+ j9 v3 S% x9 P4 P$ Z
0 o- g7 s' a0 S2 Y! q3 E: cSolid Edge Viewer (Maintenance Pack)
2 A3 ?" I: u6 B3 |' ?6 E. ^2 h9 B( Z& }( P: W2 D8 H5 o
Solid Edge Mold Tooling (Maintenance Pack) 0 H) C: {- `& l7 p& K2 s$ B
u$ @& t% L8 t
Solid Edge Insight Server WSS 3.0 (Maintenance Pack) 5 ^1 ?) U. ?& j) u# `% S0 P
2 U( Z9 i2 Z8 x/ D
) `: c$ B8 O2 \$ r: D3 B/ [Solid Edge Embedded Client (Maintenance Pack)
/ r- ]$ j; h% u) O# k, c0 ]. M3 d2 X1 P7 R$ W/ H1 d3 g. |% z6 ^
Solid Edge Embedded Client Structure Editor (Maintenance Pack) % J# M' W' u) E5 n- _
# s$ d, s& L# u% d( U8 j2 O$ D
Solid Edge Embedded Client Administrator (full install) 4 G" h. o/ n2 f8 C U
$ P% _ |3 x7 u9 x$ i& }5 Y9 e==========
! @, [1 F7 }7 g* |0 EInstallation:
& ?: _% k9 Z. E2 @ M/ W* Y( ~==========
7 n2 E* l( V% h7 t- g4 [' |After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.
* v0 J) D8 J5 a% OWindows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation. , Z3 C: W* G9 k+ |' O) q8 y
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to.
3 Z, V3 d3 e' D$ C: O8 N5 s=============== 4 _% N7 x' A' r ~& j6 R: h% u
E-mail Notification:
3 a0 T' I @4 p- I% G+ J- U===============
1 J- ^9 N2 h! G! q! k/ v5 {2 e- a# G$ e0 t& E" G! f. s
========================================= 8 ?( k$ J" `. V. u6 @7 }; U
This Maintenance Pack addresses the following PRs: 2 S2 i( p* M3 R/ w q
7 C: _ n+ z* ?; w L% @9 I, L===API===
- x' i+ [# X9 n- `# s6 s" oPR 6426380: Not getting Colors in SEPartReader, SEReader
) L. n H' R1 _8 V: e# X5 d0 J2 x4 G* I===Assembly=== ! t( a3 `6 G3 `. k
PR 1824462: Fixed crashes identified by crashlog files 1 @& f+ G- d7 j! |* k! W# C) ^& T/ ~ L
PR 1826468: Path name length is limited to 129 characters in Property Manager # q4 {; \% B# k/ Y& c) G: ?
PR 6462576: Solid Edge crashes after selecting part of SysLib after placing it s0 C3 x# U4 u5 c/ y6 P
PR 6465652: Abort if save is clicked while config file open dialog is active , g2 |. F g, D7 B+ H9 d
PR 1829176: Unable to activate zones with double-click 0 ^ X; @+ w3 ^/ y
PR 6471148: Display performance is slow on rotations and zooming 7 Z1 a9 O- q U9 b6 ?( j u
PR 6474039: Fixed crashes identified by crashlog files 4 @& Q. s$ b! g9 e' K% `$ D4 A
PR 1815765: Unable to open Catia V5 R20 part files
; j4 K2 y; V( C4 f1 y6 d' `PR 1828742: Solid Edge Frame Design / Routing API.
) p! M/ O6 }& w$ W# K; oPR 6417945: the default location of the Quickbar / Assembly Pathfinder is not correct in Sketch % x/ ]+ B/ e2 ]$ D2 S
PR 6429834: Patterned frame members list is on separate line item in Parts List
+ P4 z7 \& F. B# H8 a8 oPR 6461646: scroll to part results being obscured by the relation tree
% q9 A3 C7 Z' ]' }3 iPR 6470893: Solid Edge is slow to open a Parasolid assembly
$ G. {& {' X ~4 j. I( \+ Z' R" jPR 1819591: Assembly aborts when creating relationships 3 L8 d: x8 C; ~' D. e4 k4 d) G$ B
PR 6469074: Assembly reports are not picking up custom property values
# S' O; Q g, Z! ~* t- fPR 6472642: New Menu Starting Wrong Template 5 s6 c1 A3 K$ E% S
===Draft===
$ Y& e$ g; B$ T" X# fPR 6327121: Abort on close if dim tracker has been run and something remained in the select set 5 X) D9 C$ `. Y# n5 f C
PR 6357213: Callout Text gets merged if Alignment is changed to Center or Right 9 }' c3 i: |" Y
PR 6412216: Dimensions detach on update
: j; K0 p# p' }" `- k4 N4 fPR 6427966: Part aborts revolving a synchronous cutout
0 c: v8 l/ n m+ q# KPR 6429679: Exiting profile causes an abort # h) r8 ]& K: F3 {8 t" l
PR 6454096: Cannot exit edit boundary environment after ctrl-drag of 2d object . m" ^$ `! M! M- F5 h1 l% V
PR 6456030: Solid Edge open DWG Options/Review are not giving the correct sheet information / L! L- z W! w$ V8 K; f
PR 6456838: Can't place a dimension in a Detail View using dimension axis
9 N$ T5 W- ]: Q4 [PR 6464949: Parts list moves up and left by .175 mm when opened , W' }% D$ V8 y! \+ M
PR 1816750: Cannot select elliptical arcs in hole table command
4 b* J* O W' u, v0 a" ^PR 2162210: "Thread Display Mode" changes value when Apply button is clicked on other property pages # \: L' b; V9 S, L5 g
===Insight/View & Markup===
. \ @) O6 o' j2 ]: R' _# SPR 6457292: Failed to generate document libraries property mapping information
4 h" P# n6 B3 |8 j2 e$ [PR 6465929: Insight server log files cannot be generated for SharePoint 2010
8 ^ G: ?! Z% dPR 6466137: Registry key VMOnSaveEmbedViewingLink not delivered in ST 3 ! {. c# L0 q% d: o+ x$ n7 X
===Part/Profile/Sheet Metal=== . u! }" ?4 t9 W3 W/ m5 }
PR 1776878: Callout for %HS is incorrect on Part Copies
6 }: H! R, E, g1 z3 KPR 1824462: a crash that may occur when imprinting curves ( i" p" L9 i6 P# t
PR 6367518: If Relationship Colors is on, no indication when dimensions are failed
- A" g2 T! l9 w& q* hPR 6434556: a crash occurring when locating items in pathfinder after closing a file 7 X* @5 ~! U6 ^+ {, B. u8 z
PR 6453116: Immediately after rotate you see a flash of the model in a different orientation
8 p6 o0 n' @& ~* S+ }/ ?PR 6456053: Sync Hole gets deleted if it’s used sketch is deleted after a Move to Sync
) U0 u+ W0 u' u% P- _ sPR 6467561: the Solid Edge process hangs around after selecting a region then exiting
# {0 |. T9 m2 X4 F9 ^PR 6468272: Unable to edit a dimension value with a key-in after scrolling with mouse wheel ( J) o( k0 y4 M( o* C
PR 1809044: a crash is occurring when trying to open a Solid Edge file
/ G# ]( a* I$ m3 e$ z3 I9 aPR 6471224: the concentric live rules turning red when using local symmetry option 0 A2 u. `6 _9 g$ ]
PR 6471336: Dimension display disappears during edit formula ; ~) }/ T0 M! I" P5 e, X' `
PR 6473059: sync move appearing sluggish on keypoint locate : V: k/ K) b2 M+ K. J9 h2 Y
PR 6474371: Cannot pattern a hem 6 J! `8 [$ ^9 l& n/ v% d
PR 6475818: Send Mail & Crashlog tracking failing under Lotus Notes 3 F7 l% w0 ~. p. _! _& R$ C! O
PR 1827775: Displaying the FOP table takes a long time
* {2 `' s1 _( d5 _PR 2163514: "Show Only Overridden Variables" of the family of parts not being displayed & x" |& W7 {* c, }% x( d
PR 6477746: Cylinder from a Lofted Flange in ordered sheet metal part has incorrect flat result |
