我用lisp语言编了一个程序,想将它放在菜单栏上,由于和04版的差别很大,不知道怎么做了,求高手赐教!谢谢!!
7 U/ l. q: {4 c& J+ n4 a ?9 Q, q程序如下:
" G! H+ {6 D9 }! l% @. I$ s* V/ N(defun C:ring();% \) }9 x) Z$ N+ ^% W1 t
(setq pt (getpoint "输入圆心坐标:"));2 @7 U; |( @5 N
(setq r1 (getreal "输入内圆半径:"));( n1 a! D! v2 X9 Z ?
(setq r2 (getreal "输入小圆半径:"));! X; G/ y1 @9 y; Z
(setq r3 (getreal "输入外圆半径:"));
. m" @* _9 w" B& C" i (setq n (getint "输入小圆个数:"));
9 ?$ u1 I z1 O# H* t (setq pai 6.28318);* m4 n0 T& }& g' H. ?; b9 w
(command "circle" pt r1);+ G' W2 E( }9 g- E6 \& j
(command "circle" pt r3);
& J, \% \, V, r8 Y# J (setq r (/ (+ r1 r3) 2));* C7 O9 ^9 M# Y# b; a& u8 w& Z
(command "layer" "M" "1" "C" "BLUE" "1" "L" "CENTER" "1" "S" "1");, ^4 A5 F' R! C" q. `* E
(command);
% u( B5 s. o. ?8 O+ z7 i: ?6 r (command "circle" pt r);
0 {6 j/ A* i! F' N (command "layer" "M" "2" "C" "RED" "2" "S" "2");3 V" a0 u# U5 @. M
(command);
* n% N& g! ^ y- o (setq gle 0);' m: H; V. o/ }/ }5 X7 M
(setq k 1);
0 a( ?* ?/ \/ o$ r3 Y) a- O (while (<= k n);; X* Z7 k1 h* F9 M% e; _
(setq gle (+ gle (/ pai n)));
, k% c9 U! `% _7 Y6 c" Y- V' | (setq ptn (polar pt gle r));6 S5 a0 Y) [% I" G2 l3 }
(command "circle" ptn r2);
- ~% P1 A% b! F2 z; B, c (setq k (+ 1 k));
. g) z0 u) h/ |$ \( _8 v' E* B );
, M/ V. x$ p% D( h( a8 ]); |
