3天前
查看: 4061|回复: 5
[分享] Elecworks for Solidworks 2.0.2 Built 5
发表于 2011-4-14 14:31:13 | 显示全部楼层 |阅读模式 来自: 中国天津
; ^2 w: v8 `8 F" XElecWorks - a software module for the electrical design in the environment of SolidWorks. Elecworks functionality to automate electrical engineering, as well as increase the efficiency of production of working drawings.! R" u# \! C6 k4 U1 L
4 f* b2 ^7 y0 GSystem requirements:* Z: ?  ^) N* y. }  M
Tested on Windows 7 (Max) (x86) + Solidworks 2011 SP0.0 (x32) only on version 2.0.2
+ h7 x+ ~% w! Y3 zOperating System MS Windows XP / Vista / Windows 7 - 32bit & 64bit0 i# O7 Y1 }& ^! w* ?4 h9 }
Graphics 1024x768 resolution with minimum 32768 colours$ s2 G* N% r* d3 {* M  f
Disk Space 15GB free; y# _$ {! C+ a5 X, L5 |
Memory 1GB + RAM (2GB recommended)) b# e* Y5 r, q( |; V% u. K( ]1 ~
5 b' }2 `8 {1 W- ?
& o. K# A3 r  Q7 ]% O3 W, n
' v! \3 j7 B# Q' d$ G: ~3 qFeatures:
, B% ^( R2 L; B5 O8 A3 V" b* Means of circuit design. The program allows you to increase speed and accuracy of the creation and change of electrical circuits.& R+ T" J8 g2 C6 n% t! h
* Control I / O and control PLCs.. y0 J8 i$ N! @- ~$ M- E
* Instant Messaging. Messages in real time.5 b% N$ q, C) L7 k9 u4 S
* The navigation tool.
2 V6 d4 f+ }! N3 b* Multilingual interface to be used.
, t. Z% M4 k% b( y* Location and correspondence management functions with the norm IEC61346.3 ]* P3 D9 ]  P& J! E% k
* Print files in PDF, as well as drawings in native format DWG.
& U6 k4 e9 u8 o$ r, H9 e* c* Tools to increase productivity. Full range of specialized features and tools for electrical design allows you to increase productivity.
. [3 X2 \6 w' C0 R# s$ B* Control and prevention of errors. Automatic verification can detect errors prior to release products into production." q, s% b+ O7 M9 f6 H8 P! q) r' i
* Data management and reporting. In the working groups is the possibility of organizing the project and data management and reporting for the production units.* t/ |7 ]% a5 O- X8 c7 u
) e2 V. o  w# w2 D8 M8 ^4 W& U) I
Home : www.elecworks.com
3 z9 F, W8 \. L* N9 B6 G1 [复制内容到剪贴板) ^7 j# I+ \; a. f
代码:
- [/ B" z- {- b: V4 P* d/ UDownload from Hotfile.com:, T& F* f% `: c; ?1 B6 f( M
http://hotfile.com/dl/97410454/171f13d/Elecworks2.0.part1.rar.html
3 D; h9 E9 O' M% @$ T. \5 |http://hotfile.com/dl/97410391/a778df1/Elecworks2.0.part2.rar.html  c) `% O7 d' x, B1 r8 j2 e6 k+ @1 K
http://hotfile.com/dl/97410479/087596f/Elecworks2.0.part3.rar.html
( o. o5 w9 ?) X# D+ fhttp://hotfile.com/dl/97410534/4f3ddcf/Elecworks2.0.part4.rar.html1 \: H9 d5 {6 F, O8 \
http://hotfile.com/dl/97410611/6f6fac4/Elecworks2.0.part5.rar.html( ~8 q- S  ?) E6 r' n; B
http://hotfile.com/dl/97410765/7c78a4a/Elecworks2.0.part6.rar.html0 j! g9 n% S5 m* V+ ]' E
http://hotfile.com/dl/97410484/f1f1f3c/Elecworks2.0.part7.rar.html" ~% H6 g+ ^6 [& |- t3 y+ \
+ x2 {$ A" D& I4 F: i6 n
From FileSonice.com:  N/ G  p1 k- |& d- G1 f$ r
http://www.filesonic.com/file/59343111/Elecworks2.0.part1.rar" Q% m2 P: l0 g  m
http://www.filesonic.com/file/59343125/Elecworks2.0.part2.rar& D9 J  P3 {, b8 e1 I' @/ y
http://www.filesonic.com/file/59343741/Elecworks2.0.part3.rar
6 _9 v9 E' c8 h" W( y& qhttp://www.filesonic.com/file/59343205/Elecworks2.0.part4.rar
+ D" o2 z) x& l9 I; Jhttp://www.filesonic.com/file/59343555/Elecworks2.0.part5.rar
1 ?. `9 F: j( H4 fhttp://www.filesonic.com/file/59343607/Elecworks2.0.part6.rar
' X) E5 }. Q6 G; {( hhttp://www.filesonic.com/file/59343547/Elecworks2.0.part7.rar
0 _) K; a. p7 b* K
5 p; u, {2 p- t" V2 H6 |6 \5 ]: ~From Fileserve.com:
+ K, \& p7 _" p7 `, M- z9 ?http://www.fileserve.com/file/XZb2cB8/Elecworks2.0.part1.rar) }3 U  W2 Q% }' i5 g( C
http://www.fileserve.com/file/aDA5CBk/Elecworks2.0.part6.rar+ M* W' \8 E9 Z+ w- m3 k
http://www.fileserve.com/file/3paZyft/Elecworks2.0.part5.rar9 r7 M# D7 w* ]* ?3 ^  P) k
http://www.fileserve.com/file/VV4KedV/Elecworks2.0.part4.rar
; |9 Y/ b0 e, E5 T4 b% y- Q) Dhttp://www.fileserve.com/file/kFNnUPG/Elecworks2.0.part2.rar0 {3 G+ @% z: ]
http://www.fileserve.com/file/t4hBp5f/Elecworks2.0.part3.rar
4 E5 {+ z" a! x! Lhttp://www.fileserve.com/file/upVt3EX/Elecworks2.0.part7.rar
/ M9 Q9 R$ r7 K: ~  E- p$ R$ ~4 d+ ?0 y4 I# v; p7 g: \% |
希望有大哥下载后上传分享,据说有32位crk
发表于 2011-4-14 22:01:18 | 显示全部楼层 来自: 日本
Hotfile的地址無效,filesonic的下載中
发表于 2011-4-15 07:50:36 | 显示全部楼层 来自: 中国广东汕头
什么插件?楼主介绍一下
发表于 2011-4-17 19:47:37 | 显示全部楼层 来自: 中国江苏苏州
Hotfile的地址無效,filesonic的下載中9 {0 Z$ B) o1 }1 `
sihouko 发表于 2011-4-14 22:01 http://www.3dportal.cn/discuz/images/common/back.gif
确实存在这种问题,期待楼主更新一下位置!
发表于 2011-9-1 14:06:31 | 显示全部楼层 来自: 中国上海
/ j, y# [$ Y' q# F1 ?- d$ H9 c# k8 [3 b2 x# C: n- D1 G3 M( g" v
这里的链接里有rapidshare的链接可下,不过得翻墙8 j9 |2 t1 z- |, x
1 R2 n* N+ E0 Gfilstop.ru/soft/37851-elecworks-205-x86x64-multilangrus-crack.html" G( K5 h; a% B
) D# O! Y! {  w. r8 b. I* T' K
+ e; B1 ?2 H+ T- B  \Скачать бесплатно программу ELECWORKS 2.0.5 x86+x64 (MULTILANG+RUS) + Crack 3 U6 E1 o/ J4 J6 P0 s
9 d  y9 @( @* u
  E2 M$ U3 ?; g0 G8 e7 Wrapidshare.com/files/442071478/ELECWORKS.v.2.0.32bit.x64bit.2009.MULTI.RUS.crack.part1.rar/ t2 i" I1 ~# r0 g! T. A
rapidshare.com/files/442071657/ELECWORKS.v.2.0.32bit.x64bit.2009.MULTI.RUS.crack.part2.rar! _3 q! t, T. [  w
rapidshare.com/files/442071878/ELECWORKS.v.2.0.32bit.x64bit.2009.MULTI.RUS.crack.part3.rar
8 {/ l  X1 }/ F$ \7 T' [+ q& Arapidshare.com/files/442071946/ELECWORKS.v.2.0.32bit.x64bit.2009.MULTI.RUS.crack.part4.rar* C9 K+ ~2 `2 r
  o1 h- m+ q. O% C+ X
另,里面似乎没有x64的crack文件,只有32位的
发表于 2012-3-29 18:35:21 | 显示全部楼层 来自: 中国河北保定
http://www.fileserve.com/file/kFNnUPG/Elecworks2.0.part2.rar1 v$ G) Z1 x2 Q
4 Z1 k( ?6 U' r- D" {6 M三维网技术论坛http://www.fileserve.com/file/t4hBp5f/Elecworks2.0.part3.rar三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa  [7 M" z+ f+ V" O% r3 H# H8 I1 y2 x+ d2 G7 E: Z( b+ Z, j* Q
http://www.fileserve.com/file/upVt3EX/Elecworks2.0.part7.rarwww.( h/ A8 B' T; x* o9 ^( S) X* b
值得学习
