查看: 3126|回复: 5
[求助] 車床車牙後處理問題!!高手幫忙修改一下
发表于 2011-4-13 13:26:18 | 显示全部楼层 |阅读模式 来自: 中国台湾
車床車牙後處理的進給E希望能改成F,那位高手能幫幫忙一下% Q% E( G  w! \- }0 k0 F
2 u5 l0 W- X  \, F0 `: t0 q
O0000
0 r+ x( L, A3 T. o) M1 L(PROGRAM NAME - T): s8 Q: @/ [: f& P! J
(DATE=DD-MM-YY - 13-04-11 TIME=HH:MM - 13:21)
5 D7 v, K: h1 A( G(MCX FILE - T): ^2 P; }) K8 N( {" H
(NC FILE - C:\MCAMX\LATHE\NC\T.NC)
) t* C' Z& K, |& m( B) y& S  m(MATERIAL - ALUMINUM MM - 2024)
( k6 D0 \) {% _( s0 sG21) i8 g' u0 J0 x2 U& d
(TOOL - 3 OFFSET - 3)* A; d/ c/ \! A" e4 ~) L+ h
(OD THREAD RIGHT-  INSERT - R166.0G-16MM01-100)8 t& \! Q0 P: u/ `
G0 T03038 ^4 u: P8 X) M( ]; D  c' K/ A
G97 S1000 M03
8 s" M% b# u, M+ eG0 G54 X12. Z5.245
! Q( v7 o* X& S8 J5 RG76 P010029 Q0. R0." Q$ |* K' T5 ]5 M
G76 X6.647 Z-10. P6766 Q2621 R0. E1.25
3 w2 D4 p4 O1 d% Z' x
G28 U0. W0. M05
( ~% b# g, M9 |  k& m3 pT0300
% }( t& o# Y/ f5 O; rM30
发表于 2011-4-13 17:17:31 | 显示全部楼层 来自: 中国浙江杭州
我也遇到过,试试吧。- ]. ~1 g' _' m0 j% E- [5 f
两个办法:6 _3 m5 X9 A: j" s; e- f
1、直接将E改为F;
% y+ g, V% R. L5 |2 L6 c& h2、修改后处理Lathe输出函数:
& Y3 I! `' a( X+ O8 v% m6 C. upffr            #Output feedrate, force
2 d) e) D! g2 D# K- _2 }6 U- U; |' f# ~      if ipr_actv$ = zero, pfr_m
6 G+ v" o9 j+ b3 h- z5 X" }      else, pfr_l
( M: V& [. F  \) Z; m- A      *feed. O; X! z9 F5 T. M% w0 a
; ?1 B3 u6 o7 T4 b; f  Zpfr             #Output feedrate
1 Z0 N! P7 |, ]6 ^# n1 j, T      if ipr_actv$ = zero, pfr_m
! x9 z5 }' |. ]  |( T* }      else, pfr_l! z( q7 V, Y) }7 X$ F
      `feed5 X9 R. {  G, s8 H
5 q6 `1 D9 |$ q6 S* d& Wpfr_m           #Format feedrate for mill  P1 i( y7 [' g4 q2 Z
      result = nwadrs(strf, feed)" b& j: k- ^9 k4 `" V4 X
      result = newfs (17, feed)- L4 f6 l# t  h/ k
2 s, @# l0 q  w9 _/ u8 Upfr_l           #Format feedrate for lathe, c6 n1 M: y$ o& Q+ k
      if opcode$ = 104,1 G3 o7 a% I, i9 [; w
        [( t- N$ r, X! q& I2 q0 }
        #Format feedrate for lathe thread
/ M# a( j4 x3 F2 h* {. K        result = nwadrs(stre, feed)   #stre改为strf,即“F”  e6 G2 M$ `4 H- w) a
        result = newfs (19, feed)    #19->18
1 O+ n& A) g5 B! _) e        ]
# S: F7 i0 s$ x; [      else,3 d% E" K! f4 [
        [7 g) ^7 ~; ^  `+ o4 J0 B
        result = nwadrs(strf, feed)" z0 O5 B/ A, E$ K/ o- [& I$ ~- K
        result = newfs (18, feed)
' D# g2 u  ^0 {) O, M. @        ]
pengxiangxu + 2 技术讨论
发表于 2011-4-14 07:25:46 | 显示全部楼层 来自: 中国浙江杭州
还是只改stre吧,下面那个19最好不要改,我也不是很会post
 楼主| 发表于 2011-4-14 07:53:57 | 显示全部楼层 来自: 中国台湾
+ A/ M. s5 n& o0 H' f
& E0 A* F# d# C9 ?* s( }感謝兩位為的指點,小弟試試看去!!
% T! V4 A2 B: T) r2 e/ @! t
) j$ [6 f5 ?* Z0 [1 s& w2 h真的行了^^感謝!!
发表于 2011-4-19 15:53:18 | 显示全部楼层 来自: 中国广东东莞
用默认的就是F
发表于 2012-11-23 14:20:04 | 显示全部楼层 来自: 中国台湾
學到了後處理器輸出修改
参与人数 1三维币 -2 收起 理由
路过不买 -2 挖坟
